French headset, stack height 35mm, really?
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 987 Post(s)
Liked 638 Times
I figured easy to measure, the frame and fork are sitting there on two wheels, there's no headset installed so the bottom of the head tube is resting on the fork crown. The amount of steering tube sticking up from the head tube is only 35mm.
I was considering Velo Orange's French headset but the stack height is 41mm, so I suspect no-go. I have the bike's original headset, in decent shape but the cups are not even plated, a cheapie (I recall from my youth the Stronglight #s of P3 & V4, are those valid?). So what is commercially available that fits?
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Quoted: 1641 Post(s)
Liked 831 Times
IIRC, the shortest stack height I have dealt with yet is something like 38mm. 35mm sounds awfully short. I'm wondering whether one of those headsets without a top locknut was installed on that bike. Stronglight and JPR made headsets that had a Delrin ring in the top race piece that acts like the nylon bushing at the tip of locknut, eliminating the need for a top locknut. That may result in being able to have a shorter steerer tube the usual.....
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Quoted: 384 Post(s)
Liked 6 Times
The V4 has more stack, around 39-40mm.
incazzare.
Tange Passage is my go-to when stack height is an issue (it's something like 30.x mm), but I don't think I have ever seen a French threaded one. Couldn't hurt to look around, though.
1964 JRJ (Bob Jackson), 1973 Wes Mason, 1974 Raleigh Gran Sport, 1986 Schwinn High Sierra, 2000ish Colian (Colin Laing), 2011 Dick Chafe, 2013 Velo Orange Pass Hunter
Quoted: 834 Post(s)
Liked 2,126 Times
I don't know how particular you are in terms of style/era. That said, the Shimano 105 headset has a very low stack height of 33.5mm. Here's an ebay seller with several French-threaded units:
https://www.ebay.com/itm/vintage-NOS...4AAOSwLF1X9ooh
VeloBase.com - Component: Shimano HP-1055, 105SC
You might even need a spacer!
Likes For gaucho777:
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
If you need a centerpull hanger and the 3mm of space for it is crucial, you can get a hanger that clamps to the stem's quill. Or use sidepulls.
Quoted: 987 Post(s)
Liked 638 Times
The headset I have I have looks to be in decent condition, just not pretty. As I am taking a bunch of other small parts to the chrome shop anyway, I possibly could get the non-chromed races chromed.
Still using the stem I had on the bike as a teenager in the mid-70's, a Pivo (yeah I know) drilled to pass the cable and act as a stop. I presume when I got the bike, as a frame and bag o' parts, it had a hanger. Once.
Likes For unworthy1:
An overhaul & new balls after the chrome wears through , takes care of that..
Low Cost, headsets may not bother with grinding /polishing the races after plating ..
Quoted: 987 Post(s)
Liked 638 Times
FYI. Masking is done all the time when chrome plating. All the plater needs to do is brush over the ground races with a liquid masking material.
Likes For Salamandrine:
Quoted: 128 Post(s)
Liked 12 Times
I realize I'm almost 2 years later here, but I wanted to express my annoyance that the V.O. French headset has 41mm stack height. Lots of older bikes have low-stack headsets (I have a Centurion Ironman with 33.2mm diff between steerer and headtube, and a mid/late-70s Peugeot with 35.5mm).
I appreciate that they are making/sourcing a French headset, but odd that they went with a design that simply won't work on a lot of the bikes that would want a new French headset.
"c" is not a unit that measures tire width
Quoted: 5888 Post(s)
Liked 3,471 Times
So looks like I'll be shopping around for an old headset.
There's a great post here by verktyg on stack height for French headsets. gitaneusa.com :: View topic - Headset stack height
The crown race can be an issue too. Looks like I'll be spending some time on eBay France looking for a headset (after I measure the crown race), lol.
