What Pump do you carry?
Old 10-24-12, 09:44 AM
sauerwald
Bikes: Bianchi San Remo - set up as a utility bike, Peter Mooney Road bike, Peter Mooney commute bike,Dahon Folder,Schwinn Paramount Tandem
Well it finally happened to me - after 16,000 flat free miles commuting on Schwalbe Marathon Plus tires, I got a flat. THere was a nail stuck in my rear tire. I removed the wheel, replaced the tube, got the tire back on the rim and then went to inflate it with my pump. I have a Park Tool PMP-5 Frame Pump:
when when I went to inflate the tire, didn't work. Closer inspection revealed a mass of corrosion inside the head, and parts that were clearly not doing what they were supposed to. I put the pump in a trash can by the side of the road and called my wife to get a ride home.
This particular pump was purchased ~3 years ago, and has been on the bike for those three years, and had not been used. I probably should have tested it from time to time, but I assumed that it would be there for me when it was needed. In any event, I need to get a new pump, something that I can put on the bike and forget about for years until I finally need it - what do you use, and why do you like (hate) it?
sauerwald is offline
Old 10-24-12, 10:03 AM
Rick@OCRR
www.ocrebels.com
Rick@OCRR's Avatar
Bikes: Several bikes, Road, Mountain, Commute, etc.
Quoted: 83 Post(s)
Liked 5 Times in 2 Posts
I have a Topeak PEAK DX Master Blaster. Small, light, very effective mini-pump. Clips onto bracket that attaches under my water bottle cage. It has a flip-lever to seal it onto the valve (I use Presta valves) and works well every time.
I think I'm at 15 flat tires from a variety of causes since I started regular bicycle commuting in Aug. of 2011. I use Schwalbe Marathon Racer tires on my DaHon folder.
Rick / OCRR
Rick@OCRR is offline
Old 10-24-12, 10:32 AM
Notso_fastLane
Notso_fastLane's Avatar
Quoted: 626 Post(s)
Liked 701 Times in 418 Posts
I forget what brand pump I have (and I'm too lazy to go look. ), but I keep mine in a water resistant frame bag. I do get it out and check that it works every 6 months or so, but that's about it.
Notso_fastLane is offline
Old 10-24-12, 10:35 AM
chefisaac
Quoted: 32 Post(s)
https://www.topeak.com/products/Pumps/RoadMorphG
Awesome. Love it. I can pump to what I need at 120 very easily and fast. 99% of the time I do not use my co2. I just use this.
chefisaac is offline
Old 10-24-12, 10:36 AM
E.S.
just ride
Bikes: '15 Scott Speedster 20
None. Co2 nozzle and 2 cartridges from the LBS accompany spare tubes in my saddlebag.
E.S. is offline
Old 10-24-12, 10:40 AM
chefisaac
Quoted: 32 Post(s)
Hope they work when you need them. I read something from Bicycle Magazine that 20% of the co2 cartridges are defective.
Old 10-24-12, 10:44 AM
Yo Spiff
Carpe Velo
Yo Spiff's Avatar
Bikes: 2000 Bianchi Veloce, '88 Schwinn Prologue, '90 Bianchi Volpe,'94 Yokota Grizzly Peak, Yokota Enterprise, '16 Diamondback Haanjo, '91 Bianchi Boardwalk, Ellsworth cruiser
Liked 14 Times in 13 Posts
Zefal HP-X on my main road bike, and Hurricane mini pumps on the commuter and spare road bike.
Yo Spiff is offline
Old 10-24-12, 10:52 AM
Bosch007
Been eyeing this for quite awhile!
Bosch007 is offline
Old 10-24-12, 10:59 AM
bonsaiclist
Bikes: 1987 Schwinn LeTour; 1992 Schwinn Impact; 1990ish Trek 2100
I use a Zefal frame-fit pump that's nearly as old as the '89 Schwinn LeTour it's mounted on. I've considered upgrading to a mini but am too practical (cheap) to do so. Haven't had to use it much anyway, so I was a little concerned when I flatted while riding w/ my wife in another town. Changed the tire and the old thing worked like a champ.
bonsaiclist is offline
Old 10-24-12, 11:05 AM
MNBikeCommuter
MNBikeCommuter's Avatar
Bikes: Cannondale '92 T600 '95 H600 '01 RT1000
Quoted: 92 Post(s)
Liked 109 Times in 82 Posts
I carried a Zefal frame pump for twenty-five years. I replaced it last year with this one and there's no looking back.
MNBikeCommuter is offline
Old 10-24-12, 11:15 AM
David Bierbaum
David Bierbaum's Avatar
Bikes: 1992 Specialized Crossroads (red)
Quoted: 26 Post(s)
Liked 35 Times in 19 Posts
I have a Topeak Road Master Blaster, which is a full-sized frame-fit pump, which replaced my old Zefal frame pump that used gasket of old design, so I couldn't get a replacement gasket for it when it was too chewed up to make a proper seal anymore.
If I had to do it all again, I probably would have went with a Morph pump too, just for the integrated air-gauge, but the Master Blaster works just fine for me. And having learned from the old pump, which didn't work when I needed it, I check my pumps out on a regular basis now, to make sure they work before I leave the house.
Last edited by David Bierbaum; 10-24-12 at 11:16 AM. Reason: add a "d" to "integrated". My bad...
