How to avoid over-tightened seatpost clamp?
Bikes: 2018 Electra Townie Commute GO! 8i, 2019 Electra Townie GO! 7d, 2023 Cannondale Adventure Neo Allroad Speed
Liked 9 Times
My bike was fitted in the shop, and I noticed that seatpost lowered after some rides. I do have a picture of what it was like after the fitting, so I can put it back up, but I am afraid of tightening the crap out of it because this is carbon fiber frame. How do I do this properly?
I use a torque key similar to this https://www.probikekit.com/ca/tools-m...y-torqkey.html it clicks once it reaches the correct tightness.
Bikes: Volagi, daVinci Joint Venture
Also, they make a special paste for just such an application. It doesn't react with the CF and has a bit of grit to reduce the torque required. I'm surprised they didn't apply some when they did the fit.
Bikes: Roubaix / Shiv
Torque keys seem kinda lame. Men should own a torque wrench or two ![Big Grin](images/smilies/biggrin.gif)
I use the grit assembly paste ( https://www.amazon.com/Finish-Line-Bi...assembly+paste ) and just tighten to probably half the max torque spec. No need to go full tight, it's the max torque, not the recommended torque.
Arrogant Roadie Punk
I bought this one....i love it. I love it even more because I used race re-reimbursements from my team to pay for it...but still.
pan y agua
Liked 830 Times
Honestly though, if you have a decent feel for how tight things should be you can tighten a seatpost without a torque wrench. Use CF assembly paste, tighten the bolt enough to keep the post from slipping, without being hamfisted, and you're done. As JMX said its a max torque spec, no need to tighen the bolt more than what it takes to hold things together.
You could get lost and die.
You could hit a tree and die.
Rubber side down
Bikes: are fun! :-)
Liked 233 Times
Torque spec on that bike may be less than 5nm, which the key is set for. IIRC, the seatclamp on my P2, which is a similar design sets the maximum torque at 4nm.
And more tightly too.
Cat 2 Track, Cat 3 Road.
"If you’re new enough [to racing] that you would ask such question, then i would hazard a guess that if you just made up a workout that sounded hard to do, and did it, you’d probably get faster." --the tiniest sprinter
