Need Help Identifying Mystery Frame with Nice Chrome and Beautiful Chrome Fork Crown
Bikes: 2017 Sage Skyline, 2015 Co-Motion Periscope Tandem, 2012 Soma Smoothie, 2006 Kona Jake, 1986 Miyata Nine Twelve, 1977 Peugeot UO18c, 1977 Peugeot PRN10, 1974 Allegro Schweitzermeister Model 76, 1972 Hugo Rickert Spezial
Quoted: 116 Post(s)
Liked 601 Times
I am really stumped with identifying this one. No remnants of any decals and it looks like it was crudely repainted, including the wide red band on the seat tube.
Seems to be late 60s to 70s frame given that it has no cable guides (not even a rear derailleur stop) or bottle bosses, but it does have a threaded derailleur hanger. Chromed, ornate lugs on head tube and chromed rear triangle. Fork is completely chrome with a very slight slant to the crown. Has openings in the side of the crown that give it a bit of a bi-plane vibe. All of the chrome cleaned up really nicely with very little effort which is why I’m interested in figuring this one out and properly badging it after a repaint.
Forged dropouts on fork are stamped “Y.C.F” and the steerer tube has “F6F” stamped on it. I thought the fork may have been aftermarket, but on closer examination, the finish work on the dropouts on the fork and rear triangle have a very similar sweep to their transition to the frame that suggests it was the original fork.
Bottom bracket is threaded ISO/English. Shimano BB I suspect was a later add.
Had remnants of a Tange Falcon headset with English threading and the steerer tube inner diameter is 22.2.
Seatpost opening measured 25.4 to 25.8 so not a particularly high end tubing, but the frame feels fairly light, so it is not gas pipe either.
Rear hub diameter measured 127 mm so I suspect it was cold set from its original 120.
Feels like a nice Japanese production bike but the lack of any serial numbers gives me pause.
Any insights would be most welcome. Below are some photos and here is a Google album link with the photos I took today.
https://photos.app.goo.gl/rkr5PXTqdKvK4fLV7
Quoted: 116 Post(s)
Liked 601 Times
Overall shot of bike.
Edumacator
Quoted: 2444 Post(s)
Liked 3,137 Times
That’s not stove pipe, that’s beautiful. Thinking of a repaint to set off those lugs, drops and forks?
Definitely a 60s-70s vibe like the early Centurions. Maybe a connection?
@MauriceMoss
@MauriceMoss
Likes For jdawginsc:
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,055 Times
I too thought Centurion, maybe from the 70's but they seemed to prefer long points
Edumacator
Liked 3,137 Times
I am no expert...
Phyllo-buster
Liked 2,055 Times
Lesser model?
Bikes: None in ridable condition
Quoted: 148 Post(s)
Liked 644 Times
It looks like an early 1970s Fuji 'The Finest'. Surprising that there is no serial number on it - can you check the lower part of the seat tube on the non-drive side for any sign of indentation? That's where the numbers usually were around this time.
Here's that tiny bit of overhang on the seat stay caps:
Lugs and fork crown. I think they changed out the crown by mid-70s:
Likes For MauriceMoss:
Bikes: 2017 BMC Roadmachine 01 Enve wheels, Sram red etap,Cinelli Vigorelli single speed, 2009 Cannondale Capo, 2016 trek Domane 6.9, disc and Di2, 2016 Scott Scale 710, 27.5 plus tires and boost rims
Quoted: 110 Post(s)
Liked 203 Times
It resembles my late 70's Rex Criterium, almost def higher end Japanese to my eye, My Rex was almost all chrome but only polished at select areas. The lugs were very much like the OP is showing. Nervex lugs maybe?
araya criterium rex - Pedal Room
"ready to navigate"
"ready to navigate"
Likes For bykemike:
Cantilever believer
Quoted: 538 Post(s)
Liked 1,846 Times
"Give it some rest and some antivirals and that should clear up in about two weeks."
Likes For RCMoeur:
mycocyclist
Quoted: 910 Post(s)
Liked 822 Times
If You Squint...
Stop reading my posts!
Quoted: 1444 Post(s)
Liked 1,064 Times
the headlugs are "Nervex Inspired" but definitely of JP origin. Fuji was a prime user of these lugs but there were a few others, I don't know if the maker was ever ID'd.
Quoted: 116 Post(s)
Liked 601 Times
Pretty Sure it is a Fuji the Finest
Thank you for all the replies. Having pulled up a number of early 70s Fuji “The Finest” photos, it appears that is what this is. The lugs are an exact match and the head tube rivet holes line up with the very wide Fuji head badge in use back then. I have a first generation Shimano Dura Ace group set I have been looking to match with the right frame. Looks like this will be an interesting project.
With VeloCals being gone, going to be a bit of a challenge finding the right decals for it. Any suggestions are welcome. Also, if anyone has an early 70s Fuji head badge separate from a frame, drop me a line.
Centurion did use those lugs but the combo of the fork and the position of the head badge stud really points out to the Fuji.
Likes For abdon:
Likes For oneclick:
Bikes: 1964 Huffy Sportsman, 1972 Fuji Newest, 1973 Schwinn Super Sport (3), 1982 Trek 412, 1983 Trek 700, 1989 Miyata 1000LT, 1991 Bianchi Boardwalk, plus others
Quoted: 583 Post(s)
Liked 700 Times
Lots of love around for The Finest. You should be pleased with the project.
Quasi homeostatic system
Bikes: '81 Fuji America, '82 Team Fuji, '85 Nishiki Bel Air, '98 Klein Stage Comp R
Quoted: 46 Post(s)
Liked 199 Times
There's a couple head badges on ebay that sadly don't appear to be in a condition worthy of a full resto. Hopefully someone here has one as some jerk just bought the nicest one off of ebay this week for their '81 America...
Likes For MrGastrognome:
Quoted: 46 Post(s)
Liked 199 Times
Quoted: 116 Post(s)
Liked 601 Times
Now I have More Questions than Answers
I uncovered the serial number on the non drive side of the lower down tube. It appears to be “6F06068” which doesn’t seem to match the Fuji serial number protocols since the first digit is a number and the second is a letter. Having now looked at a number of vintage Fujis, it is possible the Frame is a Fuji newest. Seems like they were the exact frame, but the color scheme matches a Newest and I found no evidence of blue when l used paint stripper to uncover the serial number. If the first 6 is the Showa calendar number, then the frame is a 1971. Thoughts?
Likes For Sactown_Albert:
mycocyclist
Quoted: 910 Post(s)
Liked 822 Times
"F" Is For Faint?
Could that be a very lightly struck "F" indicating the production facility in front of that first "6"?
(A side light might highlight it.)
Likes For machinist42:
Bikes: 1981 Raleigh GP, 1985 Norco Bush Pilot, . . .
Quoted: 241 Post(s)
Liked 187 Times
Edit: machinist42 just beat me.
Likes For Hummer:
Quoted: 46 Post(s)
Liked 199 Times
Update: Glad to see others seeing the F.
Quoted: 583 Post(s)
Liked 700 Times
Not a Newest. The frames actually were quite a bit different. I have a 72 Newest. Serial number is on the bottom bracket also. Different lugs and seat stay treatment. Suntour dropouts and different fork crown too.
Check the integrity of the braze where the seat stay meets the seat tube. Some these would crack along the plug and then turn 90 degrees across the tube.
"It's a fine line between absolute genius and sheer stupidity"
Quoted: 116 Post(s)
Liked 601 Times
There is a faint F
Thank for the sharp eyes. There IS a faint “F” at the beginning which DOES line up with JP serial number protocols for a Fuji. Thanks for the heads up about the stamping on the steerer tube showing the “F6F” which reinforced that there is a faint F at the beginning of the serial number and that this is the fork that came with it.
According to T-Mar’s excellent Asian serial number guide in the C&V sticky section: https://www.bikeforums.net/classic-v...ber-guide.html the whole serial number can be interpreted as follows:
I will post updates as I move along with this project. Going to be a fun one!
- The first F is the Fuji facility where it was made.
- The 6 is Showa year, which is 1971.
- The second F is the month of June.
- The remaining numbers are the serial number of this particular bike.
