Trouble with removing 1" headset
Bikes: Black Sheep
I'm trying to remove a 1" headset with the Park tool PT-RT1 but everytime i push the remover up the headtube, the metal part that is slitted will start to curve inwards, and then once the split ends of the tool are all the way up the headtube, they do not meet with the bearing cups because they're curved inwards. What's the deal ???
Bikes: Black Sheep
let me clarify then:
To remove the bottom bearing cup, I insert the end of the tool that is flat and used for hammering on, UP through the head tube. I expect the split ends that are following to catch on the inner bearing cup so that I can hammer downwards to pop out the headset. This is not happening because the split ends that are following end up curving inwards as the tool goes up the headtube.
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 28 Times
The flat end goes in first. You are doing it correctly. The end of the tool should obviously clear the cup. Once that happens the split ends will expand in the headtube and you will hear an audible click and be able to visually check that the ends now rest on the edge of the cup inside the headtube.
Hammer carefully and the cup will drop out.
cab horn
Quoted: 42 Post(s)
Liked 28 Times
Please read this: https://www.parktool.com/repair/readhowto.asp?id=65
Klaatu barada nikto
stop messing around with it if it doesnt fit, and make your own.
here https://davesbikeblog.blogspot.com/20...placement.html
Klaatu barada nikto
Bikes: Black Sheep
Bikes: Black Sheep
Bikes: Black Sheep
I don't want to take a hammer and punch to a chris king . what you describe is pretty much my situation though.
Quoted: 2026 Post(s)
Liked 1,096 Times
A little North of Hell
Quoted: 71 Post(s)
Fits 1”, 1-1/8” and 1-1/4” headsets.
what makes it harder, is Kings bearings being in the cups.
I don't think he is getting it all the way past the bearing to the lip of the cup.
Or his headtube is so short the other cup bearing is compressing his tool.
you could try this. you can buy them at your local hardware store or order them from biketoolsect.com
Item #UB-CLIPS: .Inserted in to the headtube on top of the lip of the headset cup, these cir-clips improve the connection between the head race remover and the headset cup. The clips also protect alloy headset cups from damage. Kit includes 5 clips: 1" (2), 1 1/8" (2), and 1 1/4" (1).</B>
Bikes: Black Sheep
Bikes: Black Sheep
https://www.parktool.com/products/det...50&item=RT%2D1
Klaatu barada nikto
Insane Bicycle Mechanic
Quoted: 814 Post(s)
Liked 746 Times
https://www.biketoolsetc.com/index.cg...em_id=UB-CLIPS
The Bike Tools Etc folks have done right by me several times. I'm repaying the favor.
Jeff Wills
Jeff Wills
yes The Bike Tool Etc folks are Great ! They have help me alot in the past years of service.
