Dahon Speed D8 vs Dahon Boardwalk D8
Bikes: Dahon Boardwalk D8
Quoted: 45 Post(s)
Hey,
I did a search on the forums and couldn't find anything on comparing these two. It seems that they are almost identical. They're both CroMo frames, 8 speed. The Boardwalk has Altus, the Speed has Alvio (though I'm not sure what difference that makes.
Overall for touring, could they be considered the same?
Thanks!
Thanks!
I like the retro-ish looks to the Boardwalk, but that is brother here or there for touring suitability...Alivio vs. Altus, hmmm, neither is particularly top of its class, but might do just fine. Tiagra/Deore is as mid-range as I petsonally like to go. Do both bikes have the luggage block on the headtube? it is useful for mounting a Kanga rack for touring. look at the gearing too. this is important for touring. Generally you want to be able to spin rather than mash up hills to conserve your legs...
Quoted: 45 Post(s)
Sorry to be ignorant about this, but what specifically should I look at? I'll post the info here. I could always see if I could replace the gearing if necessary. I toured on the D8 and was happy with the hills in Malaysia and Taiwan, so if they're the same then no worries.
Quoted: 45 Post(s)
For the Boardwalk D8, crank is 48T and cassette 11-32T. I'm a newbie at the terminology but this seems to indicate a wide range for touring and decent ability on hills. What do you think? Did I miss some info?
I run a 47T crankset with 11-36T cogset for 26-83 gear-inches. In essence you and I have the same top end, but I've got an additional gear at the bottom. Whereas you are done once you shift to the 32T cog, I can go from 32T to 36T. I actually wish for a lower bottom end, but 47T x 11-36T on 406 wheels is probably a good Goldie Locks touring range that avoids the increasing complexity and weight of double chainring drivetrains and of wider-range cogsets that require a longer and heavier RD.
Quoted: 45 Post(s)
But first thing is first: how did you do the math to come up with 29-84 based on the numbers I gave you?
Gear-inches = Chainring T / Cog T * Wheel Diameter
I aasumed Wheel Diameter to be 19.5". That's what I have, corresponding to a 42mm wide (nominal) tire.
Yeah well this is why I'm trying not to eat so many cookies these days. At least I can cut out some fat! Otherwise I'm looking to be biking at 80kg and carrying about 10kg of stuff. The last time I did this I was 83kg and carried 7kg so it was the same difference -- that was on a Speed D8 though. But again, I can't see the difference in the two bikes.
Quoted: 45 Post(s)
Now there is a place offering a custom D8 with a FSA 55T chainwheel, but a friend of mine points out this wouldn't work out so well on hills. I believe he called it "overkill". What do you guys think?
i already told you what i think. Going for a 55T chainwheel runs counter to my advice about gearing for touring, giving useless gears at the expense of useful ones.
Quoted: 45 Post(s)
This math is not my strong point. But I guess I get the idea: more teeth on the chainwheel results in lower ability to handle hills.
as i said before, your gearing now is not bad, it's quite decent, but it could be a bit better. however, the marginal gain from swapping to a 11-36T cogset is likely not worth the trouble and expense (a switch to 9- or 10-speed).
There are hacks to get a 36T cog on an 8-speed cogset, but these are a bit complicated.
55+ Club,...
Bikes: 9+,...
Quoted: 1117 Post(s)
Liked 852 Times
How about a Dahon Mu N360: Dahon MU N 360
**thusi*st
Consider the Hinge. I like the retro look of a Boardwalk. That said I am worried about my 95-100 kg.
Speed is a great bike. Not only a good gear set it has:
Quick Release Skewer/Axle System
Sealed Hubs
Sealed BB
Nice Crank Set
I don't know about the Boardwalk D8. It might be the same, but not avail in USA>
I think the Boardwalk Hinge though is worth evaluating no matter in contrast.
Good luck.
Sealed Hubs
Sealed BB
Nice Crank Set
Good luck.
Quoted: 45 Post(s)
HI guys,
Thanks for the advice. I have now two offers I'm trying to decide between. I'd appreciate some help. There's a 230 Euro difference between the two and I'm not sure if the money is worth it. I'll also need to get some other stuff for touring such as a saddle, bar ends, and other things I have on my mind. So part of me is thinking I could "save" then 230 to spend on that. Not sure. Again, this is for a 1600km tour. Here are the choices:
Dahon Speed D8 Custom Build (From CH White)
ChroMo Frame
36 spoke q-release wheels
Shimano Claris Gear mech and Shimano twin lever shifter
Schwalbe Marathon Racer Tyres
FSA 55T chainwheel (but can be swapped to a 48T on request at no extra charge)
Total Price with shipping: 732 Euro
Dahon Boardwalk D8 (From TopCycles)
CroMo Frame
Dahon Neos 8
28 Spoke Stock Wheels
Kenda Kwest Tires
11-32T Cassette
Total Price with Shipping: 498 Euro
ChroMo Frame
CroMo Frame
Dahon Neos 8
Kenda Kwest Tires
11-32T Cassette
HI guys,
ChroMo Frame
CroMo Frame
Dahon Neos 8
Kenda Kwest Tires
11-32T Cassette
ChroMo Frame
CroMo Frame
Dahon Neos 8
Kenda Kwest Tires
11-32T Cassette
Neos RD - does this not mean a proprietary/no dereilleur hanger? if so, it is to be avoided.
36-spoke wheels - overkill on 406 size rims. is it that they had a bmx jumps and tricks wheelset that they reassigned to a folder? 28 spokes is more than good enough.
