De Rosa Primato Fork Question
Bikes: De Rosa Professional, Windsor Professional, Trek 613, Eddy Merckx Professional
I'm looking at a CL ad for a De Rosa Primato. It has a welded unicrown fork that the seller says matches the frame serial number. I thought the steel De Rosa's used two blades and a crown.
Did/Does De Rosa make forks like this for the Primato?
Liked 797 Times
I went looking for images of a Primato (as opposed to a Neo Primato) and I found examples with sloping crown forks, more traditional-looking flat crown forks (probably a correct term here but it escapes me) and what looked like a chromed unicrown fork. Do the same and see if you can find a credible example that looks like your CL ad
Thanks, Litespud & FBOATSB. I guess my initial image search was inadequate because I just found photos of 1990s and a 2004 Primato that had a unicrown fork, though I initially saw almost all semi-sloping and flat fork crowns.
OutnBack
5
10-15-18 03:31 AM
