What is the torque value for the max torque?
The crack on the cap is okay? Everytime. I use max 6nm..,....
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
The values are printed on the parts. In general, the way the torque values are stated indicate the intended result. In your case, max torque 6Nm indicates (your torque value) < 6Nm.
Shimano publishes most torque values as: 5Nm < (your torque value) <6.5 Nm. Your stem cap and stem bolts are usually something that don't need constant adjustment once at the recommended torque value, and "topping the torque off" can break bolts and crack carbon.
Setting up your headset is something you usually do once and only revisit if the headset loosens. My stem caps are only tightened to bottle-cage torque, or 2-3Nm, and that's just to keep the bolts from working loose.
Likes For Unca_Sam:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
The only bike in the world that should have the headset top tightened to a specific value is the Trek Domane w/ front Iso Speed. You NEVER should tighten a normal headset to any specific torque value. You properly adjust it...that is all. I NEVER use a torque wrench on a headset unless it is the aforementioned Domane. Manufacturers put max torque on parts like that to keep idiots from breaking them or making them so tight they won't turn. The top cap is cracked because you're over tightening it.
ETA: This thread should obviously be in 'bicycle mechanics' not GD.
Likes For cxwrench:
Also you should look into how to tighten the headset:
- Loosen bolts in picture #1
- Remove the cap, make sure that the plug is at the level of the bolts in picture #1 and tighten enough so it doesn't slide in the tube.
- Put the cap back on and tighten bolt on picture #2 enough to remove the play
- Tighten bolts picture #1 to 5-6 Nm.
Likes For mr_pedro:
Modern headsets with angular contact bearings need a significant preload applied, so tightening the top cap bolt should be done before the stem clamp bolts are tightened. 5nm could be too much. If the front wheel doesn't self-center after a turn, the preload is too large. Too little and you may hear a thwack sound when a sharp mismatch in the pavement is hit. That’s too loose, but no play will be felt. To adjust preload, the stem clamp bolts must be loosened first. It's the stem clamp that retains the setting. I've been wrenching for over 50 years now. I've never used a torque wrench on any small M5 or M6 bolt on a bike. I use a torque wrench on the big stuff like a threaded BB or cassette lock ring. I've never broken a carbon part or damaged any threaded part.
Likes For DaveSSS:
Quoted: 6195 Post(s)
Liked 4,810 Times
I seldom use a torque wrench on a bike. I just tighten till the thing won't move. If bearings are what I'm tightening on, till enough of the play is taken out of the bearings. When I've gone back and checked, I'm always well below the torque specs.
Bikes: lots
Liked 2,932 Times
Likes For cxwrench:
Likes For DaveSSS:
Bikes: lots
Liked 2,932 Times
Likes For cxwrench:
Likes For DaveSSS:
How often do you ride ur bike? I want to cycling until 70 years old
Liked 4,810 Times
I don't plan to retire from cycling. I might get too feeble, but at that point a recumbent trike is the plan. Hopefully I'll cycle till I check out or am put in assisted living.
Even then maybe they'll be starting to make autonomous electric trikes I can ride!
Likes For Iride01:
I ride a 52 mile loop with over 3000 feet of climbing in the first 22 miles, 3 times per week, weather permitting. I have other hilly routes for winter and spring. Rode 5300 miles last year. Both of my knees were replaced in 2017.
Are you checking out at 70 yo?
Should Be More Popular
Quoted: 22599 Post(s)
Liked 8,925 Times
Likes For Charliekeet:
"Less than" is ambiguous... 1Nm is less than 6Nm right? Would that be ok?
The dropped
Liked 1,014 Times
In a word: Yes! The components bearing markings like "Max 8 Nm" are telling you that torque exceeding that maximum will damage the component. It's different from Shimano/Campy/SRAM giving a minimum and a maximum amount. If it's tight enough to hold in place without exceeding the maximum, then that's the correct torque. If you can't get it to stay while approaching max torque, add a carbon assembly paste to add enough friction.
Advocatus Diaboli
Quoted: 4736 Post(s)
Liked 1,532 Times
Obviously (hopefully) CF paste shouldn't be used on threads/bolts - eg. the OP's headset -- I can't imagine there's anywhere that you'd use CF paste in that scenario.
Bikes: MBK Super Mirage 1991, CAAD10, Yuba Mundo Lux, and a Cannondale Criterium Single Speed
Quoted: 344 Post(s)
Liked 297 Times
One caveat, torque ratings I believe are typically specifying the max that the bolt and the threads on receiver combo can withstand and avoid stripping. Potentially a max torque rating on a component, if used, could potentially damage the item that the component is being bolted to. For example, a seatpost clamp max torque rating, doesn't accommodate or know what material or can be withstood by whatever seatpost you're using. A stem's handlebar clamp doesn't know what handlebar you're using. A FD clamp doesn't know what your seat tube can withstand, etc. The advice to use the least amount of torque necessary to hold is the best advice.
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,994 Times
I would say use torque wrenches on just about everything that is fairly mission critical or has a recommended torque spec from the manufacturer minus of course preloading bearings as that is not a torque thing (except maybe with the Trek bikes cxwrench mentioned) Using my torque wrench doesn't take much time (and once I get my box completed and figure out the wrench I want to stick with and the bits I like it will be easier currently is in a molded case at the bottom of the box and not sure I love love love it)
Clark W. Griswold
Liked 3,994 Times
Maybe if it properly tightens the bolt without it coming loose and will not cause damage. The max is there so you don't go above and cause damage but if you can get away with much lower torque go for it. That is the whole idea.
Are you suggesting one should experiment with lower values to see if one can get away with it? If the handlebars come loose on a fast descent, oh well, I'll tighten it a little more next time and try again. Sounds stupid. If you have a torque wrench, why not tighten to specified value and be done with it. No need to experiment.
