Bags for Trek Checkpoint that attach to the hardpoints?
Bikes: '86 Centurion Elite RS '17 Trek Domane SLR6 Disc '16 Trek Boone 5 '15 Trek Fuel EX 9 '20 Trek Checkpoint SL6
Quoted: 25 Post(s)
Are there any bags (top tube, frame bag) that attach to the water bottle braze-on hardpoints?
Seems like, in particular the ones just behind the stem are made exactly for this purpose, but I can't find anything specifically made for this purpose that don't include straps to wrap around the frame.
Revelate makes one. I'm sure there are others.
https://www.revelatedesigns.com/inde.../MagTankBoltOn
Edit: I'm only aware of bolt-on top-tube "gas tank" bags. Frame bags are typically much more heavily loaded (sometimes with water), such that they will almost require the additional strapping over and around the top-tube, bottom-tube, and seat-tube; I'm not sure that any frame bags utilize bolt braze-ons.
Can You sew?
there are bags to go in a cage like the 'anything cage' often fitted to fork blade fitted bosses.. [instead of front panniers] ..
you could consider that approach..
https://salsacycles.com/components/c.../anything_cage
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
The top tube bosses started in triathlon. There are some strange bags for them if you shop from that angle. There are some single piece plastic ones that wedge open, for instance. The little zipper bags seem all the same to me but you can have some style (like this from Rogue Panda)
Genesis 49:16-17
Genesis 49:16-17
My Koga Trekking bike had 2 waterborne bosses under the top tube to attach the pump holder clips ,,
Quoted: 3242 Post(s)
Liked 2,089 Times
I’ve the Revelate MagTank bolt on, on my Cannondale. It’s a great bag. Good size, the wedge shaped tapers at the rear so you don’t hit it with your knees, the bolt on design reduces lean on the bag when you stuff it (an issue with Velcro mounted designs), the clasp is brilliant. I had it in a downpour last Tues., everything stayed dry. Well worth the $65.
Quoted: 86 Post(s)
Liked 51 Times
[After biking across Catalina Island]
My girlfriend's gravel bike in M - she was jealous of my frame bag so we got her a Rogue Panda bolt-on full frame bag as well. In this smaller size it omits the seat tube strap, and just has one near the head tube. Honestly it would probably work fine with no straps at all. In size S I bet they don't include any straps.
I like my Rogue Panda bag but there are many custom makers who offer a bolt-on option. TBH it's purely aesthetic - there's no other real advantage to the lack of straps. I have a fully strap-on frame bag on a different bike, and it's definitely quicker to remove the strap-on bag than to fish around inside the bolt-on bag to remove the screws. For instance when taking Amtrak once for the return leg of a bike tour, the conductor loading the luggage car refused to touch my bike until I removed the empty frame bag for whatever reason. I only had a minute or so to get this done in a panic before the train left. Had this been the bolt on bag, I would not have made it in time.
(Amtrak and their weird and inconsistent bike policies are a totally different thread though)
