PowerTap calibration question
Bikes: Bianchi Veloce and a custom-made Commonwealth (Medford, MA)
Quoted: 22 Post(s)
Hi -
I have my PowerTap paired with a Garmin Edge 510. I always calibrate it before I start my rides and when I stop and the Garmin shuts off. The calibration readings are usually in the mid 500s. Today, it was in the 300s throughout. I also noticed that my power readings were lower than I would have expected, although not by a ratio of the two readings.
Generally speaking, what is the cause and effect of such an unusual calibration? I don't understand this process at all well.
Thanks
Thanks
Roadie
Unfortunately a calibration in the 300s means your Powertap has to be sent in to be replaced by Saris, most likely a damaged torque tube.
Quoted: 550 Post(s)
Liked 325 Times
Quoted: 22 Post(s)
Hi - I have a dreary update to this and - again - perhaps someone can shed a flashlight on this for me.
I contacted Saris through email and have gotten an interminable run-around. First, the guy told me to download PowerAgent and update the firmware, without telling me how this is done. He also told me that my unit should calibrate at 515, which I can assure you it never did (usually it did around 550). Then he told me to send a picture of the unit (again, this is a G3), which I found odd. I opened the unit and sent a picture of the hub, but he replied that he needed a picture of the cap itself.
Now, I'm not an expert on power meters by any stretch of the imagination, but I find it odd that the manufacturer needs me to send it pictures of my unit.
Can anyone gently educate me?
Quoted: 550 Post(s)
Liked 325 Times
They've made multiple versions and the tech support guy wants to see what you have in case there was a recall, it's under warranty, it's a version with a common fault....
noeldlt
Bicycle Mechanics
4
10-03-12 02:33 PM
babyboomer
1
09-22-12 02:56 PM
Elvo
Road Cycling
8
06-20-11 07:06 PM
