2002 Trek 7700 FX Front Wheel rec? Also, tubes?
I've got a 2002 Trek 7700 FX. It came with Presta wheels, and I quickly developed a distain for them, so my LBS drilled out the holes for Schraders. Not the best solution, but inexpensive. The front wheel in particular seems to keep pinching the tube, and my current LBS, which is the best one I've experienced, has found bits of metal around the hole. The real solution, of course, is to put a Schrader wheel on it.
The bike came with 700x38 tires, but as the vast majority of my riding is city streets and paved trails, with the occasional hard/slightly muddy dirt or some crushed, hard-packed gravel, I've found that the rolling resistance could be improved, so I'm going to 700x32 Gatorskins, just doing the front to start and see what I think.
I've talked to my LBS about this. They love the Gatorskins, and while they could take whatever rim I purchase and build the wheel, they strongly recommend I buy one prebuilt, as the cost of the build would be pricey. So - I'm thinking that what I'd like to get is a 18" inner-diameter Schrader front wheel, as I can't imagine ever going larger than the 38s I started with. Could I get a recommendation or two of a proven, durable prebuilt wheel for this spec?
And while I'm asking, what tube would be a good choice for 700x32 Gatorskins? Amazon recommends the "Continental Tour 28 700x32-47 40mm Schrader (Auto) Valve - 4 Pack", but the reviews suggest this tube is thinner and smaller than what most people use. I don't mind paying a few bucks more for a great, durable tube well-sized to the tire so I'm not dealing with a flat miles from home.
TIA!
TIA!
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times
Likes For hokiefyd:
Quoted: 768 Post(s)
Liked 1,745 Times
The Gatorskins will work, but just be aware that they're very firm ride like concrete (due to the flat protection) and I presume they'll be less comfortable than the tires you have on it now. Given the stated use (on paved trails and occasional gravel), you may not experience a perceived improvement in rolling resistance. In fact, rougher surfaces are ideal for slightly larger tires at lower pressures that deflect against, rather than bounce over, small obstacles.
Fixed it for you...
However, I rode Gatorskins on my commuter for 4 + yrs give or take and never had a flat, so while they ride like crap, they are a great tire.
Likes For jaxgtr:
