Blackburn HP pump with non-Schrader valves?
Has anyone here experience with the Blackburn HP pump and different kinds of valves?
I´m considering buying this pump for my home workshop, but it seems that the pump head is very Schrader-valve specific. Will it work well (with adapters or such) with other kinds of valves?
Quoted: 2026 Post(s)
Liked 1,096 Times
I just looked at the Blackburn web site and they show the HP floor pump as having a Presta-specific head, not Schrader at all. There are adapters to allow a Presta pump head to work on Schrader valves but they aren't nearly as common as the other way around.
Many other brands of floor pumps come with a dual-head that works on either Presta or Schrader valves with no adapters needed.
Of course, I mixed up the names. I´m pretty sure I can find the adapter.
Any idea how well it will work - will I be able to use the full range of pressure, the pump can deliver?
Liked 1,096 Times
The adapters do work and will allow the full range of pump pressure although I don't know why you want to be able to fill a Schrader valve tube to 200 psi.
Be sure to get the correct adapter. Schrader pump to presta valve adapters are everywhere, usually for $1.50 or less, since they allow presta tubes to be inflated with car or gas station pumps in an emergency. The adapter you want is a lot more unusual and more expensive. Here is one source I was able to find:
https://www.jensonusa.com/store/produ...0+Adapter.aspx
Thank you for your answer, again. Last time I picked up a Schrader-to-auto valve adapter at my local bike shop, I noticed that he had at least three other kinds of adapters in the drawer, so I expect that he has this one as well.
I just noticed, though, when checking out the Blackburn pumps at another dealer than the one I had visited first, that the Air Tower 4 model apparently comes with a Schrader+Presta head (two holes), and the same pressurizing capability.
Yes, I know that I would probably not be needing 11 bar pressurizing capability every day, but I believe that this parameter tells a lot about the expected gasket life-time and construction sturdiness of the pump.
