How to mount guide under BB shell?
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3898 Post(s)
Liked 6,503 Times
I couldn't install the new cartridge bb without damaging the expanding plastic piece and rivet of the original (now trashed) plastic guide. The new guide (pictured) is smooth on the bottom. And the hole in the frame is huge, 8mm across. I would assume cable tension alone will help keep it in place after cables are routed. I thought about using Sugru, a screw, and two-way tape. Thoughts?
Tinker-er
Bikes: 1956 Rudge Sports; 1983 Univega Alpina Uno; 1981 Miyata 610; 1973 Raleigh Twenty; 1994 Breezer Lightning XTR; V4 Yuba Mundo aka "The Schlepper"; 1987 Raleigh "The Edge" Mountain Trials; 1952 R.O. Harrison "Madison"
Quoted: 168 Post(s)
Liked 269 Times
Try some 3M heavy duty double sided tape, the kind that is used to stick numbers on the outside of houses. It'll stay.
Likes For PhilFo:
Quoted: 3464 Post(s)
Liked 2,831 Times
Emblem tape will work.... but if you have index, that performance will suffer.
I would remove the cartridge - tap the hole, with a functional tap, then find a short pan head SS fastener, or short SS set screw, use a washer, nut or jam nut to retain.
do this before reinstalling the cartridge.
does not need to be metric. Just all have to match the other parts.
Likes For repechage:
aka: Dr. Cannondale
Quoted: 2157 Post(s)
Liked 3,425 Times
Shoo Goo.
Likes For rccardr:
Bikes: old ones
Quoted: 26449 Post(s)
Liked 10,406 Times
...I use 3M auto trim tape for jobs like that.
Likes For 3alarmer:
Quoted: 2331 Post(s)
Liked 5,040 Times
^ Me too!
Steel is real...and comfy.
Likes For jamesdak:
señor miembro
Liked 6,503 Times
Have you done this with success?
Better than two-way tape?
Yes, @repechage, it is indexed using a 6403 rd with 7-speed Shimano on the down tube.
señor miembro
Liked 6,503 Times
I liked all these ideas, but tried the screw version first as I found one that looked perfect. I drilled a tiny hole in the metal cartridge body.
The screw wouldn't thread, so I enlarged the hole with a bigger bit. The photo below was taken after it was enlarged even more by threading in the screw.
I turned the crank as I threaded it in, and it hit the spindle. But after I added the guide with the screw, it works perfectly.
I added blue Loctite just in case. Maybe I'll remove it and add some Sugru to support it even more and prevent water from entering.
You like?
You like?
Quoted: 1954 Post(s)
Liked 2,022 Times
That is insane. Just sayin.
I’ve seen that bridge before….on an Allez…Sirius? Probably lots of bikes.
señor miembro
Liked 6,503 Times
Likes For SurferRosa:
Quoted: 1617 Post(s)
Liked 2,621 Times
Likes For curbtender:
señor miembro
Liked 6,503 Times
Bikes: Serotta Rapid Tour, 89 Paramount, AD Vent Noir, All-City Space Horse
Quoted: 28 Post(s)
Liked 118 Times
I see that I'm late to the party and you've already worked out a solution... but i recently had luck using 3M Badge and Trim Cement that I picked up at an auto parts store for a BB shell that didn't have any holes already drilled in it.
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 987 Post(s)
Liked 654 Times
I guess metal shavings from the drilling won't find their way into the bearings of the BB? The term is, after all, sealed bearings.
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Tinker-er
Quoted: 168 Post(s)
Liked 269 Times
That sheet metal screw will back out, loctite won't save it. You're going to need to slap some shoe goo or something like that to keep both the screw AND the guide in. Really, the guide will be held on by cable tension, but without an adhesive as recommended previous, the guide may wander after the screw falls out.
Quoted: 236 Post(s)
Liked 171 Times
Liked 5,040 Times
Just to reiterate for those that find this thread down the road when they are looking for a solution. This is the 3M tape I've used successfully on several bike over many years now. It has never failed. If it' good enough to hold much heavier trim pieces on cars it will certainly hold a cable guide.
I've also used it to hold sensors, magnets and such on my bikes. I get the wider version and then trim it to fit invisible under whatever piece I am using it on. I've also been able to remove it without pulling paint off the bikes. Just roll it off like you would tubular tape on a rim and it should calm off cleanly without damaging good paint. They've changed the name a bit from last time I ordered it but the part number is the same.
https://www.amazon.com/3M-03615-Scot...2600831&sr=8-9
Likes For jamesdak:
Quoted: 236 Post(s)
Liked 171 Times
But, to each their own..
Likes For tendency:
Liked 5,040 Times
I tried something very similar from a competing vendor initially and it came off after a week or so. Thoroughly cleaned the surfaces first. Personally, prefer the glue method myself as the cable guide is something I'd never remove, in any case, the Loctite 'glue' I use can be removed with acetone so I think it's a better long term solution even if you think you may want to remove the guide down the road.
As I think about it, my Cherokee Trailhawk came without the homelink garage door openers. So I used this tape to mount a small key fob size opener to the inside of my windshield. It's holding just fine despite being exposed to heat and cold and all the vibrations and such that come with driving off road. I trust the stuff.
Quoted: 1146 Post(s)
Liked 1,767 Times
I think I would have epoxied the hole and drilled that for a short screw for placement. It just needs to hold side to side. I don't like the drilled cartridge, only because the next removal could go wonk if you don't remember or pass on to the next one that does service.
Quoted: 987 Post(s)
Liked 654 Times
IF, and only if, JB Weld would hold, imagine drilling and tapping for a real machine screw. In another topic, I recently drilled and tapped a previously virgin BB shell and am very confident in the resultant installation. But that would presume the plug of JB Weld wouldn't simply turn in that hole (one would reshape it into a square of oval). A hole that big -- intended originally for an expanding plug?
Quoted: 2365 Post(s)
Liked 1,753 Times
I usually screw it on once without the BB in place, to cut the threads in the shell. Then I just cut off or grind down the screw so that there's just enough of it to engage the entire thickness of the shell, and re-install. May require some trial-and-error iterations.
Quoted: 3814 Post(s)
Liked 6,732 Times
I believe Eddie did it with bubblegum and extra salty spit.
Likes For nlerner:
señor miembro
Liked 6,503 Times
