Oil With Some Tenacity?
Quoted: 1641 Post(s)
Liked 831 Times
Didn't the bottles turned from the old green to white around the time Phil died?.....
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Quoted: 1188 Post(s)
Liked 1,154 Times
I am looking for suggestions for a less-expensive substitute for Phil's Tenacious Oil. For the amount I need to use it, I can't justify (too cheap to pay) the price. I want it for freewheel use and most lubes, even motor oils seem too thin. I know, ideally, I should re-grease them, but for various reasons that's not possible right now. Any suggestions for a heavier, "stickier" basic lube that won't gum up the works?
You can also mix grease with a little solvent like white gas and dribble that into the freewheel. Warm up the freewheel and the solvent evaporates leaving the grease behind.
Liked 1,154 Times
A mechanic at work gave me a can of this stuff to lube some of the pins for lifts on my truck. It sprays in, bubbles up then coagulated. I didn't realize how expensive it was until I just searched and I'm almost out, dang...
https://www.ebay.com/p/1407376980?ii...xoCplIQAvD_BwE
Quoted: 964 Post(s)
Liked 1,451 Times
I am curious what is the situation that you use so much oiil that $10 for 4 oz is too expensive? i have a bottle that has lasted for years...mostly used to smooth quiet freewheels....not a lot other use for me.
I fully admit these and similar (what grease, what chain lube, can i use mineral oil from the laxative section in my hydraulic brakes, can I use bear grease on my brooks, etc) make me ask why? Why cheap out from products designed to do what they are supposed to do with substitutes? I can see if maybe it is a coop doing 1000 bikes a month...but then you can probably get industrial amounts and lower cost on the right stuff.
Quoted: 472 Post(s)
Liked 1,028 Times
I'll try to sincerely answer your question why. I'd be lying if I said my frugality was about money, but that is the common conception. I guess for me it's just that I already have a lot of this stuff lying around. Plus, I don't have to go out shopping, keep around another set of bottles, or spend the money. That's threefold savings AND I get to learn something about oil, which may benefit me or a friend later. This is my usual approach and it hasn't caused me trouble, but I'm leaning heavily on my training in chemistry and experience repairing all sorts of equipment, from excavation to labs. If at least a few of us are amused by being skeptical and inquisitive about products, and have training and experience to be critical, we can chat about it and keep the technical details in common knowledge. Fending off ignorance and revealing "trade secrets" to the consumer helps keep snake oil salesmen at bay.
"Good for everything in the place". And it looks just like the Park Tool grease. Suits me.
Quoted: 1610 Post(s)
Liked 2,590 Times
Quoted: 1136 Post(s)
Liked 650 Times
Likes For TenGrainBread:
Quoted: 753 Post(s)
Liked 737 Times
Do you have a source for 120w transmission gear oil? I couldn't find any thing with google. I did find some 600w oil for your Model T. I'm not sure this stuff has a bike use, but now I know it exists.
600w oil
600w oil
verktyg
Quoted: 1036 Post(s)
Liked 1,238 Times
Gear Oil
Looks like gear oil is only available in multigrades now: 75W-90, 80W-90, 90W-120 and so on. The first number before the "W" is the viscosity at room temperature. Additives maintain the same relative viscosity as the the second number at higher temperature.
Looks like 1 quart is the smallest size container you can buy??? More than several lifetimes worth of freewheel oiling. Any of those higher viscosity oils will work.
One suggestion, take a little container to an oil change place and if you ask them nicely, they may give you a little bit of gear oil.
Note: some manual transmissions use ATF - Automatic Transmission Fluid which is about 10W - too thin. Motor oils run from 20W to 50W and multiweight oils can range from 10W-30 for cold climates to 30W-50.
verktyg
Chas. ;-)
Chas. ;-)
Quoted: 753 Post(s)
Liked 737 Times
I did a little more poking around, and it looks like SAE 120 is roughly equivalent to ISO 320. This might be worth a try.
