why do delta trikes seem to "push" with only one rear wheel?
Bikes: Kent Gran Concor 10 speed, Western Flyer 10 speed, JC Higgins (Sears) cruiser
I am finding that many delta trikes seem to just use one wheel to drive with. While I can see reducing tire wear and improving agility on flat ground, it is really awkward riding mine as it makes mine feel like it "digs," tends to want to lift a tire, and in general loses traction easily. Has anyone tried a delta that "pushes" with both rear wheels? Most I find online speaks of using just one wheel.
Bikes: Specialized Sequoia Elite/Motobecane Fantom Cross Team Ti/'85 Trek 520
Same issue with cars. In a nutshell, you can't drive both wheels equally with a solid axle because when you turn, the inner wheel will be rotating less than the outer wheel even in a very slight turn. Cars have differentials, too expensive for generic trikes.
Handling and performance suffers for everyday use when you have a solid axle with no differential action allowed. If you have a welded rear axle, you will feel like you are plowing. The bike will seem to skip and stutter as you make harder turns. Not very pleasant.
For racing though, it is desired to have a solid drive axle. Most trike racers will lean the trikes so to be only on 2 wheels when they turn which mitigates the negative impacts of a solid rear axle.
Quoted: 1074 Post(s)
Liked 295 Times
When building a delta, rear wheel drive trike you have two inexpensive options:
1) single wheel drive
2) "live" axle = both wheels fixed and dual wheel drive
and then there's the expensive option: a differential, allowing both wheels to drive but also to rotate at different speeds.
Basically a live axle drive will handle equally poor in both directions of turn, and due to the difference in circumference between the inner and outer wheel, one wheel will have to "scrub", slip & slide a little, fighting the turn and causing tire wear.
Quoted: 5793 Post(s)
Liked 2,585 Times
Having 2 driving wheels on a common axle calls for a differential so that one can go faster (or slower) when going around curves. These are pricy and heavy so cheap trikes opt out and have single wheel drive.
Years ago there was a trike (don't ask, I don't remember) that had both wheels share a common axle, but each wheel was on a freewheel and so the outer wheel on a curve could overrun the inner. This is a nice simple and efficient design, except that it can' be used with any kind of hub brake, which is why you don't see it often.
FB
Chain-L site
FB
Chain-L site
Liked 295 Times
Liked 2,585 Times
Like all design, it's about trade offs. I suspect that the OP's problem and that many (most?) adult trikes are designed for seniors or utility purposes, and a hub brake greatly simplifies the design. Since performance isn't a real issue (to the designers) they opt for the cheap simple solution of single wheel drive.
I suspect that the differential question is one reason that so many recumbent trikes are opting for single rear wheel drive.
FB
Chain-L site
FB
Chain-L site
Because there is only 1 wheel driving, and it is off center ...
there are German deltas with a differential but those Germans don't work for cheap.
they would be Recumbent rather than Upright types ..
Tadpole types are simplet to drive via 1 center rear wheel ..
there are front wheel drive delta designs too ..
A hand driven crank friendly design for Para cyclists W/O leg function.
Quoted: 239 Post(s)
Liked 7 Times
had assumed it was a sport for people with handicaps preventing balance on 2 wheels.
but they actually balance on just 2 when turning? this blows away my assumption of lack of ability; why not race bikes then?
Bikes: Bike(s)
Here's a quick link to observe some trike racers negotiating corners at speed:https://www.youtube.com/watch?v=1k-o2-1IA4A
They appear to lean into the corner while accounting for road camber and given slope, maintaining their COG inside the turn to avoid an upset.
The differential design was originally patented by a fellow named Starley in the mid 1880's, and incorporated into their trikes. There are quite a few contemporary differential systems being used in delta configuration.
Liked 2,585 Times
I'm more of a Torsen fan myself.
FB
Chain-L site
FB
Chain-L site
Quoted: 1572 Post(s)
Liked 643 Times
Now that we're in race car terminology, a "push" (running straight in the corners) is what's going to happen to a delta trike that drives both rear wheels via a solid axle.
Liked 2,585 Times
There'a a bit of fighting on low speed turns, but at anything higher the weight shift (tipping) causes the inside wheel to slip, and the outside wheel drives it around the turn. I don't know what would happen on a recumbent trike where the tipping forces are much lower, though I suspect it would be similar.
FB
Chain-L site
FB
Chain-L site
20barcroFT
Bicycle Mechanics
1
08-11-14 10:14 AM
20barcroFT
Classic & Vintage
0
08-10-14 02:46 PM
