Tool for 5 speed Maillard Freewheel
Henderson, NV
Bikes: Trek Alpha 3700, GT STS DH, Raleigh Grand Prix, Fisher Montare, Fisher CR-7, Fisher Aquila, Diamondback Sorrento, The Bike Beat Revolution, KHS XC 504R
Liked 651 Times
Need to remove this freewheel.
It"s a Maillard, made in France, 24 spline, looks like 30 mm diameter. Mounted on a SR hub.
Is the CT-3 the tool? Some say FR4 for Maillad, It's only 20 splines from what I can tell.
Is there another tool that will work like one with 4 or 6 splines etc? Any DIY tricks to remove without the tool?
I'm thinking the bike shop might be a better option than buying a one time use tool for 30+ dollars.
I don't need to save the freewheel. I'm replacing it with a single speed,
![](https://cimg5.ibsrv.net/gimg/bikeforums.net-vbulletin/813x1080/maillard_5_spd_freewheel_89ef211752258254641bd9896df55ad863dc62c5.jpg)
Probably more economical to have a shop remove it but here are some choices. mallaird 24 spline freewheel removal tool - Search (bing.com) Also this for removing without special tool.
Henderson, NV
Liked 651 Times
Yeah. I saw that video too. I haven't been able to get the lockring loose.
EDIT: I got the lockring off. The inner hub part is being difficult. Going to take to work and I'm sure I'll get it off there. Bigger pipe wrench and bigger vise.
Likes For Desert Ryder:
Liked 2,945 Times
Search for a Normandy freewheel remover. If you don't expect to need it again, any shop that's been around for 20-30 years will have it and should remove the freewheel for a nominal charge.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Henderson, NV
Liked 651 Times
Success!! I removed the inner part of the freewheel with a large set of vise gripes and a hammer.
Now awaiting the single speed freewhell to continue with my project.
