11-34 on Shimano 105 R7150?
Hey all,
Can I put an 11-34 on a shimano 105 R7150? I am learning. I read someone said it'll fit on an ultegra r8150 so does it mean the same thing for the 105 stuff? Do I need to buy anything else or just the cassette?
Quoted: 3242 Post(s)
Liked 2,089 Times
According the the Shimano website, the R7150 Di2 rear derailer will function with 12 spd. 11-34 and 11-36 cassettes. Depending on what you are currently running, you might need a longer chain if moving to a larger cassette.
https://bike.shimano.com/en-US/produ.../RD-R7150.html
Likes For eduskator:
Quoted: 768 Post(s)
Liked 1,747 Times
I do believe you will need to add a spacer to the hub to it as the cassette recesses to fit a 10 speed hub so on a 11 or 12, they are just a tab bit wider. So FYI
Likes For jaxgtr:
Thanks for the help everyone. I will let the mechanic do it for me. I just wanted to be prepared and buy the part ahead of time if I needed any. Appreciate it!
If you're coming from the 11-30T, just note that you''ll be losing the 16T gear to gain the 34T. I often find myself between 14T and 17T, and appreciate the smaller gaps to keep my cadence consistent. Obviously, you'll gain the lower gear for climbing, but it's not without tradeoffs.
Likes For aliasfox:
Yes this is something that I recently learned. I love to climb and incorporate a few good ascends on pretty much 9 out of 10 rides I go on. I should incorporate more flat roads every now and again but I like to climb so I can experience the thrill of a descend on the other side haha. I appreciate your input!
On my 11-spd drivetrain, I actually ended up ordering a 12-29 cassette from Miche, as it gives me 12-17 in one tooth increments, an easier granny gear than an 11-28 cassette, and all it trades away is the 11T that I almost never use. Another benefit is that the cogs come individually - ie, not built into a carrier - which will allow me to trade out individual cogs to suit my needs.
For example, I'm currently running 12-13-14-15-16-17-19-21-23-26-29. But I bought this range when I lived on the east coast, and didn't have miles of steep climbing available to me.
Now that I'm on the west coast, I'm considering switching to 12-13-14-15-16-17-19-22-25-28-32 by buying the four individual cogs and doing a swap. It would likely make 3mi of 8% more bearable, and the occasional 17% switchback easier, as well.
Likes For aliasfox:
