Addiction 2021.3
#1526
Bikes: Shmikes
Quoted: 10175 Post(s)
Liked 5,871 Times
What's your mix of solo/group looking like compared to last year? Maybe you're better at surfin' wheels? Or maybe you're just more aero?
I'm finally starting to feel like I'm approaching the shape that I was in last year. Like you, my eFTP is about where it was in the Spring, but I've been feeling much better during hard efforts and it may just be that I haven't had the opportunity to really uncork it for an uninterrupted 3+ minutes.
Likes For MoAlpha:
#1527
Quoted: 20810 Post(s)
Liked 9,456 Times
Yup, this is my problem, too - it's just impossible to stay on top of the pedals when there's a flat or dip. Unfortunately, the only surefire steady hills in the area mean an 80+ mile round trip ride, which presents other problems w/r/t an all-out effort.
#1528
Fat n slow
Quoted: 3259 Post(s)
Liked 2,085 Times
Revolt has a 48/32, which is fine for this. I'm still trying to get my fit dialed in on it, I can't seem to maintain similar power #s as the R3 and it makes no sense to me.
#1529
Klaatu..Verata..Necktie?
Quoted: 10435 Post(s)
Liked 11,911 Times
This is why I always roll my eyes when people try to tell me that everyone's leaving California.
#1530
Liked 9,456 Times
#1531
Fat n slow
Liked 2,085 Times
Hard to rule out and I am hanging longer on the fast rides, but I think my solo work (ahem) has also improved and I'm also feeling subjectively stronger. I don't know what it is about those 3 min max efforts, though. I just don't seem to be doing them. All of the > 3 min hills nearby have flat spots where I find it nearly impossible to maintain power.
Likes For phrantic09:
#1533
Liked 9,456 Times
Ah - significant, but not huge. It could be a tiny fit difference, but I wouldn't be surprised if it just came down to riding conditions. I know that I'm not as confident sending it on gravel as I am on pavement; in to and out of corners/curves are always a little more conservative. Also, circling back to gearing, standing going uphill isn't an option, either.
#1534
Fat n slow
Liked 2,085 Times
#1535
Liked 9,456 Times
Maybe more than that, usually my NP on the Revolt is in the 200W range where today on the R3 it was 250ish. It's not even just gravel, I ride the revolt a lot when it's wet or threatening to rain and try to push just as hard. In rollers or on the flats I just can't hold the power the same without my quads bugging me and sometimes my knees. Honestly think I need the front end a little lower and the saddle down a touch.
#1536
Liked 11,911 Times
I saw an article that said "Vaccine resisters can’t be persuaded if they feel disrespected". So, you can't convince somebody who has taken an irrational position unless you respect that irrational position?
#1537
Quoted: 8281 Post(s)
Liked 9,052 Times
They've started reaching WAY upstream to get some more water into Lake Powell and Lake Mead, gonna start draining Flaming Gorge
https://oilcity.news/community/2021/...ater-released/
#1538
Liked 11,911 Times
Oh, okay. Yeah, that'll do it. My saddle-to-pedals on the Haanjo isn't quite the same as on the R3, and I am more prone to knee discomfort on the Haanjo, but I don't have a PM on the Haanjo to compare. I haven't checked the saddle setback, but I suspect that there's a difference in ST angle between the two. That said, I'd still want my front end a little higher on the gravel bike vs the roadie.
#1539
Quoted: 10237 Post(s)
Liked 5,184 Times
what should the chain rings be torqued too. So far pedals are not the issue. Went to fighting the head set and remembered I wanted to remove the last spacer. Was in the process of that when I got called for daddy duties. The way today is going looks like I will be on The Ritchey tomorrow.
Whyfi, I have a new route kind of figured out. Plan on trying it tomorrow to see how it goes. I did a big part of it today. Most of it is back country roads where traffic is minimal. Keeps us north east for the most part. Eventually would like to take it in to west point.
Likes For bampilot06:
#1540
Bikes: Shmikes
Liked 5,871 Times
#1541
Liked 9,456 Times
I never would have thought that it would make such a difference, but I've never been able to get as comfy on 175s as I have since moving to 172.5s. Totally dumb, but there it is.
#1542
Liked 11,911 Times
At first, I felt like I was 'flat footed' on the 170s - I tend to point my toes, rather than ankling. So I raised the saddles a bit, then a bit more till if felt more natural. I can spin the 170s a bit faster, but since I can spin the 175s at 105+ easily, it's not that big a deal.
#1543
Liked 9,052 Times
Likes For big john:
#1544
Liked 9,052 Times
I went for a little ride this morning and experienced the heartbreak of chainsuck. The chain got stuck on the big ring and slammed into the chainstay causing an abrupt halt to my cadence. I had to stop and use a convenient piece of trash to dislodge it.
Let's see: New Campagnolo rings $$$$, chain $$, cassette $$ if I can even find the stuff. Just dropped $350 at the dentist yesterday and $300 there last month. Teeth, amiright?
Maybe I should get a job?
#1545
VFL For Life
Bikes: Velo Volmobile
Quoted: 28617 Post(s)
Liked 1,857 Times
#1546
he said member
Bikes: yes please
Quoted: 2789 Post(s)
Liked 1,951 Times
Need some advice.
The clicking noise that I experienced with the C2 on hills (low cadence high torque) has developed into a constant knocking noise at all times. Reminds me of an engine with a bent piston rod.
I had to get out of the saddle today to charge up a tiny mountain and for the rest of the ride the knocking got worse.
I stopped multiple times to make sure nothing felt loose (crank arm, seat, pedals, rear wheel, bars etc…..)
Everything felt tight with two exceptions. I am running the old pedals and they have more play than my new pedals. Have always been this way though. And my headset developed a tiny amount of play during the ride.
My plan is to re torque everything down, and swap pedals but if that doesn’t solve the noise any recommendations?
Thanks.
Thanks.
#1547
Liked 9,052 Times
#1548
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12777 Post(s)
Liked 7,694 Times
#1549
VFL For Life
Liked 1,857 Times
#1550
Liked 9,052 Times
