Cable housing rubbing on carbon frame
I just got a carbon fiber bike and the derailleur cable housing rubs on the head tube. Should I put some protection like electrical tape or something there, or am I worrying about nothing?
Boom.
Quoted: 16 Post(s)
It will wear away at the paint and give it an "smudged" look after a while.
You can put a clear piece of "tape" there (not sure what's called). Ask your LBS about it.
Roadie
I use helicopter tape, one roll will last you the rest of your life. It works quite well and is easy to cut into shapes for different areas of the bike
I'd recommend putting something to protect the finish of the frame.
I put some reflective 3M Scotchlite tape (check my signature), which doubles as reflective tape. It looks like it should be durable, but I'll have to see.
Quoted: 551 Post(s)
Liked 278 Times
Tape AND criss-cross your shifter cables. It minimizes the pressure of the cables pushing on the sides of the head tubes and if they are short enough they don't make contact with the head tube.
Quoted: 722 Post(s)
Liked 353 Times
my bianci came with some sweet rubber washers that they placed on the cables by the rub zones......they tend to move about but do work when adjusted "each & every ride"...good luck
Bike Junkie
Location: South of Raleigh, North of New Hill, East of Harris Lake, NC
Bikes: Specialized Tarmac, Specialized Roubaix, Giant OCR-C, Specialized Stumpjumper FSR, Stumpjumper Comp, 88 & 92Nishiki Ariel, 87 Centurion Ironman, 92 Paramount, 84 Nishiki Medalist
Quoted: 68 Post(s)
Liked 37 Times
+1, I found those at my LBS (had to pay for them), but they are clear and almost invisible at about 5' distance.
Roccobike BF Official Thread Terminator
Pokemon Master
Still can't climb
Quoted: 12 Post(s)
Liked 6 Times
i had the frame protection stickers and they worked fine until the regular washing caused them to fall off. then i replaced them with electrical tape because bf members said electric tape fixes everything on a bike. they were wrong. it wore through quite quickly.
coasting, few quotes are worthy of him, and of those, even fewer printable in a family forum......quote 3alarmer
No @coasting, you should stay 100% as you are right now, don't change a thing....quote Heathpack
that bike nut
Bikes: 2010 Motobecane Immortal Force 90' Trek 1400; 90' Trek 850; 06' Trek 520; 01 Iron Horse Victory
Quoted: 25 Post(s)
I run my cables criss-cross style. The left shift cable to the right stop and cross back over on the down tube. Better shifting and no rub.
My Trek came with some clear stickers to address this issue. They have been on the frame for a year and work well. They are thick plastic, thicker than typical tape. I believe auto parts stores also sell clear tape to protect car headlights and paint. There are several heavy plastic or poly tapes available from 3M that work great. Some are marketed for bike finish protection (velo tape, etc.) but you can find others designed for ski protection that work great.
My bike is a little over a year old and the tape has taken a beating from my cables. I am happy the finish is protected (even though I'm nursing an injury that has limited my riding over the past couple weeks).
Liked 6 Times
My two bikes are blue & silver and red & white in color. I picked up some round 1/2inch diameter self-adhesive backed velcro dots at The Dollar Store (white and black) that works great. The white for the road bike, and the blacks for the mountain bike. You use only the fuzzy part for the cable housing to rest on.
It is cheap and very effective. Moreover, you can change them regularly when they get dirty. Just peel off, wipe the area with some alcohol, then put a new dot on there. Also much better than the expensive lizard skin protectors.
Bikes: 2006 Orbea Volata, 84 Trek 760, 83 Trek 720,
+1 Those were the first things I bought to put on my ORCA frameset.
They call me "Mr. Mixte"
Bikes: Cervelo Prodigy
Quoted: 478 Post(s)
Liked 87 Times
Bikes: Ron Cooper, Time VXSR, rock lobster, rock lobster, serotta, ritchey, kestrel, paramount
Go, Dog. Go!
Bikes: '09 Fuji Team; '11 PedalForce QS3
Billy1111
Road Cycling
21
10-15-15 09:35 PM
volosong
Bicycle Mechanics
25
05-14-15 07:56 AM
