Chain wound up on outside of frame.
#51
Quoted: 3543 Post(s)
Liked 2,957 Times
#52
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
I think I smell a sock. Could be wrong. Just sayin'.
#53
Quoted: 1116 Post(s)
Liked 1,211 Times
Good reason to just buy simple, common tools like this locally. Why wait for Amazon to ship when every bike shop in the world has a chain tool, and they're not expensive enough that Amazon would save you meaningful money.
#54
Liked 1,211 Times
Yeah, I know, and I get that. But in spite of all the good-natured forum members posting explanations, diagrams, and videos, the chain is still jacked, the drivetrain is in pieces, and the bike's on the floor. If the OP has "no idea what [he's] doing with bike repairs," he should recognize when he's bitten off more than he can chew.
Bike shops exist for a reason, and a worthy mechanic can show the OP firsthand what's going on and how it's supposed to work. It doesn't have to be a struggle.
I find it nearly impossible in a reasonable amount of time to give meaningful written instructions to anything but the most simple procedures. It almost always is good advice to do a web search for Park Tool videos on the subject at hand or take to a local shop or co-op. In the old days, you'd buy a book like Glenn's and figure it out.
#55
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 275 Post(s)
Liked 448 Times
It would be helpful if newbies were allowed to post one picture their first posts. Then when they come for help they get it and stay.
Then more eyes on the ads.
Likes For biker128pedal:
#56
Quoted: 7033 Post(s)
Liked 11,068 Times
At least the chain isn't wound up inside the frame. That would be a real problem.
#57
don't try this at home.
Quoted: 982 Post(s)
Liked 516 Times
A bit late, but:
Did you unbolt the rear derailleur from the frame, or disassemble the pulley arm? Because the chain around the front derailleur is reversed. (And the rear derailleur looks like it's not bolted down into the correct location.)
Either from removing and re-linking the chain wrong (but you didn't do anything with the chain?)
Or from taking the rear derailleur off and flipping it over 360 degrees.
The photo, rotated.
The green arrow points to the part of the chain that should go from the bottom of the front chainring to the bottom of the rear derailleur, around it's bottom pulley.
The red arrowpoints to the part that should wrap around the back and top of the cassette, not under the cassette like it is now.
But the way it's configured now, it can't go around the chain ring. You probably need to unbolt the rear derailleur from the frame, then flip it upside down, and flip again. Then rebolt to the frame.
Or: cut the chain with a chain tool and reattach it correctly after mounting all the bike components correctly.
The photo, rotated.
#58
Liked 2,957 Times
I consider myself a pretty good writer, as well as a pretty good mechanic. But even explaining in writing something as simple as changing out a floor pump chuck has been daunting to me.
Likes For smd4:
#59
Liked 2,957 Times
A bit late, but:
The photo, rotated.
The photo, rotated.
#60
Quoted: 841 Post(s)
Liked 1,073 Times
Easiest way I can see to do this is to unbolt the 2 bolts holding the rear derailleur cage/pulley wheels. Remember which pulley goes on which end and same for the bolts if they are different and remember which orientation the removed cage piece is mounted. With that removed you can flip the chain over. Install the wheel with the top of the chain running on top of the cassette cog. For easier optics, rotate the pulley cage counter clockwise until the small pulley end is in the lower position and use a string or zip tie, etc. to hold it there. This makes it much easier to see the final routing as you're putting it together. Now install the upper (larger) pulley with the chain routed in front of it. Then route the chain around the back of the lower pulley and bolt the cage/pulley also making sure that the chain is routed inside any tabs on the cage. Refer to the posted diagrams above if in doubt about your routing. Done. Extra points for cleaning the parts while they're disassembled.
#61
Quoted: 581 Post(s)
Liked 921 Times
The problem is that the chain is upside down - the part of the chain that is up by the seatstay up by the brake should be the bottom run of the chain. I bet if you could pull the bit that is through the rear derailleur straight between the jockey wheels, you could flip the whole thing over so the bottom run is on the bottom through the derailleur and the top run can run over the top of the cassette. It might be helpful to remove the front part of the chain from the front derailleur to give you more room to work.
Likes For ClydeClydeson:
#62
Quoted: 1609 Post(s)
Liked 2,216 Times
The chain is looped. It is hard to discern in the picture but the part of the chain that is nearest the floor (red arrow) is the return from the chainring to the lower jockey wheel. The lower jockey wheel is nearest the floor.
Solution is to move the chain in nearest the floor (red arrow) past the other part (green arrow) and over the RD. Everything will fall into place. No need to take anything apart.
If the picture were presented from the top, you would see the portion of the chain (red arrow) is further from the frame center line than the other portion (green arrow). The RD cage needs to be rotated 180* at some point.
Likes For SJX426:
#63
Quoted: 15 Post(s)
Liked 7 Times
Solved
Success!
Went to a bike shop, they said 1.5 week wait, I said screw that im fixing it myself. The key was to take my wife's bike, which is the same make/model as mine, just the female version, instead of my other bike, and sit her bike upsdie down right behind my bike upside down. (I work on bikes upside down because I don't have a bike mechanic stand). This way, I could look at both simulataneously, instead of turning my head back and forth, and forgetting what the other bike looked like immediately. I also had to wait till I wasn't brain fogged either. It really came down to the rear derailer being all coiled shut instead of sprung open like it should be.
Procedure on how I fixed it:
First I put the crankset back on
Then I pulled open the rear derailer and the chain magically untangled and gave me enough slack to put the chain over the pedal crank arm and onto the chainwheel.
then, with the rear derailer still held open, i put the rear wheel back on, and the front derailer back into position and it just worked.
Likes For damnbike:
#64
Really Old Senior Member
Success!
Likes For Bill Kapaun:
#65
Liked 2,957 Times
Congratulations! Glad you were able to figure it out.
Now, about your stripped crankarm problem...
#66
Quoted: 18398 Post(s)
Liked 4,521 Times
Likely faster shipping could have made a bigger mess when at most he needed to remove the rear derailleur jockey pulley wheels and flip the chain down and pull the derailleur cage around.
Likes For CliffordK:
#67
Quoted: 275 Post(s)
Liked 448 Times
Success!
also now your on your way to being self sufficient.
