Can anyone identify this frame?
Senior member
Quoted: 943 Post(s)
Liked 658 Times
MTB frame with canti posts and rear cable hanger. 9 digit serial number with a gap after the first 5 digits. A lone S stamped above the sn.
Seat post pinch lugs on the front of the seat tube.
Sn# 19401 0837
Sn# 19401 0837
Hoards Thumbshifters
Bikes: '23 Black Mtn MC, '87 Bruce Gordon Chinook, '08 Jamis Aurora, '86 Trek 560, '97 Mongoose Rockadile, & '91 Trek 750
Quoted: 246 Post(s)
Liked 335 Times
92-Mid 90's Univega mtb
Look up Alpina 5.3 to 5.7 from '94.
Likes For mechanicmatt:
Senior member
Quoted: 943 Post(s)
Liked 658 Times
Doing some more searching, and looking closer, the Alpina 5.7 models I'm finding have some subtle differences from my frame. This example shows the top of the seat tube cut at an angle whereas mine is cut square.
The cable stops are mounted higher on the top tube on those I searched.
Also, the chain stays appear to sweep up a few inches behind the bottom bracket whereas mine are straight.
Examples below of images I found on line.
Quoted: 246 Post(s)
Liked 335 Times
'95 Alpina 502? Look at different examples through the years. '97 is when v brakes start taking over so the cantilever bridge may only be on lower end models around then.
