GCN on Steel
Quoted: 2331 Post(s)
Liked 5,045 Times
Noticed the riding scenes were from the old video where he rode the old Orbea Cabestany.
Steel is real...and comfy.
Bikes: 1978 Bruce Gordon, 1977 Lippy, 199? Lippy tandem, Bike Friday NWT, 1982 Trek 720, 2012 Rivendell Atlantis, 1983 Bianchi Specialissima?
Quoted: 346 Post(s)
Liked 177 Times
Nice video. Thanks.
Bikes: Steel 1x's
Quoted: 632 Post(s)
I felt like he was trying to take a dig at steel bikes the whole time. Or rather steel bike proponents. Would be nice to get someone that actually knows about steel bikes to do the video.
Quoted: 4560 Post(s)
Liked 2,803 Times
I usually enjoy GCN videos but I can only take just so much of Simon's voice. Too much vocal fry, trying to force his voice to sound deeper than it naturally is. He should take some voice lessons. But he's good in the mix with the other co-hosts. They have a great rapport and the videos are fun and informative.
Quoted: 2506 Post(s)
Liked 2,986 Times
I rode high-end steel bikes from the mid-'60s to the mid-'00s and ran bike store service departments for two decades, and I didn't see any anti-steel bias.
Liked 5,045 Times
Quoted: 1136 Post(s)
Liked 650 Times
I thought the video did a great job of outlining the properties, benefits, and disadvantages of the material while also highlighting the pertinent point that most people don't get - there is no such thing as "the steel bike" or "the carbon bike", nor properties that all steel bikes or all carbon bikes have. All bikes use different tubing, geometry, components, which have more of an effect on the feel of a bike than inherent properties of the material itself. The general public doesn't get that, and many C&Vers don't either.
Plus that fillet brazed Saffron frame featured in the video is beautiful. I think a lot of C&Vers would appreciate the construction (the seat junction especially).
52psi
Quoted: 790 Post(s)
Liked 802 Times
I think he was just trying to maintain a level of neutrality/respectfulness with regard to materials, which is sorely needed (around here especially).
I thought the video did a great job of outlining the properties, benefits, and disadvantages of the material while also highlighting the pertinent point that most people don't get - there is no such thing as "the steel bike" or "the carbon bike", nor properties that all steel bikes or all carbon bikes have. All bikes use different tubing, geometry, components, which have more of an effect than inherent properties of the material itself. The general public doesn't get that, and most C&Vers don't either.
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4688 Post(s)
Liked 5,836 Times
He mentioned toughness at the beginning, but never expanded on it.
That, to me, is one of the great benefits of steel. It typically gives fair warning before it fails, much more so than aluminium and carbon fiber.
Liked 650 Times
There are many different alloys of steel and aluminum. And then further multiply those by various processing (annealing and heat treating) that can change the mechanical properties of the alloy, making them more ductile or harder or stronger. And then further multiply that by the various grain structures that can be produced with modern alloy production techniques that give the metal different responses to different types of stresses, impacts, and strains. This scientific paper demonstrates how variable a metal's response to force can be depending on the type of alloy, tempering, grain structure, and direction/type of force.
To put it shortly, a material's properties are not set in stone, so to speak. The way modern aluminum responds to stress can be made very similar to steel, depending on how it's made and treated. We already see this with the way steel production has evolved over the last four decades. Frame makers in the 60s would never have even imagined the steel alloys that exist today with corrosion resistance and UTS in the 2000 mpa range. Same for aluminum. It makes no sense to say "aluminum" acts a certain way in general. Too many bicycle enthusiasts have tunnel vision when it comes to modern metallurgy and production.
Bikes: Yes
Quoted: 3231 Post(s)
Liked 3,874 Times
In that case, they misspelled "aluminium" on the overlay at 1:57.
My Bikes
My Bikes
Quoted: 7354 Post(s)
Liked 2,488 Times
I like their videos, including this one. @canklecat, I know what you mean about his vocal technique, as I'm a singer, but it's in fashion, and while I won't use it, I'm OK with it. He seems to have some training in acting or something related, which can add a little dramatic emphasis even when he is just dispensing facts, and I find that to be a good thing.
Liked 2,488 Times
Fit is also another huge factor. Changing the fit of a bike (or going from a bike of one fit to a bike of another fit) can give dramatic differences. Changing the handlebars on a bike can get me to love or hate a bike.
Bikes: Steel 1x's
Quoted: 632 Post(s)
He mentioned rust for example. A lot of builders are using either the new stainless stuff or ED coating on the inside to negate rust. Essentially a non issue at this point.
He mentioned 4130, but failed to mention butting, heat treating, air hardening that allows for improvements over standard 4130, not to mention things like 953. I also thought it was odd he mentioned Columbus (Italian) versus Reynolds (English) when he brought up tubeset manufacturers.
He also failed to mention that steel is much more impact resistant to sharp objects and fails less catastrophically then carbon fiber.
He also did not mention that steel picks up where carbon leaves off for heavier riders and loads.
He also danced around the whole steel feel difference seeming to play it off to geometry.
When you summed it up, he downplayed steel's strengths while mentioning the weaknesses. Not that it really matters, people are going to ride what they like. Once they get on a steel bike, they will likely wonder why it took them so long to ride one.
If this video bothered you, make sure and avoid the one where he rides an 80s steel Orbea and a modern carbon one back to back. It was a pretty futile exercise.
Bikes on Flickr
I prefer email to private messages. You can contact me at justinhughes@me.com
Bikes on Flickr
Bikes: Steel 1x's
Quoted: 632 Post(s)
Kinda proving my point about the GCN slant. Steel bike improvements didn't stop in 1980. Maybe comparing a 2017 Genesis racing bike to a modern carbon one would have been a more fair comparison that doesn't make steel bikes out to be something of antiquity.
FWIW, I think GCN make some very informative and well produced videos.
Bikes on Flickr
Bikes on Flickr
Liked 5,836 Times
While that might be true for a certain group of frames from a certain time period, again, it's a generalization that isn't true by nature of being one material or the other.
Quoted: 1627 Post(s)
Liked 630 Times
That's exactly how I interpreted it, too.
Liked 2,488 Times
Yeah, I don't feel an aluminum or carbon fan is going to ruin my enjoyment of my steel bikes.
