3mm gap between the crank arm and chain stay: too little?
Bikes: i don't have a bike. a few frames, forks and some parts. that's all
Quoted: 54 Post(s)
Liked 52 Times
just dry-assembled a single speed setup. chainline seems fine, straight. but the distance between the chain stay & crank arm seems too tight.
drive side is fine, well with about 5.5mm—where they encounter closest—but the non-drive side is like about 3±mm. it seems rolling fine, just wondering if 3mm is 'too close' ish too tight, when some kind of distortion happens when ride. before trying a bit longer spindle, would like to collect your insights, what's the limit here.
fyi, the spindle is DA 109mm pista, symmetrical. what i suspect is that the non drive side arm has slightly more stretched taper as i see less room between the BB cup & the arm joint. if 3mm becomes a prob, i can simply source 112 - 113mm spindle, opening up a couple more mm on both sides.
Quoted: 3818 Post(s)
Liked 6,752 Times
If that’s the clearance on a dry fit, i.e., without tightening the crank bolt, you’re too tight. If the bolt is already cranked down, I could live with that just fine.
Likes For nlerner:
Likes For WolfgangVerne:
Master Parts Rearranger
Quoted: 1557 Post(s)
Liked 2,029 Times
You're good to go. Ride and enjoy!
Likes For RiddleOfSteel:
just in case you might want to put down a couple of turns of black tape or cloth tape, take it up a steep hill, get on the gas and see if you scrape the tape,
Likes For cjenrick:
Quoted: 1866 Post(s)
Liked 665 Times
Does the chainset need a DA spindle? If you could find something not just with more spindle length but a little longer on the non-drive side it would be better insurance. Bring both sides up to maybe 6 mm (¼ inch) if you can. Spindle 6 mm longer but on the drive side only 2 mm longer. I don't know what kind of spindle will get you these dimensions. This is where consulting a Sutherland's handbook would be useful.
If you're using a Campy Record Pista chainset and have the Campy Record Pista BB, you get even L/R spacing and very low Q.
Quoted: 54 Post(s)
Liked 52 Times
Yes, I agree! It would be ok if there's no lateral flex in the chainstays, but, do you really know?
*early DA stuffs are, understandably, stupid. it's like they tried too hard not to copy/resemble the dominating marque, Campy. unique and thoughtful same time almost obsoletely strange... IMO.
small ring
Quoted: 439 Post(s)
Liked 935 Times
I would put your intended pedals and shoes on it and check for heel strike
59 Allegro Special -- 72 Bob Jackson -- 74 Motobecane Grand Jubile -- 74 Sekine SHS 271 -- 80 Nishiki International
Likes For droppedandlost:
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,045 Times
I’d say no worries. I put road cranks on my RockHopper to go 1x and reduce Q-factor and I have maybe 1mm clearance on the non-drive side and have ridden many thousands of miles without a problem.
I should perhaps add... when I undo the U-brake straddle to pull the wheel, the brake arms block the crank arms, but it would take a fair amount of chain stay clearance to prevent that, and it’s pretty much inconsequential.
Otto
Otto
Likes For ofajen:
Quoted: 54 Post(s)
Liked 52 Times
thanks for all the inputs, folks. at this moment, i've decided not to worry about it. a few bits still incoming, almost there. can't wait to ride the heck of it...
2k miles from the midwest
Quoted: 525 Post(s)
Liked 931 Times
With those cranks, I doubt you'd cause them to flex into the frame. Now if you're running some NR-knockoff Saavadera cranks, then yeah, it would probably be kissing the chainstays.
when you climb a steep hill out of the saddle, the rear stays will flex.
this is what shifts your real derailleur on thin frame or Vitus type bikes.
in this case, you would be pulling the stays to the right, (chain on the right) which means nothing to worry about on that left hand crank.
I thought I posted this last night, but I'm not seeing it now, so here goes again. Apologies if this is somehow a dupe.
If I'm seeing your photos correctly, I'd be more concerned about the drive-side clearance between the chainstay/bb shell and the inner chainring ledges and the back of the outer chainring bolt. From the photo it looks like you've maybe only got 1-2mm clearance there. Is it really that close?
Might be I'm just seeing it wrong, might be shadows, camera angle weirdness, "fork is bent" lens distortion/weirdness, or whatevs, but it looks very, very tight to me.
All's you'd need would be a bit of flex, a little bb slop, maybe that Ital fixed cup loosening just a hair, and you're maybe shaving paint, or worse...
Fuggedaboutit!
Fuggedaboutit!
Quoted: 378 Post(s)
Liked 1,412 Times
I have this problem once in a while, on a specific frame with that type of clearance.
The R inner heel of the shoe doesn't noticeably strike the chain, but ends up greasy after a ride.
I don't remember to check while riding, and maybe I don't really want to know.
I do have extenders for the pedal spindle if it worries me.
