Shimano derailleur design flaw
Quoted: 18377 Post(s)
Liked 4,512 Times
So you might want to consider saving some money to upgrade. Some good quality fatbikes show up from time to time, used, on my local Craigslist. In the meantime, you will certainly learn a lot from continuing to ride the one you have, and fixing stuff when it breaks, if you plan on fixing it yourself. I had a '65 VW bug that was like that. I learned more about auto mechanics, driving that car, than any other one I've owned.
The Roadies out there tend to drop the fat bike riders (except the fat e-bikes) mighty quickly on pavement.
If this bike was part of diet and exercise, and he is meeting those goals, then there are a wide range of bikes out there that may also meet the needs including FAT bikes, MTBs, Cyclocross, Gravel, Touring, Cargo, and Road bikes, depending in part on what kind of roads and trails are the preferred destination.
Quoted: 1944 Post(s)
Liked 2,164 Times
Since the the premise of this thread is a derailleur design flaw, contact Shimano and point out that flaw in their design. I’m sure there are people in their engineering department who would be more than happy to hear from you.
Obviously you had hoped for more support here, or you wouldn’t have started this thread.
John
John
Likes For 70sSanO:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Do we have the OP's derailleur model?
I'm not one to claim that Shimano Tourney (TZ30/TZ31) represents the pinnacle of Shimano engineering.
There is a reason that TDF riders tend to choose Shimano Dura Ace over Tourney.
Even competitive MTB riders will choose XTR over Tourney.
The OP's failure was odd, likely due to a number of things. For example, older style chains had much more prominent pins, while new chains (9,10,11,12s) have flatter pins. No bushings in the jockey wheels. And, potentially a lot of flex in whole system.
My guess is the typical kid's bike gets maybe 500 miles tops. And, perhaps gets passed down once or so before getting junked. In fact, there may be a level of planned obsolescence in them.
An adult that is heavily into exercise or commuting riding could put thousands of miles a year on the bike, and can easily exceed the expectations of the average Walmart Special within a matter of months.
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1948 Post(s)
Liked 1,470 Times
But it is true. He said:
A smart approach would be to say, check the dropout/derailleur mounting tab is not bent, or else the problem might recur.
Anyone with minor mechanical ability could look at it themself, and see if it is straight or bent.
Maybe he needs to take his bike to a mechanic, but many others have mechanical skills to do this themselves.
It has never happened before, and not something I ever expected, so not something I investigated in detail. Now that it has happened, It is something I will be conscious of, and check.
I had someone recently tell me I should learn how to patch a tube. I suggest that most people on this forum know how to patch a tube. I believe it is really bad on their part to imply that others are stupid.
I am not saying this because of myself. I believe those that imply that others are stupid, will continue to upset people, and display their own stupidity. I am trying to help him.
I know that some come on this forum, and say things that indicate that they have little mechanical understanding. But most people on this have a reasonable understanding of mechanics.
Having very little information (see above) to go by, Trakhak posits a potential issue that -- in hindsight, based on your alleged level of mechanical abilities -- seems obvious, even though you also stated that you had not looked in detail at that issue because it had never happened before and thus was not something you expected. So, perhaps not really that obvious, certainly not so obvious as to cause immediate offence or to be construed as calling you stupid.
I humbly venture that responding with such a suggestion is also obviously expected given all the unknowns, but then again, I am not overly sensitive.
Or should we all adopt the Japanese way of conversing in the passive voice with no pronouns lest someone gets offended?
Liked 4,512 Times
Pro racers don't 'choose' anything. They ride what's on the bike that the mechanic gives them. That decision is made much higher up the chain of command and at the Pro Tour or World Cup mtb level is obviously going to be the top of the line so there really isn't a decision to be made.
Wider the better for tires, right? That is what I keep reading here.
No doubt companies make more money selling Walmart FAT bikes than selling $10,000 road (or MTBs), so wouldn't it be better to use what they are selling....
Except they also want to win, not show a bunch of riders left in the dust.
Quoted: 6963 Post(s)
Liked 10,964 Times
The OP‘s theory is defective – not the derailer.
Likes For Koyote:
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
Agree that these are the most likely causes. And if the hanger wasn't bent before the incident, it almost certainly is now. OP should check hanger alignment before installing a new derailleur.
Likes For JohnDThompson:
Liked 1,470 Times
Likes For SoSmellyAir:
Quoted: 529 Post(s)
Liked 255 Times
...just to reiterate, your original description of your bicycle indicates that it might be a bargain fatbike. The least expensive ones are not designed with robust adventure in mind, as far as durability of the components. To some extent, these bicycles are designed for different levels of use, all the way from just riding on the street, to full on downhill, go anywhere bikes. the fact that it has fat tyres and wheels does not, in and of itself, guarantee any sort of off road use durability or life expectancy.
The bike is an X-treme 26 inch fat bike.
The X-treme bikes I have seen on the internet are electric. The X-treme bikes they sell here are ordinary pedal bikes.
It has a strong frame, which will probably never break. With what I have done with it, I am amazed I haven't broken spokes. So the bike is tough. I have ridden thousands of kilometers on very rough tracks.
Replacement parts are very cheap here, so repairing it is not a problem financially. The problem is if something breaks when I am somewhere far away, and the inconvenience.
I don't believe there are any better quality fat bikes for sale here.
