Patching tires - help
So patch #293 is ready to be applied, but I have a few questions for the experts before I go about this.
1) I always patched it on an empty tube, in fear of the air escaping the hole and causing a bubble in my patch as the glue dried. But because of this, when the tube is pumped back up, the patch restricted the surrounding rubber to fully inflate. The tube was always slightly deformed. Is that an error on my part? Should I be patching an inflated tube instead?
2) The poorly written instructions say to apply the glue and then the patch.
But isn't this contact cement? Shouldn't I be waiting for the glue to dry, before applying the patch?
3) Stick on patches vs the glue-on ones. I found stickies for the first time and they are woooooonderful, so much easier to apply, especially on the trail. But over the course of the summer, they sort of came undone. I was sure to sand + clean the rubber before applying, but maybe it's just the brand that I used that was poor. Or maybe because I patched a deflated tire. Are those stickers meant to be permanent patches, or temporary?
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
Continue to patch empty tubes. When the patched tube is reinflated inside the tire it doesn't matter that it looked deformed.
For a traditional patch kit, it's neither contact cement nor glue - it's vulcanizing fluid. Put it on the tube and wait for it to dry before applying the patch.
Stick on patches are supposed to be permanent - but many delayed failures have been reported. Hasn't happened to me, but I haven't used many.
Deformation of the tube is normal. It doesn't matter, because in use it is the tyre, rathe than the tube's elasticity, that is the limiting factor.
Apply the rubber solution to the tube. Stick on the patch when it is almost dry but still slightly tacky
The instant patches are what might be called semi-permanent. When I have used them they have failed at between one and two years.
Quoted: 1572 Post(s)
Liked 643 Times
I collect my punctured tubes in a box in my workshop and patch them all at one time when it's convenient. I use vulcanizing fluid patches and clamp the patches with a c-clamp and a couple pieces of wood as they dry or cure or whatever the right word is. I can't remember ever having had a patch fail.
Quoted: 3352 Post(s)
Liked 1,056 Times
I have used glueless patches for years. I inflate the tube to approx the size of the tire, and apply the patch. I then press the patch down with my thumbs for several seconds, and then release the air. Using this method prevents stress on the patch when the tube is put in the tire and inflated. I feel this is why I have had such good luck with glueless patches. I use Park glueless patches, and some have lasted 2 years or more.
Traditional patches take five minutes to apply and are permanent, they'll last as long as the tube.
Old Fart
Bikes: '97 Klein Quantum '16 Gravity Knockout
Quoted: 163 Post(s)
Apply patch to fully deflated tube when vulcanizing fluid is almost dry(still tacky)...clamp tightly between fingers for a little while.
I've been patching tubes since i was 8 years old (45 years, now) and this has always worked so well. The patches are truly permanent- to the point where I've had tubes that had more patches than original tube material and they'd last for eons- I'd always end up throwing the tube out just because it had too many patches...never because a patch let go. (Now I use Gatorskin tires and don't get flats- so I can run nice virgin tubes!)
I've been slowly upgrading all my tubes to "thorn proof" type. Over the past three years or so. Have had no problems since. Knock on wood. It's a sacrifice. Thorn proof tubes are heavy & expensive. And, you have to get just the right size. YRMV. Be good, have fun.
Quoted: 258 Post(s)
I carry glueless. They'll get me home. If I intend to keep using the tube I'll replace them with glued patches before long.
To those that have used stickon patches with success: we're these on skinny road tires running pressure of 90+ psi?
Quoted: 4560 Post(s)
Liked 2,802 Times
I inflate the tube until it takes shape and has slight resistance to compression. Then I'll apply the glue, wait for it to dry (takes less than a minute), then apply the patch. If the tube deflates and is limp by the time the glue dries, I'll pump a little more air.
So far, so good. I've done this with dozens of patches umpteen years ago, and more recently with the one flat I've had since resuming cycling a month ago.
No idea whether this is correct. I just find it easier to handle the tube, tire and rim when the tube is very slightly inflated. Easier to be sure it's not kinked inside the tire.
Old Fart
Quoted: 163 Post(s)
I bought a set of those when I first started riding. When they arrived and I realized how heavy they were, I never even took them out of the box! They weigh more than a good puncture-resistant tire...a lot more!
I used them once on a 700x28 tube at 90psi and they sucked. Didn't hold pressure for more than a day. Given that regular patches really aren't that difficult to apply, I don't see the point of the stick on ones.
^ I've had the same experience. High pressure tires just blow the stickon patches out. I've had great luck with them on my MTB and my tourer at pressures no higher than about 65 psi.
Yes, they are very heavy. But, to be fair they don't really weigh that much more than a good tire. Especially if you're using the 23 - 25mm sizes. And, for fitness riding they're hard to beat.
Quoted: 150 Post(s)
i inflate, let some air out untill the pressure is low enough to hold the tire in shape but not bubble the glue, patch it, put something heavy on it do hold in place and grab next tire i need to patch..
Bikes: 2020 Masi Giramondo 700c; 2013 Lynskey Peloton; 1992 Giant Rincon; 1989 Dawes needs parts; 1985 Trek 660; 1985 Fuji Club; 1984 Schwinn Voyager; 1984 Miyata 612; 1977 Raleigh Competition GS
Quoted: 1126 Post(s)
Liked 253 Times
You have all the main answers so let me address the clueless patches because there is some controversy with those.
All I have used in the last 20 years or so are glueless patches and I only had 2 maybe 3 failures in all that time. One failure was from the tube getting wet accidently, the others were from poor quality brands of patches, but if I use Specialized Fatboys or Park brand I never have a failure. And I DON'T go home and peel off the patch and put a glue on patch on, nor do I throw away the tube! If the tube is prepared correctly a glueless patch will last the life of the tube, I've had tubes with as many as 13 glueless patches that were 7 to 8 years old and they all were still holding and they were my main tubes I rode on. I like these so much I never went back to glue on patches in those 20 some odd years. My commuter bike has two on the front tire right now and I think nothing of it riding the bike with those on. I even have a spare tube in my seat back with two glueless patches on it and the tube still holds air just fine.
Reason most people don't like them is that they fail to prepare the tube correctly, with glue on patches you can make an error in the preparation process and you might get away with, not so with glueless. Lot of people also really don't know how to patch a tube with glue on patches, they hide the fact for not knowing by saying they just buy new tubes every time they get a puncture, fine, but that's a huge waste of money.
Preparing the tube is the same as a glue on, you have to use the enclosed buffer to buff the tube an area slightly larger than the patch will cover, you then peel the patch off making sure you touch the smallest area possible (usually I peel if with a fingernail from the corner and it hangs on my nail and then I place it so it's centered over the hole). Next you have to press it between your thumbs and your fingers (making a sandwich with the tube and patch in the middle) as hard as you can for 30 seconds, then look at the patch, if you see any frosty areas (lighter shaded areas) you have to repress those areas; I usually repress the corners just for precaution whether or not their frosty. Now the tube is ready to go.
I told a friend about these once, and he tried using one when I wasn't there and called me up to swear at me! So I went to his house and patched the same tube with his patches and showed him how to do it as I went. After that he never has had a failure and he's been using them now for about 4 or so years.
I'm not sure how long the self sticky stuff lasts in storage, just for peace of mind I replace any left over patches that are over a year old, their cheap so it's no big deal to do that.
The original tube of adhesive was all dry. So I'm using store-bought rubber cement. Hope it works.
I have a cut out old inner tube+contact cement patch on for the last 3 years and always have it inflated to 75 psi which is its max with no issues.The trick is to have a smoothest thinnest layer of cement on both patch and tube area and it should be properly sanded b4 ,If these 2 steps are followed properly then you should have no issue and the tube lasts as good as new.
Liked 253 Times
1/2 as far in 2x the time
Bikes: Yes, Please.
Quoted: 499 Post(s)
Liked 285 Times
+1 Sometimes I got cuts at the valve stem when we rode our coaster brakes with lower pressure down hiking trails. Otherwise patch and forget.
Old Fart
Quoted: 163 Post(s)
It might hoild temporarily- but rubber cement is not the same (and not as adhesive) as vulcanizing fluid. I used to think they were the same- they sure seem similar- but they're not the same. You can get real cheap tubes of vulcanizing fluid on Ebay- or antire li'l patch kit for around a buck- order a bunch of 'em just for the tubes of fluid....throw away the patches if they're not suitable. (Glad this came up- I always check my tube of fluid which resides in my saddle bag every7 few months...and it's about time, and I'd forgotten! I replace it every year, whether it needs to be replaced or not)
rpenmanparker
Road Cycling
101
08-11-22 06:29 AM
mattkime
Bicycle Mechanics
30
09-24-10 12:47 PM
