Miyata Ridge Runner rear derailleur question
Old 01-07-24, 04:53 PM
marius.suiram
Quoted: 243 Post(s)
Liked 172 Times in 110 Posts
Hello, I just bought a 1984 Miyata Ridge Runner mountain bike.
The original rear derailleur is a Suntour Mountech which is known as kind of bad and many were replaced because of the dirt they accumulate and hard to maintain.
The one on the bike was very dirty and the upper pulley was stuck and with broken teeth.
So I want.to replace it with something close like period and Suntour. I tried a Cyclone mark II, but I cannot move the chain on the bigger sprocket (28 teeth), even I released the adjustment screw as much as possible.
Any suggestion way and what should I use instead?
1992 Torelli Nitro Express; 1972 Claud Butler.
marius.suiram is offline
Old 01-07-24, 05:25 PM
ehcoplex
Bikes: '38 Schwinn New World, ’69 Peugeot PX-10, '72 Peugeot PX-10, ‘7? Valgan, '78 Raleigh Comp GS, ’79 Holdsworth Pro, ’80 Peugeot TH-8 tandem, '87 Trek 400T, ‘7? Raleigh Sports, ‘7? Raleigh Superbe, ‘6? Hercules
Quoted: 761 Post(s)
Liked 1,563 Times in 757 Posts
The Cyclone MKII GT should easily handle a 28t cog. How much space is there between the small cog and the drop-out/stays? Is it a freewheel hub? If there's enough room you could put a spacer behind the freewheel to move it outboard some. Or, ideally, reconfigure the axle spacers and re-dish the wheel....
ehcoplex is offline
fender1
fender1's Avatar
Bikes: I hate bikes!
Quoted: 431 Post(s)
Liked 710 Times in 233 Posts
Suntour VGT-Luxe?
fender1 is offline
Old 01-07-24, 05:52 PM
marius.suiram
Quoted: 243 Post(s)
Thank you.
It is a freewheel. I hope I can remove it and put a spacer there, because I have enough space.
Old 01-07-24, 05:54 PM
marius.suiram
Quoted: 243 Post(s)
Originally Posted by fender1
Suntour VGT-Luxe?
Thank you, I will keep you suggestion as a back up, I will try first to add a spacer.
Old 01-07-24, 06:25 PM
ehcoplex
Quoted: 761 Post(s)
As I said, ideally you'd get things to line up by changing out axle spacers (the 'space' you lose on the drive side needs to get taken up on the NDS so the OLD fits the dropout spacing properly) and re-dishing. But the behind-the-freewheel spacer works too. In theory the spacers (which seem to usually be aluminum) can get crushed under torque and come apart, but I haven't seen it. They're the same spacers that get used for tweaking bottom bracket alignment. These are the ones I've used in the past- https://www.amazon.com/gp/product/B08SQKT2MV
ehcoplex is offline
Old 01-07-24, 06:37 PM
machinist42
mycocyclist
machinist42's Avatar
Quoted: 910 Post(s)
Liked 820 Times in 452 Posts
Missing Links?
Will it climb onto the lowest gear when the chain's on the smallest front chainring?
machinist42 is online now
Old 01-07-24, 06:49 PM
marius.suiram
Quoted: 243 Post(s)
It makes noise, like trying to move.
It moved 2 times out of ten and after the rotate a few times.
Old 01-12-24, 05:42 PM
marius.suiram
Quoted: 243 Post(s)
It worked, putting a couple of spacers.
Thank you
Likes For marius.suiram:
