Does using different diameter spokes make a difference on a rear wheel?
Old 06-19-22, 07:56 AM
Aladin
Aladin's Avatar
Bikes: 2000 Litespeed Appalachian, 1998 Litespeed BlueRidge.. 1977? Schwinn LeTour 12.2 'Rain Daze'
Quoted: 64 Post(s)
Liked 17 Times in 14 Posts
Originally Posted by Andrew R Stewart
I don't think Brandt said this ("should be"). "Because spokes are usually tensioned no higher than 1/3 their yield stress" (cut and paste from the link) is the reference I see. And the word "usually" is the difference I point out. Some might read this is semantics but there's a large space between should and usually. My first copy (I leant that one to a coworker to never see it again) of his book was a long time ago. Replaced by a later edition. I do agree with the end goals he tries to explain. I do take some issue with the path he choose to take to teach it. This book did set a foundation of discussion that has lasted decades, a very worthy accomplishment.
I have no issue with using 1/3 of max strength as a max wheel build tension. If the rim and nipple/rim interface can handle it. Since most spokes break from fatigue and not exceeding tensile strength, and many rim/nipple interfaces are problematic (spoke bed cracking, nipple/rim friction/corrosion) reducing the spoke tension achievable, I consider raw spoke strength to be a minor aspect. Andy
Andrew the actual strength of the rim hole possibly is a primary mitigating factor in wheel failure... spoke under very high tension subjected to extreme stress. Impacts etc... the nip gets pulled thru. Almost always when I see them 'thru' that wheel it's maxed over 140 kgf.
I went to triplet rears early on for my own 16/8's.. averaging 110/95. Always Lasers... built some 12/6's usng the triple butted Sapim Force... which are excellent spokes.
Aladin is offline
Likes For Aladin:
Old 06-19-22, 11:23 AM
holytrousers
hoppipola
holytrousers's Avatar
Bikes: fausto coppi
Quoted: 512 Post(s)
Liked 227 Times in 163 Posts
Originally Posted by kommisar
Rear wheel for a road bike. The largest tire that can fit in between the chainstays is a 700x28 so this is a smooth road only kind of bike. The rider is 100-110kg. It will be built to a 36H cs-rf3 hybrid hub. I have a truing stand, dishing tool and a spoke wrench. My tension measuring tool is a violin tuner that can detect the frequency of a plucked spoke.
I have asked about that method before and after building three wheels that i thought were perfect while i was building them, all rims ended up with cracks on the DS. I would definitely recommend buying a tensiometer.
Back to your question, maybe thinner spokes are better because they allow a more precise adjustement. It takes more turns to achieve the same tension, so it might be easier to reach a good tension uniformity.
holytrousers is offline
Old 06-20-22, 01:15 PM
davidad
Quoted: 582 Post(s)
Liked 171 Times in 138 Posts
I've only built about 25 wheels and never used different sized spokes for the NDS and had no problems.
davidad is offline
Old 06-20-22, 07:47 PM
Aladin
Aladin's Avatar
Quoted: 64 Post(s)
Whhhhhewwww...am I IMPRESSED. Amazing................ specialty that 25 count.
Butttttttttttt... if one has a MUCH bigger view of the idea/issue... there is some instances where it DO apply.
Open mind.... you. Less nonsensical typin' ... which just serves to underline your inexperience.
Aladin is offline
Old 06-22-22, 01:45 PM
Mackers
Quoted: 194 Post(s)
Liked 181 Times in 141 Posts
Lovely.
Are you Winterrider?
You talk exactly the same mixture of gibberish and arrogance as he does.
Mackers is offline
Old 07-20-22, 07:32 AM
FatInBike
Quoted: 7 Post(s)
Originally Posted by 79pmooney
I'm a big fan of using 1) butted spokes and 2) a gauge heavier butted for the right rear. ...Cassette wheels always go a gauge heavier...
I am with you, definitively, but the point is absolutely reasonable with hubs spoked 1:1-left:right. What do you think about tension behaviour in wheels spoked 1:2-left:right (typically 24 spokes hub equipped)? My idea, truly basic and unexperienced, is to put heavier spokes on the NDS, given that the 1:2 spokes system increases left tension of 22% (source: well known Sheldon Brown website), but offers less material to oppose to the DS, with the risk to have spokes elongations (upon dynamic forces) only on the NDS? In theory, elongation is proportional to to the spoke section. Possible solution: on NDS butted in order to keep constant tension on nipples, but heavier not to elongate too much.
I really care about your opinion, before to start my next wheel project.
FatInBike is offline
Old 07-20-22, 08:25 AM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3871 Post(s)
Liked 2,568 Times in 1,579 Posts
Spokes "elongating too much" isn't a thing, unless you're using extremely skinny spokes on the drive side of a conventional real wheel. You'd have to deliberately make it happen.
Originally Posted by chandltp
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