If there was, an expensive bike may break as often.
Some people look after their bike, by avoiding the worst places. I don't avoid going anywhere. If it breaks it can be repaired. Replacing the entire bike is also cheap here.
Quoted: 529 Post(s)
Liked 255 Times
Prior to it happening, it did not look bent or out of alignment, and worked fine, but something was obviously not right for this to happen.
Old fart
Liked 3,400 Times
Liked 1,470 Times
I am aware of the distinction between stupidity and ignorance; I was facetiously referencing a similar suggestion by Trakhak (to check the rear derailleur mounting tab), which the OP construed as Trakhak calling the OP stupid.
1) A failure in an instance of a device does not mean the device was poorly designed.
2) Clearly something was going wrong with the drive train, but alo kept riding instead of diagnosing and resolving the problem. Then the derailleur went into the spokes. That means the derailleur was damaged beyond repair, but it doesn't mean the der itself failed, and if it did fail, it doesn't mean that alo figured out the source of the failure.
3) Alo thinks he can evaluate the hanger without a mechanic's help. That's up to him, as was continuing to ride when he knew his drive train was not operating as expected. But no one knows everything, and sometimes specific knowledge is a hell of a lot more important than intelligence. I'd want a 2nd opinion on something like this myself, but I think lots of people would make a different choice.
4) Many years ago, a reporter for a certain magazine listed the 10 dumbest members of the US Congress. The person identified as the dumbest called a press conference to announce that he wasn't the stupidest boss. He did not get a positive reception. The moral I drew from that story is that declaring oneself to be smart isn't smart. Show, don't tell.
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Did I miss the part where the OP said what rear derailleur he had?
Quoted: 645 Post(s)
Liked 797 Times
Try to a little less of a dick to people giving you advice when you came looking for advice 👍
Quoted: 194 Post(s)
Liked 204 Times
It is impossible to know for sure, and the derailleur is totally destroyed, so it cannot be reproduced. But I think it was most likely the leading edge of a link that caught on the derailleur.
I wish you luck with the bike.
Quoted: 1104 Post(s)
Liked 1,825 Times
I'm a Campagnolo man right down to my tattoo. But it's pretty hard for me to believe a Shimano RD killed itself because of "design flaw". Truth be told, if it weren't for Shimano, Campy would still be selling old NR/SR rear derailleurs with pulleys that cracked.
Likes For nomadmax:
Quoted: 529 Post(s)
Liked 255 Times
Maybe I was wrong. Maybe a lot of people on this forum don't have a good understanding of mechanics, and need to take their bike to a mechanic when something goes wrong.
Quoted: 241 Post(s)
Liked 454 Times
I had the chain on the large front sprocket, and the middle freewheel sprocket. The chain was a bit too loose, and would jump teeth on the freewheel when going up steep hills, or trying to accelerate quickly.
However, after a few hours of riding, it changed by itself down a gear, to the next largest sprocket. The chain was too tight, and there was too much resistance while peddling. I was concerned about bending the axle, but it didn't seem to. If I continued riding this, it would wear quite rapidly, and loosen up. But the gear is too low, and I finish up riding too slow.
I have been losing weight. The gear I am in now, would have been good last year, before I lost the weight. But my bike goes faster now.
So I plan to fit another derailleur and chain.
When has the bike been serviced? You say you've been riding the bike for 2 years. Has the chain and cassette/freewheel been checked for wear and stretch?
You say the chain was a bit loose and would jump teeth...this is a possible sign of a stretched chain and possibly worn cassette/freewheel. The chain will skip over the teeth as it tries to bite the gears. The springs in the rear derailleur do their best to keep tension on the chain to prevent 'chain wrap' but a stretched chain, worn gears, bent rear der. hanger and an inexpensive rear der. whose spring has lost some of its' strength are a combination recipe for disaster. There is also the possibility that a stretched rear der. cable, out of adjustment due to stretch over time and not checked and adjusted periodically could be a contributor to the problem.
My suggestion: Bring bike to LBS...explain what happened...A good shop with check chain stretch, gear wear, hanger alignment, cable stretch/rear der. adjustment, etc.
The limit screws and "B"/chain wrap adjustment on the rear der. should not have 'moved' on their own accord...they just don't move...but the limit screws won't do their job if the rear der. hanger is bent.
Sounds more like the rear der. springs were under load, tried to do their job then failed to do so and chain wrap with damaged parts is the result.
If you want good info, suggestions, advice you need to tell us the name of the bike, model of the der., etc. otherwise we are just guessing.
Good luck.
Expired Member
Quoted: 3674 Post(s)
Liked 5,433 Times
. From another thread, this is your bike but it doesn't seem to have fat tires. Is there another bike? Maybe post a pic.
Quoted: 529 Post(s)
Liked 255 Times
I've a few questions and some suggestions.
Good luck.
Good luck.
After the derailleur failed, I had the chain shortened, so it became a single speed, and I could ride home.
Then somebody suggested.
If this is a genuine misunderstanding, go back and read previous posts.
If you are intentionally misquoting, don't waste your time.
You can also read previous posts for the make of the bike and the model of the derailleur.
Quoted: 529 Post(s)
Liked 255 Times
I like to treat people like they are intelligent, unless they say or do something which indicates they are not.
None of us know it all. That is what forums are for. To share ideas with others, so we can all learn.
