removing decals....
removing decals....
Old 12-03-06, 12:02 PM
interceptor
not revenge...punishment
interceptor's Avatar
Quoted: 40 Post(s)
Liked 21 Times in 12 Posts
removing decals....
What is the easiest way to remove decals?
interceptor is offline
Old 12-03-06, 12:22 PM
botto
botto's Avatar
Quoted: 15 Post(s)
Liked 27 Times in 12 Posts
botto is offline
Old 12-03-06, 12:25 PM
branman1986
Eternal Cat3 Rookie
branman1986's Avatar
Bikes: 2004 Giant TCR2 Composite & 2006 Fuji Touring
with a french manicure?
branman1986 is offline
Old 12-03-06, 12:54 PM
iab
iab's Avatar
Quoted: 3015 Post(s)
Liked 3,808 Times in 1,411 Posts
Although botto has by far the nicest nails on the forum and seems willing to let you use them to remove your decals, a blow dryer or heat gun may make the job easier. If the decals are under clearcoat, I would recommend a bead blaster.
botto, would you send the nails only or the nails attached to the fingers?
iab is offline
Old 12-03-06, 01:04 PM
operator
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 26 Times in 19 Posts
Take off what you can and then goo gone. Unless it's under a clearcoat.
operator is offline
Old 12-03-06, 01:14 PM
botto
botto's Avatar
Quoted: 15 Post(s)
obviously those weren't mine, but you can have 9 1/2 finger nails if you'd like.
botto is offline
Old 12-03-06, 01:38 PM
iab
iab's Avatar
With 5 minutes of buffing, your nails could look like this.
iab is offline
Old 12-03-06, 01:40 PM
botto
botto's Avatar
Quoted: 15 Post(s)
botto is offline
Old 12-03-06, 01:59 PM
Geoff326
Geoff326's Avatar
Bikes: Cannondale CAAD7
uh wth
Geoff326 is offline
Old 12-03-06, 02:07 PM
CrimsonKarter21
Mitcholo
CrimsonKarter21's Avatar
Bikes: 2010 Mitcholo w/ Sram Force/Red
A hair dryer, but only if the decals aren't cleared.
CrimsonKarter21 is offline
Old 12-03-06, 03:20 PM
indygreg
Duathlete
indygreg's Avatar
providing they are not under clearcoat, a steamer is about as good as it gets. It supplies heat and moisture that seem to really help get stickers off and not leave any residue. Goo gone will take care of the residue if there is any.
I have no idea how to deal with clearcoat covered stickers.
indygreg is offline
Old 12-03-06, 04:36 PM
operator
cab horn
Quoted: 42 Post(s)
Originally Posted by Geoff326
uh wth
+1
operator is offline
Old 12-03-06, 04:37 PM
operator
cab horn
Quoted: 42 Post(s)
Quite simply, the clearcoat has to come off.
operator is offline
Old 12-03-06, 06:21 PM
labrat_62
guppy
labrat_62's Avatar
Bikes: Kona Nunu, 1960s fugi (now a fixed), 2006 Felt F3C
nails like those could get through the clearcoat
labrat_62 is offline
Old 12-03-06, 06:40 PM
Sixtwo
Sixtwo's Avatar
Bikes: 2005 Giant FCR1, 2006 OCR C3
I just removed a dealer sticker from my Giant with a blow dryer...took about 3 minutes worked perfectly.
Sixtwo is offline
Old 12-03-06, 09:08 PM
cuda2k
Unique Vintage Steel
cuda2k's Avatar
Bikes: Kirk Frameworks JKS-C, Serotta Nova, Gazelle AB-Frame, Fuji Team Issue, Surly Straggler
Quoted: 57 Post(s)
Liked 225 Times in 56 Posts
bench grinder. Works great, especially with carbon fiber.
{the not so small print} DO NOT TAKE THIS ADVISE!
cuda2k is offline