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
Usually, the crown race and lower pressed cup are what wears out on headsets; the upper pressed cup and threaded race don't carry load (they just provide alignment) and so don't really wear. You can often just replace the crown race and lower pressed cup with any ISO headset parts of similar stack (e.g. Tange Levin, etc.) and keep the current upper race and threaded parts.
Liked 3,471 Times
I have a Stronglight P3 competition headset english threaded on another bike. If the crown race is the same, I might just swap out the cups and crown race from the english threaded P3 and keep the original threaded bit from the Mercier. The inside diameters are close (26.4 for ISO, 26.5 French if I'm lucky 27 if I'm not) (if I'm reading the Sheldon Brown crib sheet right):
https://www.sheldonbrown.com/cribsheet-headsets.html
Stop reading my posts!
Quoted: 1444 Post(s)
Liked 1,062 Times
If it's a FR fork (and not a Tange replacement) I'd bet money you would not encounter a 27.0 crown race, as that's JIS standard. I like JDT's suggestion but you also need to confirm the crown race physically fits the OEM cup if you keep that cup, sometimes the diameter is a tiny bit too big (NG) or too small (just makes a wide gap that's asking for grit to invade. If you swap both the race and lower cup then just confirm the cup fits the headtube: Tange HSs usually have matched cup with the race so you get the 30.2mm cup with a 26.4 race HS (what you'd want to try for most FR applications) and the 30.0 cup with a 27.0 race HS
Quoted: 823 Post(s)
Liked 1,395 Times
My Allegro was apparently originally the “C” grade variant that left the factory with a Stronglight P3. A previous owner recut the crown for 26.4. I have been very pleased with the basic Tange lower assembly mated with the upper parts of a generic steel headset that was original issue on a lesser Motobecane. If memory serves, Chas./verktyg has said Motobecane’s budget low-stack headsets were actually made as O.E.M. units by Stronglight.
Quoted: 987 Post(s)
Liked 638 Times
I had had any sense, when I took the frame to a frame builder to have some braze-ons added, I could have asked for a new, longer steerer tube.
Likes For tiger1964:
Pining for the fjords
Quoted: 130 Post(s)
Liked 444 Times
Campagnolo Gran Sport (and Pista) headsets have a 34mm stack height and were available in 25x100. There's one for sale on French ebay right now.
Quoted: 987 Post(s)
Liked 638 Times
Been checking out eBay looking for any of these options mentioned for a while now, unobtanium unless I want to spend $350+ on a used headset.
Liked 3,471 Times
Here is some useful tech info:
https://velo-orange.com/pages/threaded-headset-basics
Likes For bikemig:
Quoted: 823 Post(s)
Liked 1,395 Times
Post 18 gives you a cheaper solution. See if you can find the top to the French threaded P3 (the cup, the locknut etc) as those tend to survive. The problem is nearly always the bottom. So find a low stack height headset and use the bottom. The crown race will be 26.4, not 26.5, but posters here have made that work.
Likes For rustystrings61:
Bikes: 1980 Gitane sprint,1977 Motobécane C4, 1977 Carlton Clubman, 1959 Claud Butler European
Quoted: 69 Post(s)
Liked 122 Times
Ha! Four years on, and I have found this because I have exactly the same measurement, well 34.4mm! You would think someone would be making them by now! LOL. Well my search goes on!
Quoted: 192 Post(s)
Liked 566 Times
Cycles Grand Bois has a reproduction headset of a vey high quality that matches the appearance of a Stronglight P3 or a Lightrace. It has some alloy parts in the mix as well as steel and includes a ball set in retainers. It has an advertised stack height of 35 mm, so it is designed to solve exactly the problem that is the subject of this thread. If you look up Cycles Grand Bois on Google, you can utilize
Google translate. The Grand Bois reproduction parts are all made to a very high standard.
PS…Measure your fork crown seat/crown race carefully as there is likely to be some hanky panky with the dimension from that era.
PPS….Oops…It looks like they are out of stock on the French threaded version, so no help unless they are restocked….
Likes For El Chaba:
