Cassette removal tool...Sun Run?
Bikes: 1987 Centurion Ironman Master, 1992 Koga Miyata Exerciser, 1992 Schwinn Crosscut
Quoted: 209 Post(s)
Liked 175 Times
My grandson's little Trek 7-speed mountain bike has a cassette lock ring labeled:
Sun Run 40N.m
The locking ring has 12 teeth, and is about 31mm wide.
Any idea where I could find this tool, or an equivalent?
Thanks!
Sun Run 40N.m
Thanks!
Really Old Senior Member
Sure it's not a Sun Race FREE WHEEL, not cassette?
https://www.parktool.com/product/fre...26%20Freewheel
Freewheel or Cassette?
Super Moderator
Quoted: 1173 Post(s)
Liked 931 Times
Picture ?
It's a Free Wheel.
Likely uses the tool I linked to. Can't count the splines though, since the nut obscures them.
The splines I think you refer to are for disassembling the FW, not removal.
Clark W. Griswold
Quoted: 4389 Post(s)
Liked 4,027 Times
SunRun the new Laxative brand from Maeda Industries. You will have a Superbe bowel movement when you Sprint to the toilet. We call it the New Winner Accush t system but you can just call it SunRun.
Quoted: 209 Post(s)
Liked 175 Times
Silly of me not to recognize this, but I don't have much experience with the newer stuff, and had never heard of Sun Run.
You guys are the best, thanks again!
I have the same.. sun run, 12 splines, calculated 30 to 32 mm diameter
Can you confirm which tool did you use? I can't find the specifications, and the one that's linked above doesn't seem to be correct....
Thank you!
Droid on a mission
Quoted: 317 Post(s)
Liked 281 Times
Make sure the area where the tool goes is free from sand and other gunk, try blowing it out with an air hose gun before inserting the tool. Other issues may be a bent axle partially causing blocked access, if that is the case, you may need to remove the axle's lock nut first.
Quoted: 550 Post(s)
Liked 419 Times
Don't mean to revive an old thread, but can anyone identify the larger spline tool for the lockring?
This is a freewheel with a cassette. Yes.
I'm not talking about the Parktool FR1.3 to remove the freewheel from the wheel.
We need a bigger tool to undo the lockring to get the cassette off the freewheel.
Quoted: 1092 Post(s)
Liked 1,030 Times
Quoted: 4434 Post(s)
Liked 1,576 Times
It's a $15 freewheel.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3894 Post(s)
Liked 6,497 Times
Sr Member on Sr bikes
I just came across this today. Many freewheels that require a splined freewheel tool…Shimano, SunRun, etc…can be removed using the head of a 13/16th hex nut, or a 13/16th Allen wrench. Also the hex end on some sockets is 13/16. I tried it. Fits perfectly.
https://m.youtube.com/watch?v=vMMNdx4TZ_s
Dan
Dan
Quoted: 550 Post(s)
Liked 419 Times
Everyone here has missed the point.
Removing the freewheel off the hub is not the issue. The Parktool FR1.3 does exactly that. That Youtube video above is moot.
Opening the freewheel to service the pawls and 39 bb's on the bottom and 31 bb's on the top is not the issue. The Parktool SPA2 does exactly that.
It's the lockring that binds doesn the splines. So the splines can be removed from the freewheel.
Liked 1,576 Times
Freewheels don't have cogs compatible with cassettes, and you can't use splined cassette cogs on them. This particular freewheel has replacement parts available and was not intended to be disassembled, which is why there is no tool available commercially to remove the cog lockring.
If you just want to make belt buckles out to he cogs, cut the lockring with a grinder. Otherwise, I don't know why you would take this apart.
Liked 1,576 Times
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4339 Post(s)
Liked 2,983 Times
This reminds me of the famous Ken M who would inject ridiculously uninformed statements into message boards and FB posts just to watch people argue with each other.
Kenneth McCarthy (born c. 1980),[1] popularly known as Ken M, is an Internet troll known for his comments on news websites such as Yahoo! and The Huffington Post. Unlike the more common associations for the term troll on the internet, Ken's comments are usually benign, with his comments displaying a complete lack of understanding of the featured topic, while other commenters take him seriously.[2]
Likes For DiabloScott:
