Rebuilding Bella Basso
Edumacator
Quoted: 2441 Post(s)
Liked 3,135 Times
My first baby when I came off my bicycle hiatus, and an incredible riding bike. Thanks to a few purchases and a trade (generous from his side) with @SoCaled I am reworking Bella.
Instead of the Italian colors they previously sported, the pantographed items were repainted in red, white and blue (to match the “Americana” model.)
I had originally built her up with a mosh mash of parts including Chorus crank, Campy NR wheels with a 7 speed freewheel and brifters. Obviously I could not get it quite right in indexing.
I also never was enthused with the cockpit which has a too narrow Cinelli bar (40. I need 42/44).
Edumacator
Liked 3,135 Times
Super Record crank. Hoping the chainrings are thin enough for 8 speed duty.
Now I just need to find a good fitting black bar.
Likes For jdawginsc:
Quoted: 3514 Post(s)
Liked 2,927 Times
Nice looking frame. Any cool decals under that bike stand clamp?
Edumacator
Liked 3,135 Times
Sidi. Campagnolo on the NDS chain stay.
Has anyone ever had an extremely tight fit stem to steering tube issue. Steel wool grease treatment only slightly helped. At least it shouldn’t move...
Chrome lugs look great...fork will have to accept patina.
Might have to move to a black saddle to offset the black bars and stem. Plus some Cinelli -3ttt mismatched OCD I will have to get over. Not wasting the nice stem!
Liked 2,927 Times
I wouldn't sacrifice the stem either. At least they're both Italian.
Bikes: Cuevas Custom, Cimmaron, 1988 "Pinalized Rockma", 1984 Trek 510, Moulton custom touring, Raleigh Competition GS, Bridgestone Mb-2 & 3, 1980's Peugeot - US, City, & Canyon Express (6)
Quoted: 1104 Post(s)
Liked 3,765 Times
New patriotic paint on the panto's looks great, nice work!
My local bike shop (in Manhattan Beach, CA) was owned and run by Ted Ernst, who was a former pro racer. He really knew his stuff. He owned an adjustable variable taper reamer, which he used to use to ream out the inside of the steering tube (if necessary) so that it would exactly fit the stem. He took out a very, very slight amount on the inside of the steering tube of my 1979 Pinarello, and my new Cinelli stem fit just right - slightly sticky when doing in dry, but would slide in smoothly when greased.
I recall Ted saying that he bought the adjustable reamer from a plumbing supply store. A web search bring up plenty of options.
My experience is that Cinelli stems have tended to have a larger outer diameter than 3ttt or Nitto. If you check your bike (fork) with another stem and it fits OK (easier), I'd leave the fork alone.
My first bike was made with Reynolds 531, and the 3ttt stem fit a bit loosely. Ted told me to shim the stem with a bit of greased newspaper (for the first 1" down from the headset's top locknut) and that did the trick - the stem no longer rocked in the steering tube.
Andrew G.
Likes For Andrew_G:
Edumacator
Liked 3,135 Times
Thank you! Pretty easy with the old paint pens!
Bikes: 1973 Colnago Super, Litespeed Classic , Automoto , Pinarello Gavia TSX,Eddy Merckx Corsa Extra,Eddy Merckx EMX-5 , 1982 Moser SL, Concorde TSX, Vitus 979 KAS. Diamant SLX,60's Meteor
Quoted: 235 Post(s)
Liked 947 Times
A few years back I was bidding on an Identical Basso frame on EBay ,, I lost when the bidding got over $550 .
Great looking bike build !
Edumacator
Liked 3,135 Times
I might be paring down my "collection" of stuff, but Bella is going nowhere.
Edumacator
Liked 3,135 Times
Just a tad bit off no matter the cable routing, or adjustment. Big cog was a bit problematic. That's why I am opting to go straight 8 speed (RD, brifters, cassette) with this one.
Quoted: 1562 Post(s)
Liked 1,734 Times
Anyways, when in doubt, you can always switch back to Shimano. Shimano 7 speed brifters will shift that 7 speed freewheel or cassette perfectly fine. Going to 8 speed all campy, would mean having to find a 8speed Campy hub which is an oddball.
Edumacator
Liked 3,135 Times
Were you trying to shift the 7 speed freewheel with the 8 speed Campy Ergo? I always wondered how that would work. On paper the cog spacing should be correct.
Oddly, I have 3 or 4 Campy 8 speed wheel sets floating around...and the brifters to match (including a racing T that I have no clue what I will do with), but not sure I have enough rear derailleurs to match. I am pretty sure one of them went with the boxes of non crap...oops.
Jealous of the Basso branded stem and seat post. My Basso does not have either of those.
They did such a nice jobs with those frames though. But all I ever see for sale anymore are larger ones (60+ cm).
Edumacator
Liked 3,135 Times
Easily one of the most under-rated frames. Does everything well.
Likes For malcala622:
Edumacator
Liked 3,135 Times
Thank you! It was a really nice one that I splurged on. Would have preferred silver but at the price, it works. The crank was purchased several years ago at a good price, and @SoCaled furnished the post. Luckily I am not one who cares about cross-pollination between Cinelli and 3ttt.
Honestly, there is nothing about a vintage Basso that's inferior to the other top name Italian brands of the time.
I really want a certificate for my bike since mine is mostly a wall-hanger and the framed cert would look great behind it. Anyone done this yet that lives in North America?
https://bassobikes.com/it/accessori/...ginalita-basso
English link:
https://bassobikes.com/en/accessorie...f-authenticity
English link:
Edumacator
Liked 3,135 Times
Probably going to avoid the certication. I know Bella is real!
Liked 2,927 Times
There are reviews of the Basso Gap and Ascott in 1980s Bicycle Guide magazines. They were considered equal to the Cinellis, Colnagos and DeRosas of the day.
Edumacator
Liked 3,135 Times
Bella is complete!
I think Bella looks great, but I reserve the right to have OCD demand a black saddle at some point.
White might not be right...too bright and OCD blight
Yes, those are Shimano pedals for simplicity of exchange.
The new 8 speed Campy Chorus shifts better on the stand than the seven speed NR wheels it had.
Centaur skeleton brakes seem to fit.
Chrome on the fork is slightly pitted. Will worry about that later.
Liked 2,927 Times
I'd be more OCD about having blue bar tape instead of white--as this bike deserves!
Likes For smd4:
Edumacator
Liked 3,135 Times
Ouch! Maybe true. Too late. It’s my favorite tape.
Liked 2,927 Times
