Best tire pressure for 30mm tires?
Fellow cyclist,
I just got a new Canyon Endurace road bike that comes with 30mm Schwalbe pro one tires. For any of you who has ridden with 30mm tyres for a while, what do you consider to be the best pressure for non-tubeless?
I filled it up with 75 psi on my maiden ride earlier today and it was very comfortable on rough tarmac. I'm 150 lbs or about 68 kg.
Thanks,
Richard
Thanks,
Richard
Quoted: 20810 Post(s)
Liked 9,456 Times
I've only ridden 30s tubeless, but that was 70psi when I was at ~210lbs. 75psi at 150lbs is significantly higher than you need to be.
Likes For WhyFi:
Bikes: 1984 Gitane TdF, 1986 Look Équipe, 1983 Colnago Super
Quoted: 113 Post(s)
Liked 140 Times
Here's Frank Berto's chart, to use as a guide. It looks like around 60 psi is more appropriate.
The horizontal axis is weight per wheel - see the instructions at the bottom.
Likes For cyclic_eric:
Thanks for the input. I just converted the tyres to tubeless today. I will test riding it at 60 psi tomorrow.
Richard
Richard
Likes For richard.susanto:
Should Be More Popular
Quoted: 22638 Post(s)
Liked 8,953 Times
Likes For datlas:
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12832 Post(s)
Liked 7,757 Times
Likes For LesterOfPuppets:
Liked 8,953 Times
Not to derail thread, but is there really any science behind the 15% for wheel drop? Why not 17% or 13%?
Likes For noodle soup:
Liked 9,456 Times
Wow...55-60ish PSI. That's a game changer for me, coming from my old Trek bike which has 23mm tires (110 psi).
Thanks, all. I will test this tomorrow.
Richard
Richard
Liked 9,456 Times
Likes For WhyFi:
Liked 8,953 Times
If you still have your Trek, drop your PSI to 80F and 85R. Do it now and thank me later. Pumping up to “max” PSI is usually too much.
Bikes: everywhere
Liked 7,757 Times
I have the same tires, tubeless p, on rims that are 28.5mm wide (external). I weight about 200#, I usually run about 60-63 front and 72-77 rear, depending on if I skip a day pumping them up or if I know I’m going to ride some rougher pavement. I’ve run them as low as 50/60, but they feel just a bit too squishy for me at the lower pressure. Definitely a personal preference thing.
Liked 8,953 Times
I understand that having a "uniform" rule makes it easy to calculate, and actually the 15% drop rule gives a reasonable result, but like anything else it's a starting point and can/should be tweaked. It certainly makes more sense than the newbie error of pumping up to the "max rated" PSI but I still don't think it's "scientific" or evidence based.
