Installing bar-end shifters after bars are taped
Quoted: 765 Post(s)
Liked 660 Times
I recently decided to convert a just-rebuilt bike from downtube shifters to bar ends. I didn't want to strip off the freshly-wrapped bar tape (one of my better wrap jobs, as luck would have it) in order to wrap over the lower sections of shifter housing in the usual manner. The shifters work fine with the housing outside of the tape, but the housing is a bit "floppy." That isn't a problem functionally, but it bothers me a little
Does anyone have a clever method for overwrapping the bottom-most couple of inches of housing--the part closest to the shifters, that is--to secure it a little better? I suppose I could try some sort of Rivendell-esque band of twine, but I'm no doubt there are other approaches that would work as well or better. What have you got?
www.redclovercomponents.com
--Ogden Nash
--Ogden Nash
Quoted: 4512 Post(s)
Liked 6,383 Times
I recently decided to convert a just-rebuilt bike from down-tube shifters to bar ends. I didn't want to strip off the freshly-wrapped bar tape (one of my better wrap jobs, as luck would have it) in order to wrap over the lower sections of shifter housing in the usual manner. The shifters work fine with the housing outside of the tape, but the housing is a bit "floppy." That isn't a problem functionally, but it bothers me just a bit. Does anyone have a clever method for overwrapping the bottom-most couple of inches of housing--the part closest to the shifters, that is--to secure it a little better? I suppose I could try some sort of Rivendell-esque band of twine, but I'm no doubt there are other approaches that would work as well or better. What have you got?
I know it goes against the grain here but I double wrap most of my bars for extra cushion anyway and especially if the tape is ratty like on a new acquisition.
The last couple that I have done I just wrapped the upper half and called it good.
I also just reinforce the area at the brake lever with electrical tape if the hoods or tape start to come loose or breakdown.
My hands have always gone numb pretty easy and seem to be getting worse.
Likes For merziac:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3888 Post(s)
Liked 6,485 Times
It's a bit frustrating in the short term when you have to retape your bars quickly if you change out your stem or whatever, but it's worth it. Take a little pride.
Likes For SurferRosa:
Quoted: 1088 Post(s)
Liked 1,205 Times
I guess if I had to think through this for a clean look, it would probably take these steps:
1) Remove shifters (I know, I know...)
2) Position housing end where it needs to be to fit properly against the shifter
3) Start tape with matching tape a few inches from the end, matching the original wrap's direction
4) Tuck tape into the bar end
5) Replace shifter
Mind you, I haven't done this, so I may be missing something simple that would thwart this, but this is where I'd start.
5) Replace shifter
Quoted: 887 Post(s)
Liked 335 Times
I'm guessing that you wrapped from the bottom to the top, so there is no tape to work with at the bar end. If I am wrong you can ignore me now. If I am right you are sort of screwed for an elegant save; but with a deft touch you may be able to cut and add and dress it up.
Quoted: 3810 Post(s)
Liked 6,702 Times
I would just slice the tape clean at the bar end, insert pod, then use super glue to secure the tape end (with some scotch tape to hold the end secure while the glue dries).
2k miles from the midwest
Quoted: 525 Post(s)
Liked 931 Times
What I've done is waxed thread a la Rivendell, with ~.5" right at the shifters and another wrapping about the same size by the bends. I've had a couple singlespeeds that grew derailleur hangers...
Quoted: 1949 Post(s)
Liked 2,010 Times
Need a picture of your bars as is. Use cotton tape and wrap over the housing from the shifters to beginning of the bend so that the housing goes up just a bit and heads back down towards the housing stops on your DT. It won't take much tape. Contrasting color would be cool. Finish off the wrap with twine or normal electrical tape.
Quoted: 3464 Post(s)
Liked 2,829 Times
Some bar end control bikes had the cable housing appear early - just beyond the straight return.
tape the housing on provisionally to double check the cable housing lengths and where you wish the cabling to exit and reward the bars. No kludge.
