Can’t remove pedals ~ but still want to use SPD shoes.
I got a schwinn Johnny g original spin bike off Craigslist. $100
Works great.
EXCEPT the pedals are rusted on solid. I’ve tried everything to remove them. But I still would like to use my Specialized Cycling shoes with SPD clips.
is there something I can hook on to the existing pedal that will adapt it so I can clip in.
I’ve googled but I am really not sure what to order or if it will work ~ and can’t afford returns and hassles with shipping.
thanks for help ….
Works great.
thanks for help ….
Quoted: 514 Post(s)
Liked 451 Times
No.
Use penetrating lube (I like Finish Line's Chill Zone), a solid wrench, and plenty of leverage.
Likes For oldbobcat:
Quoted: 505 Post(s)
Liked 640 Times
Hit it with some penetrating oil from both sides, cut the axle, and hit it with an impact wrench or tack a long bar on it and twist. A little fire will loosen it up too...
Likes For wheelreason:
Quoted: 1088 Post(s)
Liked 1,028 Times
two things.
1. Did you start with the right side (you're right side when sitting on the bike) and try to remove it by assuming the spindle rotated counterclockwise when looking at it? The right side is reversed thread while the left side is normal threading.
2. Are you using a good pedal wrench? Something like the Park Tool PW-4 which has never failed me in removing a pedal from a bike, this includes the 60s-80s low end bikes with steel spindles that had steel pedal spindles rusted in. At half the price but good for a homeowner, is the Bikehand extra long handle. It looks similar to the park but they're not the same. The Park will last well over a decade in a pro shop, mine is 20 years old and has more wear on the sides from kicking around a tool bag than the jaws have from turning pedals and axle nuts. The Bikehand was brought into a shop I was at, after about 2 years there was noticeable wear to the jaws but it probably turned more pedals in those two years than the average home shop will go through and with a 14" handle it'll move things. I don't recommend either for installing pedals, way to easy to overtighten without a lot of practice and tear the threads out of a crank, I've seen people do it too.
Quoted: 6976 Post(s)
Liked 10,975 Times
Leverage is your friend.
Likes For Koyote:
Quoted: 2490 Post(s)
Liked 2,961 Times
Left pedal is reverse thread. (Never hurts to start there.)
"I've tried everything" - have you tried a pedal wrench? They're about 18" or so long, so they provide sufficient leverage for removal of all but the most stubborn pedals. (Pedal wrenches are designated either 1/2" or 9/16" - or both, in the case of double-ended wrenches. Make sure you use the correct size.)
(Edit: just checked the website of a company that sells spare parts for the Johnny G spin bike and saw SPD pedal hardware listed for the bike. That means that the cranks take 9/16" pedals, including your SPD pedals.)
If you use a pedal wrench and the pedal still won't budge, figure out how to apply more leverage. When customers came into one of the shops where I used to work complaining that a pedal had proved impossible to remove, I'd just grab a Park Tools fork straightener to add another couple of feet of leverage. Never failed.
Here's a picture of the tool, for inspiration.
Likes For Trakhak:
Mother Nature's Son
Quoted: 854 Post(s)
Liked 1,439 Times
The first thought is always “are you turning in the correct direction for removal. Both sides, Always to the rear for removal, to the front for installation. PB Blaster and a cheater bar, strap the crank arm to the chain stay to secure it, use a leg on the cheater bar
Likes For delbiker1:
Bikes: Novara Safari, CAAD9, WABI Classic, WABI Thunder
Quoted: 366 Post(s)
Liked 457 Times
I had a pedal that wouldn't come off a new used bike. Tried heat, penetrating oil, finally took it to a mechanic who put a 2 foot pipe on a pedal wrench. It came right off.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3891 Post(s)
Liked 6,491 Times
Two words: cheater bar.
Six more words: the left pedal is reverse thread.
Likes For choddo:
Quoted: 505 Post(s)
Liked 640 Times
LOL. When folks bring in "pedals that won't come off" I sit and shoot the **** with the mechanic for a few, if I roll the bike back, and roll it back out in one motion, folks feel they ddidn't get their money's woth.
Quoted: 682 Post(s)
Liked 453 Times
I did wonder what “to the” meant. Once you know, you know, but when I needed to remember I always just lined the wrench up along the crank with the pedal towards the front wheel and push down on it.
Likes For choddo:
Also, while I have never needed one for pedals an impact wrench breaks stuff loose that nothing else will touch.
Liked 2,961 Times
You're right. I've always wondered why no one ever seems to think to use one to free a stuck seat post or stem.
Quoted: 504 Post(s)
Liked 437 Times
Impact wrenches are great, but I'm not sure how you're going to attach one to a pedal spindle, unless it has a hexagon (most only have two flats). I suppose you could try a crowsfoot but anything you put between the driver and the screw reduces the shock that's transmitted.
Quoted: 682 Post(s)
Liked 453 Times
I could probably find some other pedals in my parts box that had only flats, but they likely haven't been used in decades.
My personal preference would be to have both.
Likes For staehpj1:
Quoted: 970 Post(s)
Liked 1,633 Times
Had trouble with a Steel Pedal rusted into a Steel Cottered Crank. Even three days of PB Blaster did not loosen the pedals. I just gave up cause I was not going to use the Cottered Crank anyway. About a week latter I noted my 90 year old Dad messing around with the crank on the picnic bench. He had been soaking the pedals in Vinegar.
Well go figure, They hand wrenched right off...
It would appear that Steel on Steel rust can be treated with Vinegar. But that may not be the case with Aluminum to Steel or other alloys.
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
First, agree with those suggesting that the wrench is being used in the correct direction. L and R pedals have opposite threads. Use the wrench so that it is parallel and adjacent to the crank arm. You should be pushing on the wrench so that you are putting no torque on the crank. If this fails, soak in penetrating oil or a 50-50 mix of brake fluid annd acetone overnight. If this fails you can, if you are willing to, use a torch to heat the joint (make sure no acetone remains!) If this fails, drill out the thread from the inboard side, usin a LH or RH drill-whichever will unscrew the pedal. If this fails, take your crank arms to a machine shop and have them wire EDM the pedal out. Or buy a new crank…
Likes For Crankycrank:
Likes For WizardOfBoz:
Quoted: 504 Post(s)
Liked 437 Times
Except you have that reversed. Right hand pedal is right hand thread, left hand pedal is left hand thread. Right hand bottom bracket cup is left hand thread, left hand bottom bracket cup is right hand thread.
Quoted: 1110 Post(s)
Liked 1,204 Times
As others have said: each pedal loosens as you turn the wrench over the top of the pedal spindle rearward. They tighten the opposite way. Penetrating oil doesn't have to be bike specific - in fact I'm flabbergasted that there is such a thing. I happen to use PB Blaster because I've had a can around forever. Cheater bar as needed.
Yep
