Hybrid rider in SE Arizona with questions
I'm riding 12 miles a day on my hybrid bike. I'd like to try using aero bars or bar ends due to mostly wrist issues, but also mild elbow and shoulder issues (I turned 60 last month). I've been using my wrist braces when I ride to keep the wrists in alignment, but I'd like to try something else. I feel like the crouched position of the aero bars will help me ride easier on windy days. I do a simulated crouched position, resting my wrist/lower arms on my handlebars (the rigid wrist brace helps with this placement). Am I nuts, or does this sound reasonable to anyone? I'd welcome any advice.
Quoted: 5793 Post(s)
Liked 2,590 Times
It sounds very logical and well thought out. I have multiple bikes, including ones with dropped bars and straight bars. Overall, I'm not as happy with straight bars because the hand/wrist rotation is wrong and I'm far more comfortable riding when my palms face each other.
So, get the bar ends, then feel free to rotate them up or forward to adjust wrist angle and your overall posture. It's your bike and only you can decide how you want to ride it.
BTW - the worst that can happen is that you end up removing the ends and feel you wasted a few bucks. But IMO it's not wasted if it helps you find a better position, or learn what doesn't work.
The above is about the bar end idea. Aero bars are a different story because they reduce steering control. I don't recommend them for anything except riding on closed circuits. In any case, 12 mile rides don't justify the need.
FB
Chain-L site
FB
Chain-L site
Quoted: 1074 Post(s)
Liked 295 Times
Nothing wrong with bar ends.
I even added some stubby ones on a wide bar bike, only to let me stand the bike upside down w/o damaging the bike computer, light, etc.
Aero bars is a so-so thing.
It works well to get out of the wind.
But control is reduced.
And if your bar is already set low, adding aero bars to a regular bike can cramp your breathing.
In the netherlands it's quite common to see Townies with aero bars.
But they have the bars so high that there's still plenty of breathing space even in the aero position.
Might require some shimming creativity to get aero bars to clamp well to a flat bar.
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
Bar ends have been around for decades but are still useful.
Quoted: 1364 Post(s)
Liked 1,678 Times
I use bar ends (inboard) and an aero bar on my straight bar MTB-based commuter. In my 40s my hands began getting "crampy" and "achy". Not just biking, but playing softball, and other activities. I found my drop-bar road bike was kinder to my hands, but I still had issues. Changing hand positions frequently helped as has padding the bars with medium foam pipe insulation. The drop-bar bikes naturally offer a few hand positions...so I went about increasing my hand hold options on the MTB.
On the flat-bar MTB I first added bar-ends but slid them "inboard" so they appoximate riding on the hoods of my road bikes. Then I found an aero bar on sale for $20. I put that on and found I also use the elbow pads as hand grips which allow me to sit very upright. And when I stretch out forward on the aero bars there is no pressure on my hands, and I pick up an extra mph or two, especially into a stiff wind.
Not only do the extra positions help with the hands, but they feel good on my back, although I don't have any chronic back issues.
Go for it...it's your bike, and after age 50, you shouldn't care too much what others think.
Quoted: 8287 Post(s)
Liked 9,062 Times
When I ride my mtb on a road section, I wish it had drop bars.
Maybe you could rent a road bike?
Just having more hand positions available may help. I've seen aerobars used on hybrids, but not sure if it'll help with shoulder issues. Definitely try them first, but if they don't help enough you may be a candidate for a recumbent - of which there are many 2- and 3-wheeled models. The only recumbent shop I know of in AZ is Ajo bikes in Tuscon.
Quoted: 523 Post(s)
Liked 230 Times
I knew there must have been at least one recumbent shop in the Phoenix area because of the number of recumbent bikes and trikes on the local CL. There is - Sun Cyclery SUN Cyclery. The shop has been there for decades.
However if she wanted to try out one on the cheap, there is an older Linear listed for $450. It is similar to my first decent recumbent that I bought back in 2001. It's easy to learn to ride and this one has underseat steering which I much prefer. It's been there a while so the owner may be willing to go even lower. https://phoenix.craigslist.org/evl/b...231245855.html Be aware that Linears come in multiple frame sizes. While you can adjust the seat and crank to fit most anybody if you buy one that is too long it may take too much weight off the front end. Still rideable but makes loss of front traction a bit more likely. There is nothing worth looking at in the trike listings.
If you look at the Tucson listings there is a Catrike Villager for $850. https://tucson.craigslist.org/bik/d/...295655983.html Current price for a new one is $2,550 so while this may seem expensive to a non-recumbent owner, it is really cheap for a high quality trike. If you search on "recumbent" in any of the nearby city listings for CL you will also get an extended listing at the bottom for nearby cities. Might find something closer to home that way.
Ergon GR 3, is a comfortable choice, I often use an open palm 'non grip', resting my hands on grip & bar end .. they are nicely integrated.
Figure 8 bend trekking bars are another favorite, they offer a forward grip which is conducive to a bent over into the headwinds posture..
mkwdrs
Hybrid Bicycles
0
04-28-16 07:36 PM
MudPie
7
06-08-12 10:09 AM