Liked 2,829 Times
Forgot - some Japanese brands used a section of clear vinyl tubing to slide on and protect the frame- the days of raw stainless housing
Quoted: 765 Post(s)
Liked 660 Times
But... but..I have always prided myself on not using more bar tape than strictly necessary. I am at a stand.
--Ogden Nash
--Ogden Nash
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,800 Times
Pick two.
Likes For gugie:
Quoted: 2483 Post(s)
Liked 2,955 Times
Ifn it was me, I would just wrap another layer over the whole thing.
Likes For Trakhak:
Quoted: 2333 Post(s)
Liked 2,097 Times
Unwrap and rewrap with the same tape should be an option unless you want a perfect look
Crawlin' up, flyin' down
Quoted: 1027 Post(s)
Liked 2,528 Times
Three obvious solutions being overlooked here. (1) Go with stem mounted shifters. (2) Convert the bike to a fixie. (3) Sell the bike and use the cash to buy one that already has barcons.
Okay, I didn't they they were good solutions.
Likes For bikingshearer:
We are missing some details. Cloth tape? Bottom up or top down? I assume you would have said so if it was shellacked.
Anyway, assuming it’s cloth, you could trim the end flush, then wrap just the housing portion in the drops top-down, tuck the ends in and re-insert the shifters. Pretty simple and wouldn’t look as kludgy as wrapping with twine or whatever.
Alternatively, just pull the tape off and re-wrap. If you did it once you can do it again. I have had pretty good luck re-using cloth tape by wrapping it on a piece of fat dowel as I remove it. Obviously all bets are off if it’s shellacked.
Quoted: 195 Post(s)
Liked 207 Times
Funny, but seriously, good stem shifters on a friction shifting bike is a solution that shouldn't be dismissed. If you ride on the hoods or tops almost exclusively it can be more convenient than bar ends. (Hope this statement doesn't cost me my vintage bike tourist certificate!)
Likes For Cycle Tourist:
52psi
Quoted: 790 Post(s)
Liked 802 Times
Reuse the tape.
Liked 5,800 Times
fify
Quoted: 765 Post(s)
Liked 660 Times
My experience with removing and rewrapping this brand of tape, which has an adhesive strip, is that it can be done, but only if you do so immediately--otherwise it rips instead of peeling cleanly away from the bars. This bike has only been ridden a couple of times, but the tape has been on there for a couple of years. No way could it be reused.
--Ogden Nash
--Ogden Nash
Likes For jonwvara:
Quoted: 874 Post(s)
Liked 2,288 Times
This is the way the Mondia is wrapped with cables exiting like Aero brake cables
My Mondia is the only bike I have that uses bar end shifters. This is how they were done when the bike was new. I looked at a Bicycling Magazine review of the bike when it was new and copied it. This would require doing the bar tape over but no floppy cables, nice and tidy.
Likes For Kabuki12:
Quoted: 765 Post(s)
Liked 660 Times
--Ogden Nash
--Ogden Nash
Quoted: 874 Post(s)
Liked 2,288 Times
I have nothing to compare it to but they work very well . There doesn’t seem to be any binding, of course the trick to setting up bar ends is getting just the right amount of friction. The first time I went out on a ride I didn’t have enough tension on them and I got some ghost shifting while climbing a hill and it wasn’t fun. My daughter has SunTour type that have a ratchet action that the Campy ones don’t have.
Not lost wanderer.
Quoted: 886 Post(s)
Liked 997 Times
Cut and remove the tape from the brakes down. The rewrap bottom up including the housing under it how you want it. Then finish with electrical tape covering both the top section at the brakes and the freshly wrapped bottom section.
Cambodia bikes, Bridgestone SRAM 2 speed, 2012 Fuji Stratos...
“Senior” Member
like the feel so I switched it back to the original routing with one big curve from the bottom of the bar. It was a big improvement. I was using the original coiled housing but with a new liner. I also know tension on the barcon should be kept as light as possible.
