Flip it or take out spacers?
unwilling rashtafarian
This is my 2011 S2
I want to lower the bars, so far I have moved 1cm spacer to the top of the stem, and I wanted to go a little lower. Should I flip the stem or move another spacer?
The steerer is uncut.
Thanks
T2
Thanks
T2
Artificial Member
Bikes: Retrospec Judd, Dahon Boardwalk, Specialized Langster
Quoted: 6778 Post(s)
Liked 5,490 Times
Move another spacer. Flipping it will have the opposite effect.
OMC
Bikes: Specialized Allez Sprint, Look 585, Specialized Allez Comp Race
Quoted: 461 Post(s)
Liked 116 Times
T2 - How long have you ridden it with the bars 1cm lower?
Regards,
Chuck
Demain, on roule!
Regards,
Chuck
Demain, on roule!
You do what it takes to get correct fit not for looks, why do so many people want to please others (flip it - slam it no mater what) rather that please themselves with with what makes you fit correctly on your bike?
It may not be fancy but it gets me were I need to go.
https://www.jtgraphics.net/cyclist_bicycles.htm
It's already "flipped". If you want lower, either remove another spacer or bend your elbows more.
Some sort of pithy irrelevant one-liner should go here.
Bikes: Kestrel RT900SL, 1975 Viner, Specialized StumpJumper
Do you have enough flexibility to go lower? Going lower will also extend the reach. It does appear there are too many spacers below the stem, put a few on top and see how it feels. Ride for a week or so on 50-100 rides and see how you feel. If you set up your bike to look pro but uncomfortable for you to ride, your bike becomes useless.
Bikes: Look 585
Quoted: 25 Post(s)
ka maté ka maté ka ora
Bikes: breezer venturi - red novo bosberg - red, pedal force cg1 - red, neuvation f-100 - da, devinci phantom - xt, miele piste - miche/campy, bianchi reparto corse sbx, concorde squadra tsx - da, miele team issue sl - ultegra
Quoted: 25 Post(s)
it's flipped, now slam that *****!
SLO-1
Bikes: '09 BMC Road Racer SL01
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,180 Times
That is a pretty old picture and the saddle is different now.
OMC
Quoted: 461 Post(s)
Liked 116 Times
That's sorta what I'm trying to figure out here. The bike fits me well and is great to ride, so I'm guessing the next steps for me to take is to lower the bars bit by bit until- um- well, I don't really know. I moved two 1cm spacers so far and haven't noticed a big difference in the feel or comfort of the bike. Should I keep going until my back hates me? Also should I lower the nose of the saddle a bit as I move spacers?
You've got 800 miles with the spacer out with no problems - cool! I'm guessing that's riding on the hoods. Have you tried riding in the drops for extended periods (>ten minutes), and if so, how did it turn out? If you're comfortable in the drops, you can either try going lower or just tack weld everything and call it good. If you're not comfortable in the drops for extended periods, you need to bump the bars back up until you are. It would suck having five miles' worth of headwind and not being able to use the drops the whole time.
Remember, this advice is worth exactly what you're paying for it.
Regards,
Chuck
Demain, on roule!
Regards,
Chuck
Demain, on roule!
Administrator
Liked 2,180 Times
I didnt see the OP saying any of that. Don't be overly sensitive where you read things that aren't there
If you want to go lower, remove another spacer, and think about having the steerer cut appropriately. Carbon steerers don't do well with too many spacers, on the bottom or on top!
Either way, killer looking Cervelo!
'11 Time NXR Instinct / '79 Paris Sport by Moulton
