advice on changing brake pads on vintage bike
Bikes: Wife says I have too many :-)
Quoted: 327 Post(s)
Liked 250 Times
I have new Kool Stop salmon pads to go in my 1984 Trek 770 brake pad holders. The pads in the holders now are the original black pads. How do I remove the old pads without damaging the vintage holders ? Thought the C&V forum would be a good place to ask.
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
If the old pads won't slide out, the holders were not meant to be re-used.
Did you get any assurance that the pads you bought were made for your particular holders?
Obviously it isn't recommended to bend one of the end tabs 90 degrees open and then closed again, it can't be counted on to be structural at that point. But you could drive a retention screw into the holder if the pad happens to match the inside shape of the holder exactly. You're on your own at that point as far as the assembly being reliable or not.
Quoted: 1609 Post(s)
Liked 2,216 Times
@frogman Can you supply pictures of the holders? Or at least describe their shape? Which brake caliper is on the bike?
Quoted: 478 Post(s)
Liked 634 Times
I have successfully pried out old pads from the holders with all 4 sides enclosed, and reinserted new pads - its not easy in either direction but quite do-able. However I agree pictures of the existing pads/holders and the new pads would be a great idea.
Likes For markk900:
Quoted: 472 Post(s)
Liked 1,049 Times
Keep in mind, for a few years brake pad holders had only three sides with the pad slid into the slot. The mechanic had to pay attention and install the assembly so that the braking action forced the pad into the holder vs the other way. No drinking beer prior to working on bike. Then the lawyers took over and mandated that pad holders have four sides so that they could not be installed backwards.*
Ergo, you could bend one end down and break off that end tab. Slide the old pad out then install the new pad (wetted with rubbing alcohol to ease entry) and pay attention to how you put it back on the bike. It can be done.
Oh, then never ride the bike fast, downhill, backwards and hammer the brakes.
* of course we now have brake pads (ex: Jagwire) that have a tiny, hard to read "L" and "R" on them to ensure that you install them in the correct orientation. No drinking beer prior to working on bike.
Likes For Prowler:
Quoted: 2588 Post(s)
Liked 4,826 Times
A photo would save a lot of speculation...just sayin'
DD
DD
Likes For Drillium Dude:
Quoted: 100 Post(s)
Liked 57 Times
I've done this operation many times with excellent results. A bench vise and a short screwdriver will help to slide the old pad out (and the new one in, if necessary).
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3891 Post(s)
Liked 6,491 Times
Likes For SurferRosa:
Quoted: 932 Post(s)
Liked 1,319 Times
I've done this many times with no difficulty at all. Assuming that you have 4-sided holders, there is no need to break off or bend the end-tab. Just use a skinny screwdriver to pry the old ones out. Then use either a bench vise or a woodworking clamp (and some fiddling around) to squeeze the new ones in. Easy peasy. Sometimes a bit of dishwashing soap on the pad makes it even easier.
A 1984 Trek 770 should have Campy Super Record brakes. (OP, it would have been prudent to mention that.)
This is how most pro mechanics would do it: Remove the brake pad assemblies from the calipers. Squeeze the rubber pads in a bench vise, just below the metal holder. Tap the metal holders off the rubber pads with a hammer and dull punch or big cheap screwdriver. Pay attention to which end is open. When they are out, squeeze the new pads in with the vise. Reinstall the pad assemblies and readjust the brake alignment etc.
I'd recommend either genuine Campagnolo replacement pads (still sold) or Koolstop blacks. Salmons tend to squeal on campy record calipers. Not worth it unless you ride in the rain a lot. Since you have them, it might be worth a try. Sanding your rim surfaces lightly and sanding a toe in type bevel into the pads will usually stop the squeal if it happens.
Use a hacksaw blade to cut a groove down the middle of the pad. Then squeeze pad and remove from holder.
Adding some lube would not hurt but you have to remove the residue after removal.
Bikes: Several
Quoted: 207 Post(s)
Liked 1,042 Times
Bikes: Miyata six-ten, Miyata Grand Touring, Univega Sport Tour, Univega Gran Turismo, 80's Trek MTB, 2008 Dahon Mariner
Quoted: 85 Post(s)
Liked 83 Times
WOW, is this really a thing? Why would you use the original holders? Just wondering. Is the metal quality that different? I guess that is a silly question, of COURSE it is. But had no idea the restoration freaks got this much into the detail, no disrespect intended.
Give thanks, for unknown blessings are already on their way.
~Native American Prayer
Quoted: 327 Post(s)
Liked 250 Times
Thanks everyone for the help. Here is a picture. The brakes are on a 1984 Trek 770. They are Campy Super Record.
https://i.postimg.cc/yNDzdBfx/IMG-4030.jpg
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,803 Times
Quoted: 327 Post(s)
Liked 250 Times
No disrespect taken. The reason is because it is a vintage 1984 Trek 770 in great shape. Has Campy Super Record gear. It is in pristine condition and I want to keep everything original. The original holders are in perfect shape, I just want to change the brake pads.
señor miembro
Liked 6,491 Times
Nothing really looks appropriate with those Campy calipers other than the original shoes. So, refurb/file the pads or replace 'em with these:
https://www.ebay.com/itm/4-NEW-KOOLSTOP-Brake-Shoe-Pads-f-Vintage-Campagnolo-Nuovo-Super-Record-etc-BLACK/382461675245?hash=item590c7e06ed:g84AAOSwY31a0s-x
Quoted: 2326 Post(s)
Liked 5,013 Times
Yep, look just like the ones I recently did. Didn't even need anything special to remove them. First one pushed out by hand. The 3 others were tighter but I just shot some PB blaster along the edges and at the two holes in the bag. THen they pushed right out. Cleaned the holders good, and polished them to a mirror like shine. Then pushed in the new Kool Stops with a little dawn to lubricate. Easy peasy!
Steel is real...and comfy.
Quoted: 327 Post(s)
Liked 250 Times
Likes For frogman:
Friendship is Magic
Bikes: old ones
Quoted: 26427 Post(s)
Liked 10,386 Times
...not everyone is so inclined. I never look at the brake shoes on my bicycle, and am happy with whatever works well.
Liked 5,803 Times
It’s a Campy thing, no way you put those shoes on Campagnolo nrakes. The bike gods would smite thee.
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,703 Times
It's gotsta look good- I'm not such a fan of the look of Continentals- I'm sure they work great- but there's an aesthetic they don't meet.
Commence to jigglin’ huh?!?!
Friendship is Magic
Bikes: old ones
Liked 10,386 Times
...my aesthetic sense has always been impaired. I'm like the Greta Thunberg of bicycle aesthetics.
señor miembro
Liked 6,491 Times
Yeah, it's gotta look right. My Bert came to me with mid-reach Record calipers and cheap pads. I hate when the pad is all the way at the top of the arm. So, I needed short reach, and had some Dura Ace calipers in my bin. Unlike Campy, DA brakes look normal with the standard Shimano holders kool-stop sells. And those salmon refills not as costly as the Mathauser ones.
Sorta the cheaper route to go, I know. But I further justified the DA choice as the Bert has a DA bottom bracket, too. Plus, the 7400s work quite a bit smoother than Record brakes! <ducks>
