Shimano Claris R2000 remove Chainguard
I bought this crankset.
https://www.bike24.com/p2226997.html
It has a chainguard but I can't see any bolts to remove it.
Does someone knows if it can be removed?
Bikes: 2017 Colnago C-RS, 2012 Colnago Ace, 2010 Giant Cypress hybrid
Quoted: 408 Post(s)
Liked 122 Times
Looks as if it's a HollowTech crank set which does not have a chain guard. That's the large chain ring The bolts should be on the inside (back part) of the crank set.
HCFR Cycling Team
Ride Safe ... Ride Hard ... Ride Daily
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
HCFR Cycling Team
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
I noticed it has some phillips screws right near the 34T disc and some teeth doesn't allow for the screws to be removed.
Tried unscrewing the Allen bolts attaching the 34T ring to the bigger one but I desisted since I don't want to strip anything.
Here's a picture for reference.
Quoted: 408 Post(s)
Liked 122 Times
OK! That doesn't appear to be a standard HollowTech crank, at least not the same as a 105 and higher. However, it does look as if you'll have to remove the hex studs in order to replace either of the chainrings. Removing the Phillips head screws might remove the face piece/ring guard, but it may not look very aesthetic after taking it off; if it does come off.
HCFR Cycling Team
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
HCFR Cycling Team
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
It's a Hollowtech crankset (Shimano Claris R2000), the first Claris crankset used Octalink but now the 2nd gen uses Hollowtech.
The hex bolts are too tight. I have a rotary tool similar to a Dremel, I think I'll remove the bits of plastic to expose the 50T tooth. Reason that I want to remove it is for ease of cleanliness where dirt and grime will accumulate there, with the chainguard on it will just get messier over time