David Bierbaum is offline
Old 10-24-12, 11:29 AM
Steely Dan
born again cyclist
Steely Dan's Avatar
Bikes: I have five of brikes
Quoted: 201 Post(s)
Liked 78 Times in 31 Posts
FWIW, i have yet to encounter a defective CO2 cartridge. but i always carry at least 2 just in case.
i love my CO2 pump because it can inflate a tire to 100+ psi in seconds. so fast. so easy.
Steely Dan is offline
Old 10-24-12, 11:36 AM
myrridin
I carry the Lezyne HPG micro floor drive on my road bike and the HVG microfloor drive on my utility/mountain bikes. In my opinion it is the only portable pump able to come to a high pressure on road tires with nearly the same easy effort as a full size pump. And it is small enough to attach next to one of my bottle cages.
File Type: jpg
myrridin is offline
Old 10-24-12, 12:08 PM
RickB.
RickB.'s Avatar
Bikes: '04 Cannondale R1000, Haluzak Horizon recumbent
I carry a Lezyne mini hand pump buried in the trunk bag as well as 2 CO2 cartridges and one extra tube, I like the speed of the CO2's, but "They've done studies, you know. 60% of the time, it works every time." And my hand pump has never failed me....
RickB. is offline
Old 10-24-12, 12:15 PM
CptjohnC
Old, but not really wise
CptjohnC's Avatar
Bikes: 2010 Kona Dew Drop (the daily driver),'07 Specialized Roubaix (the sports car), '99 ish Kona NuNu MTB (the SUV), Schwinn High Plains (circa 1992?) (the beater)
seconded (or thirded, or fourthed).
I've had my Road Morph on my commuter for over 2 years, and use it regularly. I won't lie and say it is as fast as a floor pump, but it is plenty of pump for most situations.
I suspect that any pump that is not used for 3-4 years, though, will have a pretty substantial risk of failure. Seals and moving parts like to be lubricated, which is most often accomplished by movement through use. I also own a Lezyne mini pump (can't remember the specific model) for my road bike. It's a very nice piece of hardware, but I'd be hard pressed to get past 60-70 PSI, I think. Not so the Road morph.
CptjohnC is offline
Old 10-24-12, 12:19 PM
dramiscram
ouate de phoque
dramiscram's Avatar
Bikes: Bianchi, Nakamura,Opus
This :https://www.louisgarneau.com/ca-fr/pr...PE_TWO_STEPS-G
dramiscram is offline
Old 10-24-12, 12:33 PM
caloso
caloso's Avatar
Quoted: 2952 Post(s)
Liked 3,106 Times in 1,417 Posts
I am a belt and suspenders kind of guy: CO2 and a new tube for the first flat; frame pump and patch for any subsequent flats. And my frame pump is the Park one the OP binned. I haven't had any issues with mine, though.
caloso is offline
Old 10-24-12, 01:04 PM
myrridin
I had the exact opposite situation with the Road morph that I used to own. I had trouble getting a tire much past 80 psi, and that took a fair bit of effort. The Lezyne I mentioned does so easily, but I suspect that is more a result of the design then the brand. It really is designed like a miniature full sized pump, and the air hose lets me place the pump in a convenient location for pumping, rather than convenient to the valve...
myrridin is offline
Old 10-24-12, 01:08 PM
wapiti
Zefal HPx
wapiti is offline
Old 10-24-12, 01:10 PM
megalowmatt
megalowmatt's Avatar
Road Morph G
megalowmatt is offline
Old 10-24-12, 03:11 PM
usndoc2011
thats a shame the park tool failed you in the moment of need. they have such a good reputation. i used to use CO2 cartridges and the Innovations Ulratflate pump, which accepts threaded and nonthreaded CO2 cartridges (nonthreaded = cheap on ebay), and which worked great if I was only dumb enough for 1 flat per ride. on those 2 flat rides, I was S.O.L. and I also didn't like having to carry about extra CO2 cartridges or worry about not having any at home when I needed them, so I switched to the Topeak RaceRocket Master Blaster. I got the smaller one because I use 28C tires so the pressure of the tire (90-100 psi) is close to the pumps max of 80-90 psi, and it fits in my compact ortlieb handlebar bag (the HPX for road bikes -psi 120- is a few inches longer, but backpackable, definitely). IMO, it is ideal because it goes to presta and schrader and has a extension tube which places less stress on the tire valve as you're cranking away with a mini-pump. used it the other week as my Conti GP 4 season got a flat after ~1500miles and it worked great.
usndoc2011 is offline
Old 10-24-12, 03:49 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
It's in my Pannier , so not exposed to road salt and such
[though 1/4-minus gravel is laid down instead of salt on Icy roads, here].
I have various pumps on the several bikes
Silca Impero on my Road bike
and the Zefal - Brompton one on that bike, are out on the frame..
A blackburn frame fit on the touring bike.. up along the Top Tube..
all the others are out of the weather..
fietsbob is offline
Old 10-24-12, 04:03 PM
Zephri
K0UGR
I have a Zefal HPX Classic on my Trek 1200 and some random bargain bin pump in the pannier on my Motobecane. I haven't had any flats yet where I haven't been near a floor pump (rim tape flats X3), but the pump on the Moto has been used several times by other people.
Zephri is offline
Old 10-24-12, 04:05 PM
wicked ink
part time optimist
wicked ink's Avatar
Bikes: 2013 Pinarello Pista | 2007 Nagasawa Special
Originally Posted by megalowmatt
Road Morph G
Same here.
wicked ink is offline
Old 10-24-12, 04:12 PM
EmeralDQueen
EmeralDQueen's Avatar
Bikes: Iron Man
I just have like random pump nothing fancy just in case, but I really would like to get a better one though.
EmeralDQueen is offline
