Which 10spd road shifter?
I've read that I can use a 10spd Shimano road shifter to operate a 9spd rapid rise rear derailleur. Is the Tiagra flat-bar shifter the one I'm looking? Or if there are others, which would be best for a mountain bike?
Liked 732 Times
What's the point of this? Is it that you can't find new 9spd MTB shifters?
Perhaps a ShiftMate could solve that. Or you could buy second hand.
Wookie Jesus inspires me.
OP, what do you mean by "road shifter"? Are you talking about STI shifters? Just get a 9 speed, it will work perfectly and there are plenty of second-hand, cheap pieces around.
Liked 732 Times
Also, if you do go the ShiftMate with a 10spd shifter, it might be better to fit it near the shifter rather than the derailleur, in order maximise signal-to-noise in the system; the cable pull per 10spd shift is pretty damn small.
Of course, you'd miss out on the removal of a bit of friction from the RD loop the ShiftMate provides, and it'd look a bit weird, so try it the normal way first.
Liked 732 Times
Then I'd say just get a 10spd MTB shifter and ditch the Rapid Rise RD.
I have a feeling the cable pull increments aren't exactly linear, so a backwards derailleur sounds like a headache.
Liked 1,102 Times
Shouldn't be necessary. I'm using a Shiftmate to allow Campy brifters to shift a 10-speed Shimano rd and cassette and it works perfectly mounted at the rear derailleur.
Liked 732 Times
But if it didn't hold its tune, that'd be something to try.
Anyway, I think the Campy brifters pull more cable per click than Shimano, no?
Guest
Bikes: I never learned to ride a bike. It is my deepest shame.
Liked 6 Times
Rapid rise derailleurs will work perfectly in any application where non rapid-rise will work, IME. Meaning, the rapidrise 9 speed should work with the 10 speed flat bar road shifters.
I don't know about the front derailleurs, though.
