What is this mystery threaded hole for?
Quoted: 4236 Post(s)
Liked 2,949 Times
Thanks to all your help on a number of threads trying deal with the idiosyncrasies of this bike (best estimate is 1989 Colnago Super Piu), I finally got my bike built though I still have to fix the seatpost and saddle angle after they slipped on my shake-down ride.
One thing that puzzles me though, is a threaded hole immediately in front of the race number hanger. Does anyone have any idea what it would be for? Some sort of removeable pump peg?
Likes For himespau:
Likes For Ronsonic:
Quoted: 4512 Post(s)
Liked 6,385 Times
@himespau
Maybe, but it seems the no. hanger would be in the way no matter what and this would be well into the frame fit era I think.
Also seems like it would be very difficult to orient the peg and get it tight enough to stay put.
In other words, I really have no idea.
Likes For merziac:
Quoted: 321 Post(s)
Liked 263 Times
Maybe if your race number is a different size you move the little chrome dealy out to the other boss?
Or it could be an adventure nipple ahead of its time. Modern "gravel" bikes are usually covered in a rash of bottle bosses at funny spacings with no apparent purpose.
Likes For guy153:
Liked 2,949 Times
@himespau
Maybe they let the apprentice do that brazeon and he managed to get it in the wrong place, so a second was added. A total WAG.
Likes For due ruote:
Liked 2,949 Times
Ooh, I just figured it out. It's the ultimate in luxury frame mods. Just like some frames of that era (but unfortunately not this one) had little brazed on attachements to hang the chain when you'd taken the wheel off, this screw hole is a place to stick the screw for the number hanger so that you don't lose it when you're taking it out of the number hanger to mount the number. Actually, probably not, I have no idea what it could be.
Likes For himespau:
Liked 2,949 Times
To be fair, the FD braze on is very low (I went through 4-5 FDs before finding one that would clear a 53T chainring and, and even that one would only do it if it was rotated so far it wouldn't work. I think I was on try 7 before I found one that would actually fit and shift properly. Also, the crown race seat was 26.7 rather than 26.4 and no one had bothered to mill it down, so I wouldn't be entirely surprised if this frame was built on a friday after a 3 beer lunch in Italy.
Likes For himespau:
It is a lightening hole, to reduce weight.
Likes For Bad Lag:
small ring
Quoted: 438 Post(s)
Liked 925 Times
59 Allegro Special -- 72 Bob Jackson -- 74 Motobecane Grand Jubile -- 74 Sekine SHS 271 -- 80 Nishiki International
Likes For droppedandlost:
Liked 2,949 Times
Quoted: 225 Post(s)
Liked 1,101 Times
Big frame……..might be for mounting a frame-pump support bracket beneath the top tube. Just a WAG.
Montana, where men are men and sheep are lying little tramps.
Likes For majmt:
Likes For SoccerBallXan:
Liked 2,949 Times
Honestly, since this is one of the years where both entrances to the internal routing for the rear brake are on the top of the top tube, if you'd told me that it was a drainage hole that they put a threaded collar on so that the edges wouldn't be stress risers, I would almost believe you. Almost, except for the fact that the internal cable routing is a complete tube within the top tube. Which reminds me, when I frame-savered the frame, I didn't spray any in those holes. Oh well, maybe next time.
Edumacator
Quoted: 2440 Post(s)
Liked 3,129 Times
Braze on for the turbo charger/engine.
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,054 Times
Mounting holes for schrader adapters, one for each wheel.
Likes For clubman:
Likes For thinktubes:
Bikes: Numerous
Quoted: 1678 Post(s)
Liked 3,098 Times
No idea on the threaded hole but my guess is the bread was put there on purpose to soak up humidity. Works great for brown sugar.
Likes For Spaghetti Legs:
Quoted: 1079 Post(s)
Liked 1,899 Times
Put a D-ring bolt in it, and when you're riding with your mates just reach down and adjust it and accelerate at the same time, they'll all be like, whaaaaaat?
Phyllo-buster
Liked 2,054 Times
Liked 2,949 Times
Liked 2,949 Times
Just need to find a way to attach a downtube shifter there. T'hat'd work great and confuse everyone pre-ride as much as I'm confused by it now.
Quoted: 1608 Post(s)
Liked 2,216 Times
I really like the bike anyway!
Likes For SJX426:
framebuilder
Back in the late 80's I remember putting some under the top tube water bottle bosses to hold a short Blackburn pump that had a holder designed for those under the top tube bosses. I don't think Blackburn made that holder for long. They went to holders that could fit on the side of a water bottle cage but was held in place by its bosses..
