Are Aerobikes worth it?
I would say no, not that the CF SL 8.0 Disc isn't good but if you are going to make that jump I would go integrated and electronic 12 speed. Yes $4K is one of the cheapest aero bikes you will find but at that point the $4500 Canyon Ultimate CF SL 8.0 w/ the included Rival AXS power meter would be my pick
Klaatu..Verata..Necktie?
Quoted: 10444 Post(s)
Liked 11,923 Times
Likes For genejockey:
Quoted: 314 Post(s)
Liked 683 Times
Here's my totally unscientific test results using a loop I've ridden well over 600 times. Non-aero carbon road bike VS full aero carbon road bike on deep wheels:
More details here - How much faster is an aero bike? The definitive guide!
The speed gains are real, but whether they are important is a whole other kettle of fish. I enjoy riding both of those bikes equally. 🙂
PS: Life is short, buy the damn bike!
Likes For tempocyclist:
Most of the drag comes from your body, not the bike....so if you want more aero/faster see if you can optimize your position.
I expect the difference with an aero road bike is very modest.
That said, life is short and YOLO so if it's your call....don't forget to post pics of the new bike if/when you get it!!
FWIW, I don't claim to be an expert, but I have two TT bikes and three road bikes. My very limited experience is that you can roughly mimic the geometry of a TT/aero bike by configuring a conventional road bike. Any speed difference would have to be objectively measured because they're just so close. Most of it comes down to feel.
Bolt on a set of aero bars and maybe a zero offset seat post, and you're mostly there. However, to my very limited knowledge, road bikes often have gearing options not available on a TT configuration. I imagine with the wide spread adaptation of electronic shifting, this may no longer be the case, but mechanical shifting you're often limited to just two gears on your chain ring. I have found this to be a distinct limitation in hilly terrain. When I enter a triathlon, the elevation range of the bike course dictates which bike I use. If it's hilly, I will just use a road bike with aero bars. Flatter terrain, I will take a TT bike, the primary advantage only being the ability to shift (when necessary) without coming out of an aero position.
But as others have said, your own physiology will also be a limiting factor. While I do have two TT bikes and aero bars on my road bikes, arthritis in my back and neck limit how flat I can get. I tend to ride much higher than what is optimal, staying on the aero bars more to rest the upper body than for any real aero advantage.
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
"Worth" is a funny word. My S1 was noticeably faster than my standard road bike... but only when it was "naked", in sprint tri mode, with no bottles (nor cages) and no saddle bag. Once it was loaded for actual use, if there was an advantage, I couldn't notice it.
My understanding is the newer ones are better at that part anyway.
Quoted: 1743 Post(s)
Liked 1,281 Times
This is the bike I had in mind. https://www.canyon.com/en-us/road-bi...n-product-grid but, in the blue and white color scheme.
I just turned 70. At this age, lots of training and an aero bike will still leave you pitifully slow compared to younger riders. I have have two YOELEO R12 bikes with SRAM Force AXS 12 speed that are at least semi-aero. They're nice bikes, but I'd never be able to tell the difference in speed on the same route, merely due to different wind conditions each day.
If you're bike is setup with little saddle to bar drop, you're not going to be aero. I use 11.5cm saddle to bar drop, but I don't ride in the drops all the time to be aero and raise my low average speed. I ride in the Colorado mountains to enjoy the scenery while getting a good workout. I ride 45-55 mile routes with 3-5,000 feet of climbing, so my speeds will be low, compared to flatlander routes, that don't exist where I live.
Quoted: 389 Post(s)
Liked 255 Times
Likes For Jack Tone:
Liked 11,923 Times
Quoted: 4420 Post(s)
Liked 4,873 Times
I saw that test also when I was trying to see the difference in an aero frame. The problem with that test is that he's testing an aero "bike", not an aero "frame". The fast bike included deep wheels, narrow bars, probably hidden cables. So are we talking about aero bikes, or aero components. So sure, an aero bike is faster.
Quoted: 170 Post(s)
Liked 264 Times
I've had two Aeroads (one cf slx and one cf sl)... very fun but no faster at 22-28mph over various rolling Strava segments vs my 2015 S-Works Roubaix with 50mm Hunts (40mm bars, 10cm drop, same aero helmet and apparel choices, etc). All that to say an alternative could be to spend $3k less and put 50mm hoops on your CAAD12. Aeroads are nice looking - no question there! Btw, if you are capable of 500w + you'll like the extra stiffness of the slx lay-up - otherwise they felt indistinguishable.
I always keep two bikes running so I'll never be out of service due to a wreck or parts failure. In this case, the frames were a bargain at $1215, with seatpost and integrated bars and custom paint. One's red/black and one's pearl white. One has aero wheels. I've also owned two LOOK 585, two Colnago C-40, two Colnago C-RS and two identical Cinelli Superstar bikes. The most recent six were all new, but inexpensive frames. The Cinelli and Yoeleo frames are disc brake. No more rim brakes and skinny tires for me.
Quoted: 314 Post(s)
Liked 683 Times
Apparently exposed cables and hoses cause far more drag than you'd think (or at least, that's what the triathlete / time trial crowd report from wind tunnel testing).
Liked 11,923 Times
Well, my two slowest bikes are the ones with non-aero brake levers. Then again, they also have 36 spoke wheels.
Advocatus Diaboli
Quoted: 4739 Post(s)
Liked 1,533 Times
Typically, I'd guess the answer to this is that an aero bike (all else being somewhat equal) will not "feel better" than similar geo non-aero bike, but will feel "different". But I guess you have to define what feeling better means.
Liked 11,923 Times
Mind you, I haven't done the test blinded - and by that I mean with my Garmin in my pocket so I can't see the speed, not with ME blinded. I'd run off the road!
Quoted: 1279 Post(s)
Liked 1,393 Times
Advocatus Diaboli
Liked 1,533 Times
I'm not sure that's true. I know that for me, the bike that FEELS fastest IS fastest, and the one the FEELS slowest similarly IS slowest.
