Are Hookless compatible tires cheaper to produce?
Quoted: 1461 Post(s)
Liked 1,485 Times
Haven't ridden tubeless so no comment there. I would far rather flat a tubular in front than a clincher. I rode tubulars for 3 decades and got my far share of front flats. Coming to a stop never rated as "memorable" events, Yes, the heart rate spike when it happens and pretty funky steering, but not a big deal unless you are cornering. I'm returning to tubulars for all my good bikes primarily for that reason; safety after blowouts/flats. (The sublime ride and security of feeling riding over virtually anything is the nice desert. )
Likes For msu2001la:
Bikes: Giant Propel, Cannondale SuperX, Univega Alpina Ultima
Quoted: 672 Post(s)
Liked 417 Times
Well as long as you can guarantee you won't flat while cornering, no problem! Unfortunately, I've been unable to schedule my flats, regardless of tire technology.
Formerly fastest rider in the grupetto, currently slowest guy in the peloton
Quoted: 4806 Post(s)
Liked 3,930 Times
Liked 3,930 Times
Thread Killer
Quoted: 3147 Post(s)
Liked 1,711 Times
Flats on the front have nothing to do with tubed/tubeless/tubular. A flat on the front frequently results in a dramatic loss of control, and is many times more difficult to control than a flat on the rear. FWIW, I've been running tubeless on my road bikes for a few years and have flatted at speed. Not an experience I'm eager to repeat..
Unlike relying on a flat tire to keep a rider from sliding out on an extremely slippery rim-to-road interface, a tubeless tire will go soft but still afford pneumatic grip long before it loses all air pressure (in most cases) and is far safer for that fact.
Quoted: 672 Post(s)
Liked 417 Times
But of course the tire type does have to do with the conditions of the flat, and it’s simply unlikely that a punctured, or even cut, tubeless tire will rapidly deflate like a punctured tubed tire, or punctured tubular tire, will. It’s precisely the design of a tubeless tire and rim to hold air, unlike a tubed/tubular tire and rim which will not hold air at all if the tube is punctured. Furthermore, without any sealant to slow or stop air loss, tubed/tubular tires will deflate rapidly, with probable catastrophic impacts on handling. Due to the dramatically slower air loss rate of tubeless tires, loss of handling and control takes much longer, giving the rider a significantly bigger window to understand the condition (both feel of softening tire, and often, the telltale hissing of the puncture as sealant goes to work) and avoid dangerous situations.
Thread Killer
Liked 1,711 Times
That is entirely beside the fact that it is easier to control a bike with a flat on the rear than to control a bike with a flat on the front. The ;oint was that you shouldn't put a repaired tire on the front to reduce wear. You should put a repaired tire on the rear and keen your best tire on the front.
Likes For chaadster:
Quoted: 672 Post(s)
Liked 417 Times
My point is simple: The advice to move a repaired tire from the rear to the front is increasing the risk of loss of control. You want your best tire in the front. This is true regardless of type of tire, and is true regardless of the type of flat. It is more important to maintain control of your front wheel than it is to control your rear wheel.
Thread Killer
Liked 1,711 Times
In fact, I’d wager most front tubeless punctures do not even cause the rider to stop, much less result in catastrophe such as loss of control.
Quoted: 672 Post(s)
Liked 417 Times
Your point is grossly oversimplified and not really relevant to tubeless tire performance, because— and I’m sorry to have to keep repeating myself here— tubeless tires do not have the same risk of loss of control as tubed or tubular tires because tubeless tires do not lose pressure, in most cases, in the rapid manner a tubed or tubular tire does.
"Originally Posted by chaadster View Post
if workable, moving it to the front would further mitigate running risk and avoid immediate replacement."
That is bad advice.
Have a great day.
Thread Killer
Liked 1,711 Times
My point was in response to advice you offered: Quote:
That is bad advice.
Have a great day.
That is bad advice.
Have a great day.
In your world, where the performance characteristics of tubeless tires are apparently unknown, I can understand how you’d think it was bad advice, however, iit is sound advice when properly understood.
Thread Killer
Liked 1,711 Times
Sunshine
Quoted: 10964 Post(s)
Liked 7,491 Times
Likes For mstateglfr:
