Cannondale Topstone Carbon vs. Giant Revolt Advanced
Quoted: 192 Post(s)
Liked 11 Times
So I was finally able to get on both bikes side by side. Carbon 105 vs. Advanced 2. Ride’s were like night and day. Geometry was close enough, but generally the more upright position of the Giant was better for me. The Giant felt much much quicker. Ride quality was nice on each, certainly softer on the back with the Topstone given the kingpin suspension. I liked it a lot, but the bike felt a bit out of whack given the front hit fairly hard and back was soft. In terms of handling, the revolt felt better there as well. Not sure if it was just a tune up thing, but the revolt braked better as well...should be same components though.
At the end of the day, I pulled the trigger on the Giant and actually decided to buy the Advanced 0. I thought for the extra 1k, there was a ton of value. Upgrades to carbon wheels that retail for 1500 by themselves, ultegra vs. 105 and carbon crank.
I was also planning to get a second set of wheels with the Topstone for road use, so if I defer that and just swap tires occasionally, my spend is actually close to the same. Also can now use these nicer wheels for a future road wheel and get cheaper aluminum wheels for gravel use.
Hope this was the right decision, can’t wait to get the bike. Thoughts?
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times
Good choice, have a couple of friends with the Advanced 0 and they're really happy with it.
Swapping tubeless tires can be a pain, I would def plan on a second wheelset, much easier. I picked up a set of Oval brand alloy cyclocross wheels pretty cheap, they've taken a lot of abuse and are still going strong.
Quoted: 192 Post(s)
Liked 11 Times
Not familiar with shopping for wheels. What specs do i need to find for this bike?
Likes For kosmo886:
Quoted: 733 Post(s)
Liked 815 Times
Ya, I was wondering how swapping tubeless tires would go. I figure I will use the stock wheels with the road tires and get some cheaper ones for the off road. Maybe find some used if I am lucky.
Sizing
Thanks for your thoughts on the differences them between. Having a hard time choosing and not able to try them out. How did you find the sizes differ between the models? And did you still feel that the Revolt was faster on the tarmac, despite being more upright? Thanks again!
Cheers
Hampus
Cheers
Hampus
Obsessed with Eddington
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times
I wouldn't do that...carbon hoops are probably quite bit lighter, and depending on other factors may be stronger than "cheaper" aluminum wheels. I put carbon wheels on my bike, saved the stock wheels for road, and I have to say that the gravel experience on the carbon wheels has been sublime.
IME, the main upgrades are usually the seat and wheels. I upgraded to carbon wheels and it was an incredible difference. Turned the TCR into a speed demon and lightened it for climbing. I think you are on the right path there.
Quoted: 427 Post(s)
Liked 339 Times
I agree that the Giant is probably a better choice.
