Cost of bottom bracket replacement
The bottom bracket on my LeMond needs replacement (there was discernible play in the bearings). Can anyone give me an idea of how much a shop will charge me to do the job?
Expired Member
Quoted: 3674 Post(s)
Liked 5,441 Times
An old Octalink? Pull and replace crank and BB, probably at least $100 if all goes well. Maybe ask about upgrading to a newer Hollowtech and crank, easy to DIY next time.
Likes For shelbyfv:
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
cost of a new Bottom Bracket is between $20 and $150, depending on type and quality..
labor rates vary from shop to shop, region to region, and between a "BikeShop" that won't allow you in their repair area and a "Co-op" that will lend you a stand, tools, and advice.
Quoted: 4210 Post(s)
Liked 3,878 Times
Shimano has had quite a few versions of their 105 group. Spanning many years and old and new sometimes overlapped on new bikes. The actual version/model/part numbers are often stamped on the back side of cranks, ders, brakes and other parts. These model numbers give others far more information than just saying it's a105 "thing" from a 2002 bike.
Having said that: assuming no unusual or complicating aspects the labor to remove and reinstall a BB on most bikes should run $30-$60 at a LBS (actual amount will reflect that area's cost of living). The BB part cost might be as little as $20 or more depending on what is actually available (and there could be different grades of BBs that will work, interchange fully and have their own costs). Do know that when taking stuff off a bike or doing repairs often will expose other issues. On a 20+ year old bike I would expect this possibility and would hope that the LBS would do an initial assessment on the bike's overall condition before any decisions are made. Andy
AndrewRStewart
AndrewRStewart
Quoted: 4411 Post(s)
Liked 1,566 Times
So Octalink. They are still made in both double and triple crank versions. $35-$45 for the part. $40 labor, maybe less. So $70 to $100.
If you want to do it yourself, you need the standard Shimano cartridge BB socket and a Octalink compatible crank extractor and an 8mm allen wrench. Don't worry about torque wrenches.
Quoted: 514 Post(s)
Liked 450 Times
https://www.biketiresdirect.com/prod...2c57fc8e77d5e8
About a 20-minute job with the right tools, and minor tweaking for the front derailleur. There are other brands and models that will fit and cost less.
Really Old Senior Member
According to this, only ONE of the (15) 2002 Lemond models have a 105 group.
It lists a (105) BB-5500 w/118.5mm length.
Look on the inside of the Right crank for a model#
As mentioned, that looks like an Octa Link style.
https://www.bikepedia.com/Quickbike/Bikes.aspx
https://www.universalcycles.com/shop...QaApUUEALw_wcB
Liked 1,566 Times
Clark W. Griswold
Quoted: 4359 Post(s)
Liked 4,000 Times
Check with your local shop for actual prices but an average B.B. is $20-50 but labor can vary quite a bit depending on the market and the shop. Sometimes a better shop will charge more but in the end you are hopefully getting better mechanics and service. On rare occasions people whine about our shops prices but we do really good work and we aren't a discount place we are or try our best to be professionals and we run it more like an automotive shop and will generally work on anything which most shops won't do. However do your research and find a shop you like and it will pay off in the end.
Quoted: 455 Post(s)
Liked 112 Times
Our charge in the shop I work at is $70 parts and labor for a cartridge BB. Or may more if the owner has a boat payment!
Liked 1,566 Times
Likes For Kontact:
Quoted: 455 Post(s)
Liked 112 Times
A UN300 $40+$30 labor to swap it out. Easy peasy
Likes For jimc101:
Quoted: 455 Post(s)
Liked 112 Times
I checked our prices and an Octolink would run about the same.
Likes For Tandem Tom:
Quoted: 8 Post(s)
Liked 9 Times
This is not a hard job if you have the tools and youtube, but it's also a matter of time.
I had a situation where I simply could not remove a seized BB....finally broke down and paid my LBS $20 to remove and install a new one (I had the new part already). This is a single-person run shop though, so yea, he's extra cheap.
I should have just had him do it for me from the start!
I wouldn't bother paying shop labor for something as trivial as this. It's a 10 minute home job. Instructions are on YouTube, which is better than any of us can explain here using words.
Quoted: 2604 Post(s)
Liked 1,933 Times
I paid for the new bottom brackets, and labor was included since I paid list price, more than mail-order, for the hardware.
