HOT TOPIC: "Toe-Overlap" What is your opinion...
Bikes: With round 700c & 26" wheels
I read a topic about some rider complaining that he was hitting front wheel with his shoes while turning.
Some of the responses:
"Every bike I've owned has had toe overlap. Not a big deal. Just be aware of it when making very slow speed, sharp turns."
"You just get used to it and learn to stop pedaling on sharp turns."
"Ignore this. It is common and a non-issue. "
"Most of my road bikes have had toe overlap."
"If it was a huge issue manufacturers would have stopped building bikes with geometry that produces it decades ago. The vast majority of people believe this is a non-issue. "
"Learn not to pedal in slow turns"
"Most of my riding is in the Mission in San Francisco, which requires an emergency maneuver at low speeds about every other block, so I view toe overlap as a (literally) fatal flaw.
"Unfortunately, toe overlap becomes a huge problem cycling alpine passes. I could not handle one in traffic."
"Toe overlap is a problem, especially when you are racing a cyclocross bike on uphill steep switchbacks."
"Toe overlap is a result of other critical design factors and cannot always be avoided especially on smaller frames."
What is your opinion. Is it "OK" or the problem is with wrong frame size or geometry that can't fit the rider?
I pedal into my turns and don't hit the wheel. You're not supposed to be turning the wheel much but leaning into the turn more. I turn slowly sometimes in traffic, and I ride a small frame. It's a semi-compact geometry so I probably should be having this issue, but haven't run into it yet. I can turn slowly fine. Or maybe I unconsciously don't pedal on slow turn? I'll try to notice later today.
Custom User Title
Bikes: Fuji Roubaix Pro & Quintana Roo Kilo
Quoted: 2863 Post(s)
Liked 31 Times
Seriously? You started your own toe overlap thread? You could have at least made it a poll. Not an issue now and it wasn't an issue in the last couple dozen toe overlap threads.
The compromises necessary to eliminate overlap are substantial.
For smaller bikes it's virtually unavoidable, and with a little bit of thought it becomes a non-issue. For example if you want to make a u-turn on a narrow sidewalk by turning left then you just turn the bars left while doing a stutter downstroke with the left pedal (and if you have clipless you can pull up on the right pedal as well). This keeps the right pedal out of the way of the wheel, you still have power, and you can make the turn. When coasting through turns you should have your cranks vertical (a roadie thing) rather than horizontal (a mountain bike thing). Stuff like that.
"...during the Lance years, being fit became the No. 1 thing. Totally the only thing. It’s a big part of what we do, but fitness is not the only thing. There’s skills, there’s tactics … there’s all kinds of stuff..." Tim Johnson
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
All the answers are in the OP already.
(I didn't realize it was a "Hot Topic")
ka maté ka maté ka ora
Bikes: breezer venturi - red novo bosberg - red, pedal force cg1 - red, neuvation f-100 - da, devinci phantom - xt, miele piste - miche/campy, bianchi reparto corse sbx, concorde squadra tsx - da, miele team issue sl - ultegra
Quoted: 25 Post(s)
Generally I'm not riding slow enough for it to matter. If you really need to ride that slowly, get a trike
pan y agua
Quoted: 1450 Post(s)
Liked 731 Times
OP, realize when people say don't pedal in a slow turn, they're talking about really slow, really sharp turns, such as a U-Turn in a parking lot at 2mph.
At anything approaching normal riding speed, you don't turn sharp enough to hit your foot.
And if you do rub your foot turning at 2mph in the parking lot, it's not trick to keep going, either, pedaling through it, turning less sharply for a second, or back pedaling.
You could get lost and die.
You could hit a tree and die.
Both my bikes have overlap. On the road bike it is minimal and has never been an issue. The track bike however has overlap back to the ball of the foot and you can't just position the crank to clear. I have trapped my foot on the wrong side of the wheel in slow speed turns. That will wake you up.
Bikes: Opus Vivace F1
Quoted: 10 Post(s)
pan y agua
Liked 731 Times
Bad idea. You want your cleat placed correctly on the pedal to get your foot in the right position in relation to the pedal, and avoid foot comfort issues and knee problems.
Moving it to effect toe clearance is asking for trouble.
So your opinion is no opinion? This issue sounds like formula 1 problem...yes, its very fast, but not comfy, hot, loud and you can drive it only on a race track. Not everyone is a racer on a straight road.
Regardless, just be vigilant when riding at low speeds or trying to make tight u turns. Practice makes perfect.
Quoted: 10 Post(s)
What the hell are you talking about? My opinion is that all of the quotes in your OP are valid and cover off the good, the bad, and the ugly of toe overlap. Some see it as a big problem, while others don't. The reasons people view it one way or another are many - type of riding, experience, geometry, etc. You will not get a consensus or any 'right answer' on this. You clearly did some reading on this topic before posting this thread - were you not able to infer the same or do you just want to beat a dead horse? Any further discussion will garner a bunch of the same answers in your OP, so it's up to you to interpret and draw your own conclusions from there.
Custom User Title
Liked 31 Times
Hey, people riding hybrids are much cooler than people riding road bikes. We talk, we laugh, we look around and even have time to stop and take a picture here and there on each and every ride. Road bikers are more like mad, caged beasts. All they see is their front wheel and average speed on their cycling computer. Try to take their attention away for a second and they may bite ;-) As I see it Road bikes are for speed and racing, while Hybrid bikes are for fun, going places and with pretty good speed if you need it.
Rider shoe size.
This is something that manufacturers can't control at all. I have size 47 shoes on a 54-58cm frame, chances are I'm going to have overlap issues.
Its an annoyance. My first road bike was a Specialized Allez (56cm), and it had what I would describe as serious toe overlap issues. Never crashed as a result, but definitely had to be VERY careful in low speed handling. My new bike is a Bianchi Infinito (57cm) and I have zero toe overlap. The main reviewer complaint about the Infinito is that handling is "slow" compared with a racier bike (Madone/Tarmac). Personally, I love the handling, the extra stability really improves the descents, while my Allez had all kinds of wobble issues. At the same time, I could see the handling being unacceptable for crit racing.
Super Moderator
Liked 927 Times
The solution is quite obvious: Electronically adjustable crank lengths that are triggered when the fork turns past 'x' degrees. They cause your feet to retract to 150 mm cranks until you finish turning, then revert back to normal length.
Speechless
Bikes: Felt Brougham, Lotus Prestige, Cinelli Xperience,
Quoted: 163 Post(s)
Liked 39 Times
EDIT: Oops, would have to be two clutches.
Quoted: 5 Post(s)
I'm short with big feet so I'm going to have toe overlap. You learn to work around it during tight maneuvers at slow speed. Never a problem during normal riding. Here's a pic of me riding that demonstrates the obvious toe overlap when you have a small bike with big feet:
Quoted: 7352 Post(s)
Liked 2,479 Times
My wife just got a new bike and noticed, while riding, that it has toe overlap. She never had a bike with that feature. I told her she'll only notice it when going very slowly, and that satisfied her. My wife is not very sure-footed on a bike, and if she can handle it, so can nearly everyone else.
