How do I know if these are tubeless ready wheels?
I know they are listed as tubeless ready on website, but not sure if they were in 2019 or not.
Bikes: 2001 Tommasini Sintesi w/ Campagnolo Daytona 10 Speed
Quoted: 145 Post(s)
Liked 35 Times
Technically, all modern day rims are tubeless ready.
You can take pretty much any clincher rim and convert it to tubeless. It's all about proper installation of the right kind of tape and sealant and stem.
Tires however....
=8-|
Tires however....
=8-|
5000+ wheels built since 1984...
Disclaimer:
1. I do not claim to be an expert in bicycle mechanics despite my experience.
2. I like anyone will comment in other areas.
3. I do not own the preexisting concepts of DISH and ERD.
4. I will provide information as I always have to others that I believe will help them protect themselves from unscrupulous mechanics.
5. My all time favorite book is:
Kahane, Howard. Logic and Contemporary Rhetoric: The Use of Reason in Everyday Life
Disclaimer:
Likes For mrrabbit:
Advocatus Diaboli
Quoted: 4737 Post(s)
Liked 1,533 Times
oh boy..
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
I don’t know much about them, but I assumed there was.
Quoted: 514 Post(s)
Liked 450 Times
The lesson is, if you don't know for sure, tape the rim. Tubes don't care what kind of a rim strip you're using. Install the valve. Mount the tubeless-compatible tire. If the beads lock and the tire holds some air, you're ready to try it with sealant. If not, use a tube.
Obsessed with Eddington
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times
Post above yours is the answer....if the rim is not explicitly stated as "tubeless ready." Better option is uses a tubeless compatible rim (explicitly stated so by the manufacturer) if one has a hankering to be tubeless.
Likes For Badger6:
Bikes: yes
Quoted: 1281 Post(s)
Liked 643 Times
In the wild west days before lots of manufactures started making tubeless-specific rims it was basically a coin toss as to whether you could make a rim tubeless or not -- some rim/tire combos really worked well, some didn't. So trying to go tubeless on a rim that is not specifically designated as such is not really that outlandish, it's been done a bunch.
Of course there's no reason to now since everyone makes tubeless rims.
OPs rims look like modern Velocity A23s which are, in fact, tubeless.
Likes For ksryder:
Quoted: 532 Post(s)
Liked 621 Times
It's definitely not outlandish, but having a process for getting the beads to seat is the best insurance against dumping sealant in a tire that won't seat, and then you've got a mess. In fact, to this day, even on rims and tires that are tubeless ready, I still seat the beads first....then put the sealant in. Habits.
Likes For Badger6:
Quoted: 514 Post(s)
Liked 450 Times
Now I've heard of "ghetto tubeless," riders and mechanics actually successfully mounting tubless tires tubeless on non-tubeless rims. But that's with varying levels of success and reliability. Personally and professionally, I have more important things to do than spend hours trying to get equipment to do something it wasn't designed to do.
But yeah, if your A23s aren't branded tubeless ready, TLR, 2Bliss, or whatever, don't count on them working tubeless. Trust me, if a component is tubeless ready. the manufacturer will brag about it quite loudly.
Senior member
Quoted: 943 Post(s)
Liked 658 Times
Absolutely.
Likes For Dan Burkhart:
