Specialized CF Epic Road bike. Do I have to worry about 30 y/o CF?
Anyone have one of these? Before I went to look at the bike, I assumed it was lugged steel. Still wanted it because of the full Campy group, but was curious if I had to worry about 30 y/o CF.
edit: also, a good place to find replacement hoods for the Campy stratos brifters?
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
Nab it if it fits. Your major areas of concern will be the bonded joints, which should give you plenty of warning before a failure. Ride it but chase down any creaks or groans to see where they're coming from. Pay close attention to any obvious points of impact.
Trek had a series of bonded carbon bikes as well in the early 90's with the usual complaint being that the ride can be harsh. Trek only had the main triangle as CF, while the fork and stays were aluminum. Current wisdom is that the main triangle can be aluminum or steel, while the stays and fork are carbon for their greater flexibility.
mycocyclist
Quoted: 910 Post(s)
Liked 816 Times
Hmmmm.
I've read where very early ones had "separation issues" at the BB joints, so keep an eye for that. Like the guy said falling as he passed the eighth floor window when asked how it was going, "so far, so good!"
I've retired the frame as I found the ride "uninspiring." But it did survive my abuse! And I can be quite abusive, to wit:
Steel and Aluminum have long, rigorously documented histories of being used in stressful environments for extended durations.
CF, not so much. Early CF used a variety of epoxies to bind the carbon fibers. There were no SOPs for the production of the fibers, either, at that time. CF has only been used in Bicycles since the early 1970s.
Quoted: 2338 Post(s)
Liked 2,822 Times
any bike left out in the elements for years on end is going to have problems, but even then I would personally bet on the steel being more able to get back to runnin.
Likes For squirtdad:
Quoted: 767 Post(s)
Liked 1,898 Times
This is complete BS/uninformed statement in terms of steel holding up due to rusting. lots of people on this forum are riding 40,50,60 plus year frames
Likes For BFisher:
Quoted: 1639 Post(s)
Liked 829 Times
Uhmmm.... make sure the bike was not regularly put away wet after rides. Moisture is one of the things that can kill the glued bond between the lugs and frame tubes, due to galvanic corrosion between the CF and aluminum.
If you see dark crud creeping out between the tube and lug seams.......run away....
Some lugged CF bike were worse with this than others, but the good news is, IIRC, Specialized did make some effort to improve the seal between the elements and the lug seams by painting over the lugs on their later version of this bike. Plus, I think they also added isolating material (I think it was fiberglass) between the lug sockets and the CF tube ends to minimize chances of corrosion.
Likes For Chombi1:
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,800 Times
I've been through 2 Epic CF frames, back before I decided steel was the material for me. Both failed at the bottom bracket/down tube joint due to galvanic corrosion/dissimilar materials The first one was a first generation Specialized CF, the second generation supposedly "fixed" this per @Chombi1's post. This was a second gen model, check to see if there's any bubbling of the clear coat at all of the joints. If not, it's good (for now).
Thanks for all who have replied so far. As for the hood replacement. It seems like the Campy Stratos were only used for one year (1994) before Stratos was replaced with Avanti. So not sure if I can find the exact hoods I need. I have never really worked with Campy, so don't know much about their compatibility. These hoods look like my best bet. agreed?
Edit: they (EC-RE500) seem to be sold out everywhere. I'm ok with a knock-off, like Hudz, but I can't seem to find what I need with them, either.
RUSA #3100
Bikes: Yes
Quoted: 237 Post(s)
Liked 505 Times
I had a 1989 "Epic Allez" carbon bike. I rode the crap out of it and then sold the frame in 2002. The problem was with these early "bonded" carbon lugged frames is that a bonded joint would eventually fail, usually catrastrophically. I do not know if they fixed that with later models but it was a real issue through at least 90 or 91.
On a side note I replaced that with a 2002 Pegoretti Palo Santo. What an eye opening difference! That steel bike was such a joy to ride. Looking back now I think that the carbon bike was starting to feel a little dead and the Pego was just so good! That experience sold me forever on steel!
https://utahrandonneur.wordpress.com
Master Parts Rearranger
Quoted: 1556 Post(s)
Liked 2,024 Times
The painted lugs/tubes are the generally assumed safer or fixed ones. I had one of these as well. Aside from some fisheye bubbling here and there in the clearcoat, it was in great shape. Totally silent, and a wonderful ride! 60cm (62cm CTT more or less) was too small for me (saddle to bar drop too much), but one if large enough, would have been a keeper. Lovely steering and handling as well. Great comfort, aluminum fork included (I've had Cannondale road/race frames around this time, also with aluminum forks, and those forks felt good--never harsh). That red one you're considering is beautiful!
Likes For dpicare26:
This bike in question is also too small for me. I normally don't see vintage specialized bikes come up too often, so this piqued my interest. Also, it's always good to have a project.
A friend of mine recently expressed interest in training for a triathlon. He does not have a bike. Of course, he has asked if he could borrow one of mine. Being a good friend, I said yes. But I'm still apprehensive, so have been looking at a possible entry bike for him to train with.