Super-Lube-54300-Synthetic-Bottle
Quoted: 2338 Post(s)
Liked 2,824 Times
Quoted: 7348 Post(s)
Liked 2,471 Times
I'm pathologically frugal, too, and it has burned me a lot. I had the same thoughts about bike lube, and to be truthful the difference between a bad lube and a good one is not that dramatic. So I set out to find good lubes that are more economical. For a while, I used ATF, and honestly, that was fine. It was slightly messy but not awful. It needed more frequent reapplication than some but less than others. Then I learned that viscous oil is actually good for chains, so I used chainsaw oil. With both of these, I bought some small squeeze bottles or reused bike oil bottles (less than 4 oz [0.11 liters]). Then I came back around, and my favorite chain oil is Chain-L. I'm back to spending a lot more per ounce, but the actual dollar increase is close to zero. If I were running a bike shop, I would probably feel differently, but I'm not.
I did something similar with cell carriers. I had AT&T and thought there had to be a better way. I went through three MVNOs (small providers that use the big companies' networks). I even went with one or two that charged by the minute and by the kilobyte, thinking I would be more careful and lower my bills. I had a lot of headaches. Some were with the setup. And I had to restrict my usage to avoid extra charges, and I ended up paying more. I went to T-Mobile, which is a great company with good rates but the coverage wasn't where I needed it. I finally came back to AT&T. It's certainly not the cheapest, but it's not the expensivest, either, and I get what I need.
Likes For noglider:
Quoted: 753 Post(s)
Liked 737 Times
Just out of cussedness I'm going to buy a gallon. That will get me under 50 cents an oz.....
Likes For bark_eater:
Quoted: 235 Post(s)
Liked 349 Times
Update
I wound up trying Bar & Chain oil. About $5 for what seems to be a forever supply. So far it seems to be working fine. I intend to rebuild this Regina FW eventually. The only problem is, since buying it, I can't get Social Distortion's "Ball & Chain" out of my head!
Quoted: 380 Post(s)
Liked 541 Times
I've been using TriFlow since it was called TriFlon and got sued. The only lube I've used on chains, freewheels and cassettes for near 40yrs now. Chains last forever and the ratchet things never wear out.
JMO of course
Charlie
JMO of course
Charlie
Likes For Steel Charlie:
Personally I hate noisy freewheels and cassettes. While I am a cheapskate too, I really have no problem spending $3 or $4 more for a bottle of oil that will give me peacefully whirring pawls for probably a decade. None of the alternative oils are even close to as viscous as Phil's.
Liked 2,471 Times
@Salamandrine, funny story.
If you ever get the chance, try Chain-L, created and sold by a BF member. I'd like to know what you think. It's been a long time since I used Phil oil, so I can't compare it with Chain-L.
Liked 2,824 Times
Good choice of music..... now just add a little Blasters, X and Sublime
Likes For squirtdad:
Quoted: 569 Post(s)
Liked 582 Times
I could not agree more. I am on a terror in my shop getting this under control. It is 35' x 46' and I can barely move around in it. Lubes for auto, bicycles, fishing reels, firearms, chainsaws, worm drive saw, synthetic/vegetable/mineral-based oils, hydraulic oils, etc, etc, etc.
verktyg
Liked 1,238 Times
Likes For verktyg:
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Showing my age... Gear oil used to be available in 80W, 90W, 120W & 140W (W = Weight which refers to viscosity). The higher the number the thicker the oil.
Bicycling-friendly temperatures are somewhere in the middle of those two ratings, so we needn't worry too much about the exact numbers.
Quoted: 18378 Post(s)
Liked 4,512 Times
If you want super viscous, super sticky oil, try Lucas Transmission Treatment.
Liked 2,471 Times
Yes it's wet. I've only lived in humid places, NY, MA, and NJ.
South Carolina Ed
Bikes: Holdsworth custom, Macario Pro, Ciocc San Cristobal, Viner Nemo, Cyfac Le Mythique, Giant TCR, Tommasso Mondial, Cyfac Etoile
Quoted: 344 Post(s)
Liked 291 Times
A long time ago I took a community college course in classic car restoration. The instructor was an old pro and he said he would squirt used motor oil into inaccessible rusty spots. He said that used motor oil is sticky and stays in place. I have used it on freewheels and chainsaws after decanting and it seems to work just fine.
