Spoke nipples breaking
Sr Member on Sr bikes
On a road wheel that he build/laced himself, my brother has recently had a few spokes break. Or rather spoke nipples. All on different spokes. The breakage is happening right at the rim. The spoke head parts from the rest of the nipple/spoke. Actually...the spoke is remaining in tact. That seems like an odd place for the break to be happening. He thinks it's possibly being cause by extreme corrosion there due to the dissimilar metals...brass nipple, aluminum rim, steel spoke. I think it could possibly be a result of over tensioning. He's very meticulous about even tensionion when he builds a wheel. So I'm sure the tensioning is even...but just maybe excessive. The wheels are a couple of years old. Never ridden in wet conditions. Bike is stored indoors. Any ideas what could be the issue?
Dan
Dan
Senior member
Dan
Dan
Oh that's a good thought. Thanks Dan B....I'll pass that along.
Dan
Dan
I once bought some nipples and they all started breaking from extreme corrosion. Turned out they were Aluminum nipples as opposed to the normal nickel-plated brass nipples.
You can easily tell the difference by the weight, unless you're not paying attention. I now pay attention and make sure no one inadvertently gives me aluminum nipples.
Really Old Senior Member
The head of the nipple is "the nut".
The barrel of the nipple is an assembly aid. (else you would not be able to get all the "nuts" started)
The spoke end should reach the bottom of the screw driver slot of the nipple.
Bikes: old ones
Liked 10,458 Times
...sometimes you can get enough extra insertion of the spoke by further tensioning them, if the wheels are tensioned pretty low. But otherwise there's no real easy fix for this.
Bikes: 2013 Specialized S-Works Roubaix, 1980 Colnago, Litespeed Ocoee
glorified 5954
Galvanic Corrosion
Nipple related link
I rebuilt a wheelset a few months ago that was almost unused, yet the nipples were crumbling when I tried truing the wheel. I did a lot of research and have since installed brass nipples. I don't expect the problem to come back.
The voltage difference between brass and stainless is lesser than that of aluminum and stainless, making the two metals when in contact with one another more corrosion resistant.
Nipple related link
totalnewbie
Bicycle Mechanics
2
06-28-15 02:21 PM
MikesChevelle
Classic & Vintage
6
05-11-15 04:56 AM
