Fork
Old 05-20-06, 12:19 AM
seaden
Dirty Fingers
seaden's Avatar
Bikes: Motobecane Super Mirage Fixie, Somec Track Bike, Univega Supra Sport 14 sp
Fork
Looking to buy a new fork for my bike and need to know what I me to know when purchasing one that will fit. I have a campy headset and it is a threaded fork...I think the bike is 53cm and it's a Pinarello
seaden is offline
Old 05-20-06, 04:36 AM
operator
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 28 Times in 20 Posts
You need to know more than that.
operator is offline
Old 05-20-06, 04:56 AM
travsi
i don't stop
travsi's Avatar
Bikes: soma rush, giro
yeah, like headtube length and headset stack height
(campy track hs stackheights can be anywhere from
around 34mm to 39mm)
velospace
travsi is offline
Old 05-20-06, 05:21 AM
LóFarkas
LF for the accentdeprived
And make sure you know whether it's 1" or 1 1/8". (Outer diameter of the steerer tube). Both exist AFAIK. Apparently, there is also some variation in the internal diameter, which determines what stem you can use with it.
I guess you can just take a tape measure to your current fork to see how long a steerer you'll need. (assuming that frame and HS will be the same). A longer steerer can be cut to fit, I presume (?), so just make sure it's not too short. Then a caliper tells you the other 2 sizes.
LóFarkas is offline
Old 05-20-06, 11:25 AM
seaden
Dirty Fingers
seaden's Avatar
SO basically take it to the shop
seaden is offline
Old 05-20-06, 11:37 AM
humancongereel
live free or die trying
humancongereel's Avatar
Bikes: bianchi pista workhorse, cannondale r1000, mountain bike fixed conversion
i would. take it and make sure the dimensions are the same. when i replaced my fork, i had my old one for comparison, and i think it helped a lot.
humancongereel is offline
Old 05-27-06, 07:07 PM
seaden
Dirty Fingers
seaden's Avatar
how about the inches of threaded and the inches where it isn't threaded. THe one I am currently look at is 6 3/8 inches in length, 2 1/4 inches of thread
just measuring my headtube...it looks to be 5-3/4inches without taking the fork out...seems like the one I'm looking at will definately be too big huh?
seaden is offline
