For the love of English 3 speeds...
I’m wondering to what degree of disassembly should I take it - take everything off or clean it in place. The shifter doesn’t work for sure but the rear hub has an access point for internal lubrication, maybe I don’t have to take it apart completely to keep it going nice and smooth. Definitely need a new chainguard, grips and saddle. Obviously cables, housing, chain, tubes, rim tape… What have I done??
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,395 Times
I would suggest tearing apart the AW if it's being cantankerous. While they're pretty much bulletproof, they can rust or gunk up depending what's been put in them in the past (or not) and need a fair cleanup with either mineral spirits or Evaporust.
I like using slippery 00 grease (dark green) in them - the only grease that really works in an AW. Light green marine grease in the bearing races; it won't wash into the hub if the 00 grease gets onto it.
-Kurt
Bikes: 1971 Hercules, 1978 Raleigh Superbe, 1978 Raleigh Tourist, 1964 Glider 3 Speed, 1967 Raleigh Sprite 5 Speed, 1968 Hercules AMF 3 Speed, 1972 Raleigh Superbe, 1976 Raleigh Superbe, 1957 Flying Pigeon, 1967 Dunelt 3 Speed
Quoted: 1028 Post(s)
Liked 443 Times
The bottom bracket and headset bearings should be attended to.
The trick with these old bikes is never throw anything away until you're finished.
That rusty old axle nut is proprietary to Raleigh/Philips etc.
You can't go to the hardware store for a new one.
Yeah, I think so too, but I have to pace myself or I will get burnt out with this hobby. I do enjoy cleaning rusty parts so much. Very zen.
Funny - immediately after I posted here this showed up locally.
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,054 Times
Karma baby
Liked 4,395 Times
-Kurt
SE Wis
Quoted: 2747 Post(s)
Liked 3,396 Times
This has been up a few days.
https://milwaukee.craigslist.org/bik...328961494.html
If I bring another bike home I’m afraid I will be declared mentally unfit by my wife I don’t really need another bike, I don’t even want one at this point. I have to finish restoring the mountain bike I got. Then build up the touring rig on the base of the Super Mirage. I got the Phillips because it was free. I’m taking it slow with this one!
Likes For hihik:
Phyllo-buster
Liked 2,054 Times
Likes For clubman:
Phyllo-buster
Liked 2,054 Times
Likes For clubman:
Liked 443 Times
That's how they hook you.
Likes For gster:
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Likes For thumpism:
Liked 4,395 Times
Likes For cudak888:
Liked 443 Times
Liked 443 Times
Viking Frame
I stopped in to see George of Parts Unknown yesterday.
He had an interesting frame that had just come in.
A Viking
This is a stock photo
I was considering it for a 3 speed build but on examination the front forks were badly bent (sideways).
The head badge dates it from 1950 to 1955
I'm sure they could be repaired but not by me.
https://classicvikingcycles.com/photo...alley-sn-v745/
It may have been one of these as it had a headlamp mount on the fork and evidence of a derailleur hanger that had been cut off.
From the 1960 catalogue
This odd ball with a convertible top bar.....
A Viking
Quoted: 566 Post(s)
Liked 1,052 Times
Bikes: Classic lugged-steel road, touring, shopping, semi-recumbent, gravel
Quoted: 46 Post(s)
Liked 81 Times
Unfortunately I had to postpone and maybe even abandon my Raleigh project. The fork I already had to scrap since the cone and stem is hopelessly stuck inside the steerer and ended up deforming it (if it wasn't like that already). Seatpost is still stuck inside seat tube and it won't budge. I'm not sure what I'm going to do with it at this point. I wish I was retired so I can devote more time to it but that's simply not available at this time. Maybe find a good home for it. Stay tuned!
Bikes: Too many 3-speeds, Jones Plus LWB
Quoted: 359 Post(s)
Liked 265 Times
Likes For Salubrious:
Liked 4,395 Times
It may still be possible to get that wedge out, but given the steerer bulging, it's probably best to dig up another fork. They're not uncommon, but you may be better off if you find another complete Sports. I don't recall; did yours come with a workable wheelset?
-Kurt
SA AW indicator pin lengths ?
Thanks to forum member Thumpism I have a replacement index pin for my 79 Tourist Sturmey AW hub but it is significantly longer than the original. As I cast about for a shorter version is there a model descriptor of pin types better than simply looking for it by length that I can use to zero in on the correct indicator pin?
Quoted: 3810 Post(s)
Liked 6,701 Times
^ The important part to keep the same length is that solid barrel on the left. The little chain length doesn’t matter as you’ll just adjust the shift cable or the placement of the fulcrum sleeve to compensate. Looks like the replacement you have will work.
No the length over all matters in this case as I don't have enough adjustment range with the added length no matter how much I move the shifter or the cable mount. Just need the shorter indicator pin.
Quoted: 359 Post(s)
Liked 265 Times
You don't move the shifter normally. But the position of the fulcrum clip is one adjustment and the location of the pulley is the other. Between the two the new toggle chain is no worries.
Phyllo-buster
Liked 2,054 Times
