The Magic Gear Thread: "We don't need no stinkin' track ends!"
Quoted: 2952 Post(s)
Liked 3,106 Times
Have you converted a vertical dropout bike to fixed or single speed without an eccentric hub or bottom bracket? Post it here.
How did you do it? Did you use Eric House's magic gear calculator? Did you use a half-link? Futz with various chainrings and cogs? Invoke some bad juju? Light a candle to Our Lady of Ghisallo?
Why did you do it? Are you a mechanical genius? Are you a cheap bastard? Did you just have too many spare parts cluttering your garage? Was it a drunken dare? Or just for the heck of it?
And pictures if you've got 'em. I know you do.
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
I did it on an 97 stumpjumper MTB frame. Found it by luck, 44x16 worked perfectly. Fixed on a MTB is a blast...you can trackstand for days.
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
THIS SPACE FOR RENT
This shizz is mostly caused by people not wanting to file a frame. Filed frame + ground axle gets you in half link range pretty easily. I'll never get why people reeely reeely want some bike to be their fixed gear but don't want to actually commit to it. Get some old steel rig and center your chi on that first if you don't want to go all the way.
Bravo to people that nail it via gear futzing, though. We should put together a spreadsheet of frames and combos that work.
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
There is an online calc somewhere (it's in my fav's at home). You just need to measure your chainstay and it will pump out compatible gears. Cool stuff. I'll post it later.
Liked 3,106 Times
Do you mean this one? https://eehouse.org/fixin/
Likes For caloso:
i have a 94 gt pantera 42 16. it was tight till the chain stretched. its my winter bike who cares
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
Yup...that's the one. Glad I could help
dances with bicycle
There is this amazing guy Greg in SF who has a custom built Eisentrout specifically designed with vertical drops in order to "get all the extraneous crap off the bike". He knows his gear and only rides that so he had the frame built accordingly. If you have a copy of Short Bike Rides San Francisco he is the guy with the fix to be seen on two photographs.
It seems to be mostly a matter of luck and patience. The right combo of links, ring, cog and chainstay can do it, the hardest part is putting it together wrong and being honest to the fact that it too slack or too tight and that you will have to do it all over again. Too tight is better as it won't kill you, just use more oil.
Lapped 3x
Originally Posted by jamey
and destroy your drivetrain quicker.
Liked 3,106 Times
Originally Posted by taras0000
and slow you down and snap chains
live free or die trying
Bikes: bianchi pista workhorse, cannondale r1000, mountain bike fixed conversion
yep. pretty much.
Bikes: DW
how is a track end extraneous?
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
With vert dropouts tension will never be an issue. One less thing to think about. I'm assuming that is what he is talking about. Myself...I like options.
Bikes: '05 Lemond Fillmore, '05 Surly 1x1, '04 Fuji Track Pro, '02 Specialized Stumpjumper, '92 GT Tequesta
One thing that helps in using a "magic ratio" is to use a chain that already has some use so it doesn't stretch losing your tension.
dances with bicycle
He is older than the average fixed rider and will do backwards figure eights around two posts while tying his shoes and ranting on the sprinter mentality, Lance, Trek, drop bars, etc.
He is a damn fine rider so if it works for him I am not going to argue.
Personally I see trackends being about as extraneous as paint, then again if you have been riding for 30+ years you probably know if you like trackends or not on your fix.
His dropouts actually have about 2 mm of back and forward adjustabiliy. The axle is all the way in the front when the chain is new and once it have been worn it it gets pull back 2 mm. "That is all that is necessary! If you need more your chain sucks!"
information sponge
Bikes: Lots. Mostly steel. Mostly heavy. Mostly geared, and very low, at that.
I had a bike like that for a while. When I decided to replace my chain, I couldn't. My magic gearing was too magic or something. My chain continued to get worse until I ended up getting rid of that shizzie.
Buy an ENO.
End of story.
Buy an ENO.
End of story.
Philosophy and feelings don't change the laws of physics
celeste color of heaven?
I took a 1990 Bianchi campione with vertical dropouts and turned it into a fixed gear. The only thing I actually bought were spacers, and a rear sprocket. I used halflinks to get the right chain tension and I had to move the chainring a little bit closer to the frame. Besides the fact that a little bit of the chainring sometimes scrapes the frame due to torquing during rides, everything is nice. ppl look because they don't usually see a celeste colored bianchi campione as a ss :]
Bikes: redline, gary fisher, cannondale, BT Trials
wonder how many broken chains there are doing it the magic way compared to using a tensioner/ebb/eh/etc.. because i know everytime ive done that, the chain would break after not too long, or maybe im a lot harder on my drivetrain than most people
72 & Sunny
Bikes: '93 Yamaguchi Pursuit track bike, Alan Super Record
That's happened to me before...but then again I was running the same chain that was on the bike when I bought it used. Since I've replaced with KMS chain, there's like a tiny bit of slack and I don't run a tensioner and it's fine.
